Results 1 to 2 of 2
    who's using cateye v2c, v3 or strada double wireless?
    The sensor for cadence and speed come together and is suppose to be mounted on the chain stay of the non driveside. But do you just simply tie a cable tie or do you put a double sided tape below it? If i put double sided tape, will there be problem removing? I'm using it on a xc bike anyway. Thanks.
    i also unicycle
    zip ties are all that should be required. i've never seen one slip around unless it was actually bumped, not just jarred going down the trail. i've sold and installed tons of these over the last year or so. that said unless you use some sort of super powerful tape, i bet there'd be no problems removing it either.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
