Results 1 to 34 of 34
    Reputation: peteer01's Avatar
    Apr 2005
    Why aren't titanium seatposts more popular?
    Why aren't titanium seatposts more popular? They're light and strong. I don't feel comfortable using my quick release to adjust my carbon fiber seatpost while riding, but I would if I had a titanium seatpost. I just built a new bike I'm very happy with that has a cheap seatpost while I figure out if I want a Ti seatpost, carbon seatpost or dropper (which I don't think I do). I'm posting to see if there's something I don't know. Some performance reason titanium seatposts aren't more popular that I'm not yet aware of.
    2014 Horsethief, 2013 Karakoram, NB-AT3, <strike>2006 Giant XtC</strike>
    Cost. I use a Moots setback. Great post.
    Reputation: juan_speeder's Avatar
    Most folks that would spend $250+ on a seatpost would get a dropper, and many wouldn't spend that much.
    Ti posts are great though. I had a Syncos back in the day. It made me feel like I was running 10 psi in my rear tire.
    Edit: Is this for a full suspension bike? I was thinking hardtail. Not worth it on a dually, imo
    Scarlett Johansson loves my hummus.
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Just get a Thomson masterpiece post and do it right.
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Why aren't titanium seatposts more popular?
    Quote Originally Posted by Raleighguy29 View Post
    Thomsons are the harshest riding posts I have used, slip more than most, and the Masterpiece is too short for most of my bikes.
    mtbtires.com
    Apr 2005
    Quote Originally Posted by shiggy View Post
    shiggy,
    I have a carbon post on my HT I like, but this is for my trail bike. I built it with a $10 seatpost while I figured out what seatpost I want.
    Considering this is for a full suspension bike with large tubeless tires, would the harshness of the Thompson still be a concern for you? As for slippage, are you saying that the slip under proper torque, or do you just have to tighten more than the average aluminum seatpost?
    Definitely appreciate any feedback you'd have, good or bad, and value your experience and opinion.
    Dec 1998
    Quote Originally Posted by peteer01 View Post
    shiggy,
    I have had Thomson posts slip on some frames no matter what I did. Swap for a different post(s) and it never moves.
    I would be OK with a "harsh" post on a fully, but there are plenty of good reasonably light posts for much less money.
    mtbtires.com
    Apr 2005
    One of those is what I'm hoping to find. I was assuming that a titanium seatpost would be the right way to go light without the risks/limitation that come with fiber, but I'm not set on a specific material.
    Are the light, quality posts you're talking about primarily aluminum alloys, titanium or carbon? Any recommendations based on a full suspension that would need a 31.6 350mm+ seatpost? (350mm would be fine, but I'm using a 400mm right now.)
    I'm not opposed to spending up to $150. The Masterpiece is rated for XC riding, and this is a trail bike. I don't necessarily care about the amount flex, but I don't want to experience slippage, catastrophic failure, and if there is a failure of sorts, I'd like to be able to have it taken care of under warranty. I also don't want to have to regrease a seatpost every three months, as with my current seatposts, I want to set them and forget them. And, of course, something reasonably lightweight. I don't think I'm asking to much.
    Reputation: Dr.Zoidberg's Avatar
    RE: Why aren't titanium seatposts more popular?
    I used a Thomson masterpiece in my fs rail/AM bike for years with the occasional dh duty. On a fs bike i dont think there is a person on the planet that could feel 'harshness' from a seatpost alone all other things being equal. Throw on tubeless amd forget about it. Never had a slippage problem. If you experience this use a little friction paste.
    Re: titanium when i was building my bike they were just too expensive for the weight and strength IMO. If money is no object then that might be a different story for you.
    Sent from my Lumia 920 using Board Express
    Dec 1998
    Quote Originally Posted by Dr.Zoidberg View Post
    I can and do feel the difference. Had a Thompson on my gravel bike and was being beaten up on fast washboard sections.
    Changed to a cheap carbon post--only the post was different--and the bike smoothed out on the same routes. This with just 13cm of exposed post. Same tires/pressures. Same wheels. Same bar/stem. Same saddle. Same rider. Same everything except the post.
    The Thomson posts that slipped, slipped no matter what. Friction paste, more grease, no grease, super tight clamp, shims, different clamps. Still slipped. Always.
    Change the post. No problems. None. Period. Done.
    mtbtires.com
    Interesting, although a couple of things: they were during different runs and probably different lines. Also you knew of the switch so it wasn't blind, there may be a placebo going on there especially if you are looking for it. It sounds like you could very well,feel the difference but at the same time there is was still a chance that something else was going on.
    I now have two Thomson masterpiece seatposts on two different bikes and neither slip at all. After many years (well, i guess only two full seasons for the second one). I guess the old YMMV definitely applies here.
    Dec 1998
    The ride difference was not subtle. Far from it. This was not just a short test ride but over many 5+ hour trips. The kind where you forget about what you are riding.
    mtbtires.com
    Apr 2005
    I was specifically looking at Carver Bikes (Ti Seatpost).
    With the right coupon code, that would be possible for less than $150. I know it's not as light as the Thompson Masterpiece, but if it were rock solid, durable, reasonably light, and would ride better than the Masterpiece, I wasn't opposed to waiting for a sale and potentially upgrading to something like that when the price is right.
    Evolutionsverlierer
    Reputation: acer66's Avatar
    Oct 2010
    Never had my Thomson seat post slip, despite the heavily applied grease.
    Contains no juice.
    Nov 2003
    Quote Originally Posted by acer66 View Post
    Yeah, same here.
    Is my paycheck just a bribe to forget my dreams?
    Yup, but you have to compare apples to apples. Thomson MP go for less than msrp. I recall last month it was $112 shipped to US from CRC. Sometimes they go for less,on ebay and every now and then you can find a v.good price on pinkbike. But less than $150 for a titanium post is a good price too. It comes down to what you are after. And just b/c someone else experienced an issue with a seatpost doesn't mean you will either. Or just b/c someone else didnt experience an issue it doesn't mean you wont either. With either seatpost there is enough demand to resell them if you do experience an issue or doesn't meet your expectations.
    Apr 2005
    Quote Originally Posted by Finch Platte View Post
    Yeah, same here.
    Are all three of you talking about Thomson Masterpiece seatposts? (I know Dr. Zoidberg is)
    Also, do any of you adjust your seatpost mid ride with a quick release seatpost clamp?
    I normally don't adjust mid ride, but if I'm on a long ride with extended up followed by extended down (or vice-versa), I'd like to be able to adjust the seatpost a bit accordingly mid ride and not worry about excessive torque or slippage.
    wannabee
    Reputation: giantbikeboy's Avatar
    Dec 2004
    I ride Thomson on all my bikes, slipping is never an issue.
    Ti posts are neither cheap, nor particularly light.
    For similar money you can save 50-100 grams going with a decent carbon post, and won't suffer much in terms of comfort.
    2015 Scott Foil Team Issue
    2015 Kona Process 111
    2015 Salsa Mukluk 2
    I am employed by a bike shop.
    Not me.
    Apr 2005
    Quote Originally Posted by PolishExperiment View Post
    I agree I can save some weight going carbon instead of Ti, but I wouldn't be comfortable using a carbon seatpost with a seat clamp that I'm adjusting mid-ride. I would feel comfortable doing that with an aluminum or titanium seatpost, which is why I'd prefer to not go carbon for this particular bike.
    Evolutionsverlierer
    Oct 2010
    Yes on both counts
    I've had the same Dean titanium seat post for 22 years and its on my hard tail, it's like another poster said like you rear tire has 10 psi, smooth and supple, a very good choice for a hard tail.
    Ride Instigator
    Reputation: Ricko's Avatar
    There are Thomson posts and there are all those other posts...Thomson doesn't make a ti post so I have no reason to own one.
    I love Pisgah
    Reputation: Duckman's Avatar
    I have 7 Thomson posts in service currently. All being Masterpiece except 1 Elite(its been in service since 02). Never ever ever had a Thomson slip. I have had an Alien carbon slip sometimes in a Giant roadie using the oem rubber sleeve. Been several yrs since that happened tho.
    Strangely I've never bought a Thomson. All the Masterpieces were acquired from racing results swag, via those free Thomson product gift thingies. The Masterpiece post was a no brainer regarding the choice of "one free Thomson item". Super light. Handsome looking. Strong. No slip. Easy to use saddle clamp. Awesome post. The Elite came on a used bike way back then. Still works and looks new-ish.
    The only other post I like as much or even more is the Extralite UL The Post. Slightly lighter, oem ti clamp bolts, and super well made. Alas, its crazy expensive and very hard to get. Hence why I only have one of those.
    The end
    "I've breathed the mtn air, man" Johnny Cash
    It's a long way to the top
    . . . if you wanna rock and roll (ac/dc)
    Another benefit to the ti is wrenching on your bike while clamped to the post in your stand.
    J L Titanium Seatpost 31 6mm 27 2mm for Road Mountain MTB XC DH Fr Bike TI | eBay
    I like turtles
    Reputation: TiGeo's Avatar
    Because for the price you can get a carbon fiber one that flexes more i.e. Niner RDO.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Quote Originally Posted by eb1888 View Post
    B/c that can't be done with an aluminum post?
    Oct 2012
    I have a question out here: Why people spend a fortune on carbon/ti seatposts besides the weight saving? I have Alu seatpost on my trail bike (only bike) that i abuse for DH and never ever had felt any flex in my seatpost even when it's pulled out (tall). And also never had slip problem and i use quick-release clamp.
    I like turtles
    For FS, I simply don't see the need for fancy seat posts. However, for a HT, a flexible high-quality seat post can improve the ride quality immensely and tha tis why I dropped $200 on my Niner RDO post..best money I spent on my bike....its always about what kind of bike/how the bike is used in these discussions.
    We're talking carbon or ti posts. The guy I bought my stand from sold it only because he had a carbon post and was no longer comfortable clamping it with the stand. Aluminum no problem but no damping either.
    Sorry. Thomson MP being an aluminum post came up a bunch of times so I thought it was also valid. I'd put it this way: Rather than clamping being a TI benefit, not clamping is a carbon con.
    Jan 2014
    I'll stick with my Thomson masterpiece on my hard tail and Thomson dropper on the squishy bike.
    Rocks belong
    Quote Originally Posted by acetechm3 View Post
    Ha! I've got my 2002 DEAN 27.2 Ti post on my 29er CX/commuter bike now! haven't owned a 27.2 MTB frame for a while, but it works great on a fully rigid 29er commuter bike!
    I like 'em long, low, slack and playful
  1. It's Saturday ... why aren't you riding?
    By ancient rascal in forum California - Norcal
    Last Post: 03-24-2014, 08:28 PM
  2. Road bikers aren't so bad
    By Woodman in forum North & South Carolina
    Last Post: 12-31-2013, 08:14 AM
  3. Looking for cape riders..(aren't we all?)
    By SuperbMan in forum Massachusetts
    Last Post: 10-06-2013, 12:03 PM
  4. Chromoly Vs Titanium: Seatposts, Handlebars, Stems ?
    By phoenixbikes in forum Vintage, Retro, Classic
    Last Post: 08-09-2013, 01:11 AM
  5. We have Dh'ers, so aren't there Uh'ers?
    By Enzoblue in forum California - Norcal
    Last Post: 07-08-2013, 08:26 AM
