Where to get SRAM Bassworm?? X-post from E.D.
Hey all,
I have a lazy-ass rear deraileur (shimano LX). I am 99% sure my sluggish up shifting is due to a weak spring. Anyone know where I can get a SRAM Bassworm on-line? Preferably a Canadian dealer (as there will be no mystery customs charges)? But I'd look into getting one from the US if it wasn't going to cost more than a new derailleur.
Or any other solutions to a weak springed deraileur??
Any help would be much appreciated
I used to use one back in the day, almost 10 years ago now. I still have it kicking around somewhere. Really though it's not worth the effort. i'd go for a new derailluer if your's is shot.
I have a new Bassworm you are welcome to; I'll check back.
I would first service your derailleur by removing it, flushing the springs with WD-40 while you work the pivots, and then drip in a Teflon lube.
Good shifting is such a necessity I would address it at the root cause as suggested in the post above.
 Originally Posted by chomp
Hey all,
You've probably already ruled this out, but your cables aren't old and gunked up are they?
Thanks for the responses...
I found out yesterday that SRAM doesn't make them any longer and it was kind of a rinky dink thing that sorta worked. I guess my $ are better spent on a new deraileur when this one is really done.
I also cleaned everything up quite well, it must the the spring. I noticed the spring is a lot lighter duty on the LX than the XT I have on another bike.
Thanks for offering up the Bassworm too, but like I say, may as well just buy a new der.
By chomp in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 08-18-2004, 09:47 AM
By Steve5S in forum Turner
Last Post: 06-18-2004, 05:48 PM
By DIRT BOY in forum General Discussion
Last Post: 06-09-2004, 10:36 AM
By wi1trackrider in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 03-28-2004, 06:16 PM
By CraigH in forum Downhill - Freeride
Last Post: 01-29-2004, 06:56 PM
- You may not post replies
- You may not edit your posts
Forum Rules
