Results 1 to 12 of 12
    Reputation: nauc's Avatar
    what are these 2 holes for on my GT Avalanche Expert
    thanks
    "2 Wycked"
    Reputation: crazy03's Avatar
    Mar 2011
    Not quite sure what the bottom hole is, but the top hole looks like it's for internal cable routing for the rear derailleur.
    Ahhhh...Ahhhh....it's the hammy, it's the hammy!!
    Reputation: theMeat's Avatar
    For rack mounting?
    Round and round we go
    Reputation: Fix the Spade's Avatar
    Nothing.
    The bottom one is part of the dropout forging, GT have made them like that for years and it's largely aesthetic.
    Top one is where they hold the seat and chain stays together before welding.
    Reputation: Joules's Avatar
    bottom one is decoration, though it looks like they put a vent in there for the chainstay.
    the upper one... my gf's gt has a threaded hole there, which I believe is for a rack. I guess it's possible that was a welding fixture, but the one I'm looking at definitely had a tap through it after welding.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Fix the Spade View Post
    Nothing.
    Yep. Also, welding together two sealed tubes is a bad idea. Heat up the air inside and if there's nowhere for it to expand, you get trouble. Little holes prevent those problems.
    "2 Wycked"
    Mar 2011
    Quote Originally Posted by crazy03 View Post
    I stand corrected.
    alright, thanks
    Reputation: jugdish's Avatar
    Newbs. You got the little hole and the big hole, in between's the taint. If'n you don't know what they're for I can't help ya!
    Gone are the days we stopped to decide,
    Where we should go,
    We just ride...
    Reputation: ghettocop's Avatar
    Thats called the "contaminate your bottom bracket hole". My chainstays are open on the rear ends. My bottom bracket shell has holes leading to said chainstays. If water gets in the rear of the chainstays it travels to and pools in the bb shell.
    Reputation: GrapeNutsRobot's Avatar
    Sep 2004
    I can tell by your rep and rep power that you know what you are talking about.
    The Good Times are Killing me
    "2 Wycked"
    Mar 2011
    Quote Originally Posted by GrapeNutsRobot View Post
    Don't be fooled my friend.
