Results 1 to 14 of 14
    What to use to plug ends of Monkey Lite XC bar
    So I have some Race Face Diabolus grips and a '09 Monkey Lite XC (carbon) bar. Problem is, the plug included with Diabolus grips don't fit in the Monkey Lite. The material is too unforgiving to squeeze into the hole. As this is a carbon bar, there is no surprise that the I.D. of the bar is smaller than an aluminum bar.
    With that said, I am sure many here are running the Monkey Lite and ran into the same issue. What did you find to plug the ends? Secondly, why in the heck does Easton not package plugs with the bar to avoid this issue?
    Vaginatarian
    get some ODI lock ons, or one on the several expanding type plugs
    Missouri sucks...
    Trim your current plugs with some kitchen sheers. I had to do it with my Ergon plugs...
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Run bar ends and you won't need plugs.
    Reputation: Vecsus's Avatar
    Seriously? You started this is in the 29er forum?
    Vecsus
    HTFU or STFU
    Reputation: rmasse10's Avatar
    Aug 2010
    Head on over to your LBS and I can pretty much assure you they got a "bucket" of plugs that you can go thru...they are your best bet
    Custom Performance Apparel for the Trails
    Surfmonkey Gear
    PSYCHOLUST
    Reputation: scyule's Avatar
    why do you need plugs?
    I don't use them, most are ugly and they really serve no purpose....... I suppose that out there somewhere is a guy who had a crazy cartwheeling crash and punched a hole in his leg, but really, it's a few grams of plastic you don't need
    Quote Originally Posted by Vecsus
    Seriously a mistake. Got lost somewhere going back between bike and computer. I simple "move to" would have been scolding enough thanks.
    Vaginatarian
    Quote Originally Posted by scyule
    yeah, and when you lay your bike down a crunch up those carbon ends who cares, right?
    Ever had to lean your bike on is side when there is nothing to prop against? Or have the bike tip after you thought you rested it up safely? Ya get a nice big dirt core sample in your bars.
    Not a big deal, it will take some digging out.
    I just think it looks stupid without them. I was worried that another type of plug would be just the same. Still, I don't know why Easton doesn't send them with the bar owing to the fact that this may be an issue with any grip, do to the I.D. of the bar.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Corks
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by wv_bob
    Corks
    This , works great .
    DynoDon
    Reputation: manabiker's Avatar
    I use them under my Oury grips to stop from getting holes in the end of them, there are different sizes for different bars, and if you don't put them small pieces of plastic, you can end up with a few grams of dirt in there, if you want chrome go to the hardware store and try some pipe ends. Or plug them with carrots, candy or something else edible, then you can eat them for a snack..LOL!!
