Results 1 to 34 of 34
    Dec 2011
    is it worth it buying low budget repair stand?
    Hi I was wondering anyone have experience with them would they loosen up with the bike on the stand?
    I saw this ones but there are others similar
    Adjustable Pro Bicycle Repair Stand Mechanic Workstand - TheLAShop
    Adjustable Rotated Bicycle Repair Stand Mechanic Workstand - TheLAShop
    Reputation: JoePAz's Avatar
    May 2012
    I bought a $100 stand from pricepoint. I have been happy with it so far.
    Joe
    '12 Santa Cruz Highball 29", '13 Santa Cruz Solo 27.5",Vassago Verhauen SS 29" XC, AM, blah blah blah.. I just ride.
    Jun 2013
    I have the stand from the first link you posted. I'm no expert bike mechanic but I've had this stand for about 2-3 months now and it's been nothing but great. The fact that it folds away nicely so that I can stow it in the corner of the garage or even throw it on the bike of my truck is well worth it. It's stable, the top clamp is sturdy enough and the included magnetic tray and handlebar holder are an added bonus. I really like that you can rotate the clamp in small increments and the mechanism seems to be sturdy enough.
    I'm not saying this stand is equivalent to an uber expensive Park Tool stand but for the $65 shipped I paid it's certainly worth every penny.
    You can make a stand pretty cheep,look in the tools forum or google it.
    T.W.O.
    Reputation: mimi1885's Avatar
    I like the first one. It looks more solid. I don't like the stand of the second one, if you rotate the bike on the stand it may not be as stable as when it's in the center.
    Reputation: borabora's Avatar
    If you plan on working on bikes for hours and hours every week then I'd recommend getting something fancier and heavy duty. But if you are like most of us and use the stand mostly to lube the drivetrain and make minor adjustments then any cheap stand should be fine. Even if you do major work on your bike once in a while an expensive stand isn't really needed. I'd rather use the extra money for a truing stand and other tools.
    Jan 2013
    Quote Originally Posted by JoePAz View Post
    Yep, I got mine from pricepoint for cheap as well. I have it for over a year and it's great!
    Aug 2005
    If you spend a bit more money and get a lower end Park Stand, you'll be much better off.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    You can build a sturdy stand for about $30.
    My Nashbar stand has performed very well.
    Monte
    Lodging & Guiding for SW Utah Trails
    http://www.vrbo.com/298759
    www.UtahMountainBikingAdventures.com
    MTBR Discounts
    MTBR Member
    Reputation: ncfisherman's Avatar
    If you have a solid bench or post/wall, these may be a good option...Park Tool PRS 4W 1 Deluxe Wall Mount Repair Stand Bike Repair Clamp New | eBay -- Park Tool PRS 7 2BENCH Mount Repair Stand and 100 5D Clamp Single | eBay
    Having a nice solid base is good for high torque parts like cranks and bottom brackets.
    Jun 2013
    First linked stand is good - with splayed feet giving some leverage from the rear and all four sides. No go on the second one - similar to my Nashbar special and it gets tippy too often.
    Reputation: KevinGT's Avatar
    Dec 2012
    Going from no stand to ANY stand is a huge improvement. I spent 20 years (on and off) working on bikes without a stand. I finally got smart and bought my first stand about 6 months ago. It is SO much easier and so much more fun to work on my bikes now that I'm kicking myself for not getting a stand years ago.
    That being said, I would think that the change from an OK stand to a great stand would be less impactful!
    Dec 2012
    Quote Originally Posted by KevinGT View Post
    As long as the stand is at least OK, this statement is so true.
    The one in the first link looks better, more metal and less plastic than the one in the second link.
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    Quote Originally Posted by VTSession View Post
    Agree - I've had a Park Consumer stand for almost 20 years - steel construction, very easy to work on. It has fold-out legs but otherwise is very sturdy and easy to use.
    Try to go with the most steel construction you can afford if you're not going to be traveling with it.
    JMJ
    Dec 2011
    thank you all
    No I wont be able to use one of those bench stand or wall, im in a rental house.
    I posted those link without searching much, so the 1st link is a good deal then?
    my question was because the 1st time I looked at stand the ones I saw were in the $230 range now I just saw that $99 stand along with some other in the $175 range.
    it seem there are mixed reviews about this one, the Spin doctor pro G3
    Spin Doctor Pro G3 Work Stand -
    this one same thing mixed reviews, Park PCS-10
    Park Tool PCS-10 Home Mechanic Work Stand -
    the sette I saw good reviews, ST-7 DLX
    Sette ST-7 DLX Foldable Workstand | Sette | Brand | www.PricePoint.com
    this one look nice also, plus the free 2 day shipping,
    it seem that it have a plastic connection between the horizontal tube and vertical one, wonder if it would last since it would hold the most stress
    Amazon.com: Feedback Sports Sport-Mechanic Repair Stand (Black): Sports & Outdoors
    so would it worth it to get one of those or the 1 on my first post at $60
    or it mostly a brand thing
    yes just casual work, cleaning etc.
    debating if I leave the bike on it overnight. that may be another topic.
    Jun 2013
    I constantly leave my bike on the stand overnight with no issues. The rubber feet on the jaws leave no mark whatsover on my bike. The bike will rotate if you're doing work on it that requires putting a lot of force so I just get a good grip on the frame but I've never had the bike fall off or come loose from the stand. For the 60 or so bucks, it's definitely gets the job done.
    Reputation: OmaHaq's Avatar
    Jun 2010
    Unless you work on bicycles constantly and your $$$ is dependent upon the speed at which you fix a bicycle, spending money on a stand in general is a waste.
    I've been using a $6 ratchet pulley attached to the ceiling + $5 spectra to suspend bikes to work on them. 360deg access. I find it the fastest way to do things + it's cheap and easy.
    In a shop setting when you turn and burn, then a bolt-in stand is nice for everyday stuff. And then an overhead C-track carrier system is better when assembling a lot of bikes at once. Just pass the bike along on the carrier to the next guy to assemble something else or store the finished product.
    Trail-side... I use a compact stand and I don't really like it.
    - The only thing that keeps me on a bike is happiness.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    I just picked up a barely used Wrench Force stand($200) on CL for $30. Used is always the best deal for stands.
    T.W.O.
    I have a spin dr pro it's the same as Topeak pro, as well as 2 park tool stands no complaints about the park tools they are solid, well one, they are considerably heavier than the spin dr. Found myself using the spin dr most of the time because its lighter and easier to set up and move around. I added a tool trays for $10-15 deal I found on amazon.
    I'd definitely recommend you to go with the spin dr.
    Reputation: Slee_Stack's Avatar
    Quote Originally Posted by cloudbuster View Post
    I have something nearly identical to this Feedback stand (that I bought off ebay years ago). Its a VERY solid stand and always done me right. I recall paying about $120 for it. I use it every week. The worst part about it is when i collapse the tripod base, I have to be careful not to catch my fingers. Done that once ..OUCH!).
    Dec 2011
    I just called the theLAshop about the Adjustable Pro Bicycle Repair Stand Mechanic Workstand to ask about the warranty only have a 90 day warranty for $60
    I think I might spent the difference and get the performance stand they have a 20% now until the 11 of this month plus the lifetime warranty.
    anyone have a coupon for performance?
    they also sell the park tool pcs 10 with the 20%
    so the base of the spin doctor is better than the park tools 10?
    T.W.O.
    I'd say different, but much lighter for sure. I do agree with SleeStack I did get pinch a few times but I definitely learn not to repeat that too often Both my Park tool stands are much heavier and took a bit longer to set up, plus both lean forward instead of standing straight up. I work on my bike all the time and the Spin Dr is just the right tool for me. I first bought the plain version and just add the tool tray and digital scale later.
    I bought one of the Sette stands during a free shipping weekend. The best feature of it is it collapses down really easy, takes up no space, and is light. The downside is it isn't super stable. Not saying it falls over all the time but you do have to be care full cranking on things and sometimes stand on one of the legs to brace it.
    Aug 2013
    This would be like buying other hobby stuff. Always get the best you can afford, otherwise
    you'll ask yourself why you didn't get so-and-so brand the first ...
    That said, looking for used should be a good route. It's just a stand, hard to say you need
    it NOW, so be patient and get a good used
    Mar 2013
    Quote Originally Posted by ncfisherman View Post
    I have a park tools bench/wall mounted stand but with the micro adjust clamp. I love it, but there are times I do wish I had one that was portable.
    Sometimes I have my motorcycle apart in front of my bench and I need to do something to the bike. Sometimes its a nice day and I want to clean the bike on the patio. At races I use a friend's stand if something goes wrong.
    I think the bench/wall stand is great as a 2nd stand, but a portable one is more versatile.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Dec 2011
    Dec 2011
    Does it make any difference where on the seat post you put the clamp?
    Close to the saddle or to the frame.
    Also does the wheel axle should be on a horizontal line. Or angle like that is fine.
    I just don't want to put extra pressure and damage the frame.
    Thanks.
    Now I just notice how dirty the chain is.
    Dec 2009
    Used bike stand is a good solution. 3 years ago I baught one of the best stand (PRS-5) for a descent price. Just need to search a little.
    Park stand all the way! I bought the price point one and it died just over a year after I bought it. And buy a Park stand from REI and if you are a member and it ever fails you, you bring it back for a refund or a new one.
    This is the stand I've been eyeing:
    Pro Bike Adjustable 41" to 75" Repair Stand w Telescopic Arm Cycle Bicycle Rack | eBay
    Looks to be the same as in the original post...
    *Oops, just noticed my link is the same as the link a couple of posts above.!
    I really love my Park consumer stand. Makes such a difference in working on your bike. Other stands probably work well. I just know the Park is great
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    $53 bucks (on sale) and its awesome. the one they actually have now is where it can be adjusted with one hand (reviews state adjusting with two but they have redsigned it for the better)
    Rakuten.com - RAD Cycle Products Pro Bicycle Adjustable Repair Stand
  1. Repair Stand Mounted Wheel Truing Stand?
    By homey in forum Tooltime
    Last Post: 10-08-2016, 11:25 PM
  2. Repair Stand Suggestions
    By FlatTyre in forum Tooltime
    Last Post: 03-12-2013, 06:04 PM
  3. repair stand which one ?
    By 05kas05 in forum Tooltime
    Last Post: 01-25-2013, 10:37 AM
  4. Need help with PCS-1 repair stand....
    By bing! in forum Tooltime
    Last Post: 08-07-2012, 09:55 AM
  5. DIY Repair Stand
    By V1GiLaNtE in forum Tooltime
    Last Post: 05-11-2012, 12:10 AM
Members who have read this thread: 12
