Page 2 of 2 FirstFirst 1 2
Results 26 to 49 of 49
  1. #26
    dru
    dru is offline
    A wire bead is very cheap compared to kevlar, however I'd guess the much of the premium is marketing.
    occasional cyclist
  2. #27
    Reputation: J.B. Weld's Avatar
    I've replaced a lot of tubes over the years, maybe 50,000 or more, and never noticed this phenomenon of folding tires being easier to install. As stated above it depends on many factors, and I've seen extremes from either variety of tire.
    Next time you are at a bike shop pick 2 tires of the same make and model- one folding and one wire bead, and feel the rubber. I guarantee you will find that the folding version is a lot more pliable and that the rubber has a different, usually stickier feel. The casing on the wire bead will be much stiffer and feel more like a car tire in comparison. The reason for this is the folding tire uses thinner thread and a tighter weave for its casing and also uses a different rubber compound.
    I'll leave it to the individual as to whether one is better than the other, or if there is a noticeable difference but aside from price I still contend that the main differences are-
    1) weight
    2) casing and rubber compound
  3. #28
    No Stranger to danger....
    Reputation: Tone's's Avatar
    Quote Originally Posted by dru View Post
    Do all folding tyres have Kevlar in them?
    Dont ever let the truth get in the way of a funny story....
  4. #29
    Quote Originally Posted by J.B. Weld View Post
    1) weight
    Cheers JB thanks for the reply mate, very interesting about the compounds.
  5. #30
    dru
    dru is offline
    Quote Originally Posted by Tone's View Post
    I think so. It is one of the few fibres that's stronger than steel.
    Lightest canoe I ever paddled was kevlar; it was pure heaven at ~45 lbs
    occasional cyclist
  6. #31
    Quote Originally Posted by vmps View Post
    The only difference is that the folding ones are a little lighter. And they fold. Oh, and they cost more.
    What he said....
    I got the opportunity to pick us some new OEM take-off 29er 2.1 Prowler SL with wire beads for $15 each. They work every bit as well as the folding bead, set up tubless on CB Cobalt rims and the performance is no different than a folding bead. Have no idea of the weigh more....but don't care either.
    Monte
    Lodging & Guiding for SW Utah Trails
    http://www.vrbo.com/298759
    www.UtahMountainBikingAdventures.com
    MTBR Discounts
  7. #32
    Reputation: Blurr's Avatar
    Dec 2009
    Quote Originally Posted by justin_amador View Post
    folding tire's are a helluvalot easier to change if (when) you get a flat or puncture. For that reason alone, I use strictly folding bead. if you add up the cost of broken tire levers, i think cost-wise it's a wash.
    I have never broken a tire leaver, are you standing on them?
  8. #33
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    There are a few different materials used for folding tires.
    Vectran, Aramid, and a couple of others I can't recall at this very moment.
    They all perform pretty much the same for that application.
    Magura
  9. #34
    ****** to the dirt
    Reputation: deke505's Avatar
    Quote Originally Posted by monzie View Post
    I run wire beads because in a pinch I can remove the bead and use it to beat the bejesus out of someone. Can't get that with Kevlar.
    no but you could use the whole tire, since it is lighter.
  10. #35
    Dec 2009
    Kevlar degrades in Sunlight, does anyone know how long the Kevlar is good for in a tire?
  11. #36
    so if im reading between the lines, there is no real point in using wire bead tyres, and i can stop buying them thinking they are stronger, when really they are only putting extra weight on my bike....
  12. #37
    Huckin' trails
    Reputation: David C's Avatar
    Well they are cheaper... And same results beside the weight saving... I'd rather paid $15 for a aramid bead tire than $30 for a folding and bear the added 100-200gr since at some point I'm not racing and I just ride for the god damn sake of riding a bike. And that I can take that extra $15 to buy blingy totally useless parts
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  13. #38
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by David C View Post
    An Aramid bead tire is a folding bead tire. Read my earlier link and you will see that the bead material alone accounts for just around a 30g weight difference.
    mtbtires.com
  14. #39
    Dec 1998
    You need to look at the other specs of the tires. Usually there are more differences than just the bead material.
    mtbtires.com
  15. #40
    Oct 2010
    I just switched from years of using standard Wire tires to Folded and I'm really impressed! My first set of Folded tires was Maxxis Holly Rollers and have since changed them out for a set of Crossmarks. I'm riding a 35lb bike and the first thing I noticed was the weight reduction in the rotating mass. The ride quality was significantly smoother both on and offroad. I'm 273 lbs (down from 276~) and they handle my weight and abuse just fine...includind drops, jumps, and roots. I had one flatt due to a nail but changing the flatt and or tire set felt way easier than dealing with my old wire sets.
    Over all, I've put close to 200 miles on Folded tires and have enjoyed every mile. I feel that even with only a few miles that I can recommend Folded tires and not mislead or misinform anyone. I'm personally hooked on Folded tires and will continue using them.
  16. #41
    I have some 10 year old kevlar bead tires (Panaracer Smokes) that would still work fine.
    Wire bead is cheaper, but that is about all the advantage I can see in it, nothin' more...
  17. #42
    Is not amused
    Reputation: Hutch3637's Avatar
    Tone's if your looking to get into folding tires, don't want to break the bank but, still have a good tire look into CSTtires.
    CST Mountain
  18. #43
    Jun 2013
    Quote Originally Posted by 50calray View Post
    Jun 2013
    How do I tell if I have wire or folding? IRC PiranhaPro 26” x 2.10 tires here (IRC's came stock on my 1996 Cannondale)
    How much weight savings for both tires are we talking here?
  20. #45
    Quote Originally Posted by Cannondale M200se View Post
    Folding tyres are collapsable, meaning you can fold then up in your hands, wire tyres hold their shape, you cant fold them up, if already on your bike, google the brand and model and see what you come up with.
  21. #46
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I'm going to have to apply more than double the force to get the same percent stretch to get the bead over the major diameter of the wheel for a steel bead vs. an aramid bead.
    Except that the bead doesn't stretch regardless if it's aramid or wire. We work the bead to the center of the wheel where the diameter is smaller, so the bead can be worked over the sides of the rim.
    Oh, and regarding this Kevlar vs. aramid thing, Kevlar is just one brand name for a certain aramid fiber. It's just become so commonplace that people call aramid kevlar and vice versa.
  22. #47
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Mr.Magura View Post
    Magura
    Vectran isn't used in the bead. It's used in the casing. Sometimes just under the tread, but other times it covers the sidewalls, too. Depends on the tire. Vectran was used in the Mars lander airbags, FWIW, and is what my Ursack bear bag is made of.
    Quote Originally Posted by Blurr View Post
    Kevlar is not exposed to sunlight when it is used in a tire bead. I do not know of any tire companies that put it in the casing, but if they did, it would still be encased in rubber and not exposed to the sunlight until the tire was worn out and in need of replacing, anyway.
    I've been using pretty much exclusively folding tires for the past several years. Never had a problem with the bead, and I appreciate the lighter weight. Only exception would be my commuter. Bought some steel bead tires for it because I couldn't find folders in the size/tread pattern I wanted.
  23. #48
    High Desert MTBer
    Reputation: rockerc's Avatar
    If we're going to avoid generalizing (like i initially did), it'd be cool to see statistics on the quantifiable aspects of tire seating (mean and std. deviation of percent stretch required for specific tire/wheel combos, tire durometer, bead elastic modulus, etc . . .). For instance, Dupont Tensile Modulus is 70.3 GPa (according to Matweb.com for DuPont Kevlar 29 Aramid Fiber) vs. 303 Annealed Stainless Steels Elastic Modulus of 193 GPa. I have no idea if these are the exact materials that are used for tire beads but, lets assume that they are at least in the same family and use them as a starting point. That means, all things being equal (bead diameter, percent stretch, etc . . .), I'm going to have to apply more than double the force to get the same percent stretch to get the bead over the major diameter of the wheel for a steel bead vs. an aramid bead.
    Obviously, all things aren't equal, which is why it would be cool to see a set of data for at least some relevant characteristics. A sample size of one won't cut it since we have no idea what tolerances tire and wheel mfgs allow.
    So yeah, wheel geometry, tire geometry, bead material properties, tire surface properties . . . all that stuff will play a role in ease of seating beads.
    Sheesh! I can see Justin now, sitting at his desk with reams of data, working out which tire is gonna work best on whatever rim, crunching numbers until eureka! Then he finds that particular model has gone out of stock while he was working it out... No offense intended Justin, but crunching all that data seems a bit of a stretch, when the best stretch might be to get out and stretch a few tires over some rims to see...
    Tone's, for me it all comes down to money and weight, and whether the sidewalls will hold up in the razor sharp decomposed granite where I live... I have tried many different tires on my Mavic Crossmax and Crosstrails, and the only thing I know is that some tires are easier to put on than others, and some tear like damp tissue in a blender... The ones I have on at the moment are usually the best.
    It's all Here. Now.
  24. #49
    TiGeo,
    Agreed.
    I'm over 200lbs. Weight delta is minimal
    Run Big Bettys on SC BLT
    Folding about 100 bucks
    Wire 30 bucks via Amazon.
    Been ridin MTB over 35 yrs.
    Marketing trumps funtion sometimes.
    Former geologist as well.
