Results 1 to 6 of 6
    Reputation: kidhaulinbike's Avatar
    What headset to get for Windsor Cliff 29er
    I have a windsor cliff 29er with the a cane creek vp a42e semi integrated headset. Has anyone upgraded their headset and if so what fits?
    Im hoping the chris king inset works but I have not been able to confirm.
    Please help!
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    That Cane Creek a42e headset is the same one that came with my Access frame. It's a 'zero stack' type also called 'semi-integrated'.
    Looks like the Chris King 1-1/8" InSet model with the 44.0mm I.D. cups should work for you.
    These will also work:
    http://www.canecreek.com/component-h...ype=zero-stack
    http://www.pricepoint.com/detail/191...ck-Headset.htm
    http://www.pricepoint.com/detail/189...ck-Headset.htm
    The FSA Orbit Z will also work:
    http://www.pricepoint.com/detail/202...-Z-Headset.htm
    You are the man.. thanks for the input!
    Ill get either the ck or cc
    Weird but bikes direct said the ck inset wont work but a cane creek zero stack will? huh?
    What's wrong with your current hs?
    Why put a $150 King headset in a $100 frame?
    nothing wrong with it, im all about the bling..lol
    you are right that the headset would be worth more than the frame but I got the frame for pretty much free and got it pc'd a beautiful color.
    ill probably end up not buying the ck until the current cane creek breaks, thanks for bringing me back to reality..lol
