    Reputation: radials's Avatar
    Jan 2009
    White Lightning Easy Clean...
    MAN! This stuff works great and make cleaning components a breeze, but is there an alternative, equivalent?
    One can can get you two, maybe three cleans (6 oz. can), and it gets kind of expensive after a while if you clean your bike often...
    Does anyone have any suggestions?
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Stuff works great, I gave up on it due to the cost though. Someone mentioned that it can penetrate into certain bearings and cause problems as well.
    The alternative? I'd guess ether (starting fluid).
    "...like sex with the trail." - Boe
    Jan 2009
    Quote Originally Posted by stumblemumble View Post
    I know...$6 a pop for two cleans is pretty high when you ride in the dusty-desert and require cleanings every other ride...
    So starting fluid, huh? Would that be alright to spray in hydraulic brake levers and shifter levers?
    nocturnal oblivion
    Mar 2006
    Quote Originally Posted by radials View Post
    I've never tried so your guess is as good as mine. The ingredients on the starter fluid bottle I have are: ether, heptane, propane, butane, and CO2. Nothing in it suggests it'd be damaging.
  1. White Lightning Easy Clean
    By TheDoc46 in forum General Discussion
    Last Post: 05-24-2011, 07:02 PM
  2. Replies: 26
    Last Post: 07-22-2009, 09:23 AM
  3. White Lightning
    By danyiluska in forum General Discussion
    Last Post: 10-27-2006, 04:04 PM
  4. My new M1, White lightning!
    By heather@thebakkers.com in forum Intense
    Last Post: 03-30-2006, 12:11 AM
  5. White Lightning?
    By dshighway in forum Tooltime
    Last Post: 02-24-2006, 01:16 PM
