Results 1 to 10 of 10
    robust, yet smooth
    what lube for floor pump??
    My pump (Topeak Joe Blow) shaft needs to be lubed. Can I use my chain lube (am drawing blank, but it's in a black bottle with a green cap - Finish Line?) or grease or what?
    thanks,
    -capt p
    My Take
    I've used white lithium grease, not sure if thats okay or not, yet the pump still works fine.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    I use Buzz's Slick Honey.
    It's needs grease, not oil (chain or otherwise).
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    'nother vote for Slick Honey.
    Quote Originally Posted by The Squeaky Wheel
    I've used it in my Joe Blow and my high pressure Air Hammer road floor pump for years. A good lubing about once a year will suffice.
    robust, yet smooth
    can I use phil wood's grease?
    Quote Originally Posted by TNC
    ... since I already own it? It's in an aquablue tube.
    -capt p
    Bodhisattva
    Sure. It'll work fine.
    robust, yet smooth
    gratzi, compadre
    gratzi.
    -capt p
    Reputation: bike4miles's Avatar
    I allways used tri flow at the shop and it worked like a charm. Just stay away from dry lubes.
    --Miles Graydon
    7 Year bike Mechanic 5 year MTB, Road, and Cross racer
    Jamis Eclipse (18 Lb. road bike Dura Ace)
    Jamis Nova (21.8Lb. Cross bike Ultegra)
    Devinci Mt. bike (21.5 Lb. hard tail, King, Sram 9.0)
    Dirt Uni (Off road Unicycle, XT cranks, Nokian Gozzaloddi 3.0 tire)
    My Bike Page
    Bodhisattva
    Only problem I see with triflow or silicon or similar lube is that it will run down the shaft and dry out pretty quickly whereas grease will hang around where you need it ultimately leading to less frequent servicing.
    Jabberwocky Jockey
    Reputation: Darkwing Duck's Avatar
    Any grease will work - even Vaseline does fine (actually it's probably the best for the $$).
    Having said that, I just used Slick Honey in mine because it was there.
    Calling out from the Land of the Riding Hillbilly.
    www.vassagocycles.com
    www.ntmba.org
    My Blog
  1. What to lube and with what?
    By eman2 in forum Tooltime
    Last Post: 11-09-2004, 08:00 AM
  2. how to lube nipples?
    By sodade in forum Wheels and Tires
    Last Post: 11-06-2004, 01:42 PM
  3. Chain lube reccommendations.
    By Tillers_Rule in forum General Discussion
    Last Post: 10-18-2004, 08:28 AM
  4. Whats the best chain lube?
    By STUMPJUMPER FSR in forum Specialized
    Last Post: 04-15-2004, 10:36 PM
  5. Newb - Applying chain lube
    By noonievut in forum Eastern Canada
    Last Post: 04-06-2004, 10:09 AM
