Results 1 to 75 of 75
    What are the Best Grips for XC MTB
    What are the best grips for XC mountain biking? I'm looking to put them on my 2008 Rockhopper Comp 29er.
    Nov 2007
    I like clamp-on grips, like Odi's. Easy to install, easy to take off. Personally, I prefer the thinner grip styles, but I imagine it has a lot to do with hand size and personal preference.
    Nice day for a ride..... Moderator
    Reputation: Bikin' Bric's Avatar
    Sep 2003
    ODI Ruffian are my all time favourite, Sette makes a knock-off version that is available at pricepoint.com
    http://www.odigrips.com/mtb_ruffian_lo.htm
    http://www.setteusa.com/show.php/Parts|Grips|s_type_grips
    hope this helps
    Bikin' Bric's Bike Blog
    2012 Norco CCX3
    2014 Nashbar Fat Bike
    2016 RSD Catalyst 700+
    Bicyclochondriac.
    Quote Originally Posted by KC_Rockhopper_29er
    Do a search (use the advanced search function) and you will get more info then you will care to read. I imagine most people use the same grips for xc, trail, All mountain, racing, and 29ers, maybe even DH and FR.
    I like ODI ruffian lock-ons because I like grips that are thin, firm, and are easily removable/replaceable yet never slip.
    Reputation: wonky57's Avatar
    Reputation: snowdenn's Avatar
    ergons? pricey, but i just got a pair to try out so we will see...
    Fat guy on a bike
    Reputation: Mordy's Avatar
    Oury lock ons. I like race face good n evil too for non lock-on. Unless you have an air compressor, get lock ons
    Mar 2006
    Titec Pork Rinds
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    The ones that fit onto the best fitting set of handlebars. If you any grip on an ill fitting bar, you probably won't have good results.
    BTW, I ODI Ruffians on Azonic Strip bars, 28" WIDE mounted and mounted with a slight downsweep.
    ballbuster
    Reputation: pimpbot's Avatar
    Depends on where you live
    ... but I love those Sefras dual compound grips. THey have a harder rubber core to grip your bars, and a soft rubber outer.
    If you live where it rains a lot, and ride in the wet, get lock ons. I personally kinda hate them because of those alu rings, and hard feeling grip surface, but they come on and off easily, and they will never spin in the wet. I also like to put my hands on the outside ends of the bars, and with that alu ring there it digs into your hands.
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Call me odd but I've always prefered foam grips, other grips are either too hard, leave a sticky residue on my hands or just feel...wrong. Besides foams weigh and cost nothing so that's a plus
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    what not to get is race face good n evil. On the smooth side my had slipped in the summer from sweat, but I rotated them and they worked well. They are heavy though.
    There is not much choice between rotten apples.
    I second the foam grips. Cheap and good
    808+909 = Party Good Time
    Reputation: chumbox's Avatar
    I'm a massive fan of Salsa Pepperjacks.. comfy and look rad!
    Reputation: Bobby12many's Avatar
    Quote Originally Posted by RatchAttack
    hope this helps
    I second the ODI lock-on grips.
    I use the Rogue (slightly thicker) model and love it
    Ride Instigator
    Reputation: Ricko's Avatar
    I'm a fan of the ODI lock-ons as well. I like the Rogue modle grip cuz of the larger diameter.
    I have used Lizard Skins Logo's for years. They just fit right. I also have a pair of Peaty's that I am putting on a build that feel great. Both are lock ons.
    Tactical Wheel Man
    Reputation: Marshal Dillon's Avatar
    ODI Rogue lock-ons are my favorite choice b/c I like larger diameter grips and a softer feel.
    I AM I AM
    Reputation: ducktape's Avatar
    Yeah there has been threads on this in the past, generally there are a lot of ODI fans out there.
    I like the Oury grips (non lock on), they're fat & cushy, but the ends tend to wear through pretty quick (which is fine for XC riding but not for DH racing).
    Reputation: RS VR6's Avatar
    mbtr member
    Reputation: scottzg's Avatar
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Gravity hurts
    Reputation: Kyle88's Avatar
    Quote Originally Posted by snowdenn
    +1
    Depends on your hand size though. Ergons are great for big hands, they're comfortable (easy on the wrists) and when you lay your bike down they won't rip or tear the ends.
    Bicyclochondriac.
    My girlfriend really likes the Ergons I put on her mountain bike.
    Aug 2005
    i like the ergons too. they really help put your hand in the right position for dual control. plus, even without a barend, they allow you to grip the ends during climbs. that being said, i also like the Gn'E for non locks, because they are narrow and tough, but they do get slick after being sweat on. gloves help a lot. probably not so good for xc.
    I like the Ergons but they are pricey. I'm running a set of lock on Ourys right now and they're awesome. Performance has a lock on grip that's nice too, but they're a bit skinny for me.
    What does everyone say 5 years later...
    Bicyclochondriac.
    Quote Originally Posted by Canyon93108 View Post
    Nothing's changed on my end
    Rabid Lana fan
    "Time for new grips."
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Reputation: mnyquist's Avatar
    ESI Chunky! Cheap, light and comfortable.
    Reputation: Lupob6's Avatar
    Odi Troy lee design lock ons
    Dec 2012
    cool
    Quote Originally Posted by scottzg View Post
    +1
    Sent from my DROID BIONIC using Tapatalk 2
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by mnyquist View Post
    +1..........Also they don't twist on the bars, plus they don't get slippery when wet.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Mar 2011
    +1 esi
    Have to agree with the ESI's, you can get chunky, but if you are OCD about weight get the racers edge, I have those grips and they absorb the bumps amazingly, you can go for long rides wearing only really thing XC gloves, and your hands will be fine. These are the best grips you can find.
    2011 Specialized Stump jumper Comp
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    This
    Attached Thumbnails Attached Thumbnails What are the Best Grips for XC MTB-2012-11-09_21-37-48_428.jpg
    Sep 2012
    Ergon GP5 (GC3) for me. Helped a ton in reducing the numbness in my hands. The integrated bar ends are great for climbing too.
    -S
    yukonjak
    The best grips that I have found are the odi x-treme, unless you have problems with your hands going numb on long rides then the ergon ones would be the way to go. Either way lock-ons are really nice and the only way to go IMO.
    Never had a problem with my hands going numb and still love Ergon's...also like the fact that i can wear any non padded glove.
    Reputation: dirtdan's Avatar
    I prefer Oury...
    Dec 2010
    Specialized Sip locking grips are my favorites now. I'm a big fan of locking grips, more for the ease of installation and removal than them never shifting on the bar. I used to ride dirtbikes a lot and really liked the half waffle design. The Sip's are the first half waffle locking grips I've used on my mountain bikes and they've quickly become my favorites. They last a long time too.
    Reputation: SeaBass_'s Avatar
    All Ergon for me.
    Quote Originally Posted by sasquatch rides a SS View Post
    Sasquatch you f*cking Rep Whore! 160!
    Reputation: carverboy's Avatar
    Old School Oury
    +1 this with a little wire on them so they can't slip. much cheaper and softer feeling than the lock on version.
    UGG boots will germinate Paris Hilton like intellect in your soles!
    Ridin' Furry
    Reputation: Huskywolf's Avatar
    Feb 2012
    Went with Ergons also. Made the hand pains disappear since it helps keep my wrist straight.
    Sep 2012
    Ergons are the best, hands down.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    With arthritis in my hands Ergons are the bomb.
    I don't rattle.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by 29er4life View Post
    Oh get a grip, put your hands back on the bars.Eekster
    ----------- __o
    --------- _`\<,_
    BRAAP(>)/ (*)
    ************^^^^¯\_(ツ)_/¯
    http://www.youtube.com/watch?v=qqpcBpSsj1A
    Aug 2010
    I've had lizard skins (peaty's and "logos"), specialized "roca"? and some others. I have no special preference as long as they lock-on securely and I'm wearing gloves I can't tell any difference.
    ive got the oury's on one of my bikes,lizard skins on another, great grips. I just recently bought the crank bro's grips and they are nice as well.
    2013 Ibis Mojo HD Special Blend with dropper post, hope/stans wheelset and hope x2/m4 brakes
    Talk to me, Goose.
    Reputation: BatCountry's Avatar
    Jun 2012
    WTB Weirwolf Grips
    They cost next to nothing, stay in place, and have phenomenal grip. My hand numbness went away after purchasing these and getting away from my Cannondale grips..
    We can't stop here, this is bat country..
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    ESI chunky. BEST EVER
    Raised in a Chicken-Coop by Chickens
    Reputation: thickfog's Avatar
    Oct 2010
    Quote Originally Posted by Sheepo5669 View Post
    Yes, yes, yes!
    CRAMBA Chairman
    Reputation: Dereiter's Avatar
    Jan 2013
    I bought them. Nice grips. I recommend you this product.
    I vote for Chunky!
    My garage:
    12 Harley Davidson VRSCDX 10th ANN
    12 Honda CBR 1000 RR Respol
    12 KTM 690 Enduro R
    Reputation: 501Levi's Avatar
    Quote Originally Posted by RS VR6 View Post
    Using the ESI "chunky" grips.
    MTB Grips
    These! light and a low price
    Get on your bike and RIDE
    toscano
    Guest
    It is difficult for me to answer because I have found that grips that are great on a bike do not provide the same feelings on another bike, even if the geometries are similar.
    Various attempts you can do could be expensive and not always expensive is synonymous with comfort and quality.
    Reputation: banditfl's Avatar
    Nov 2012
    Quote Originally Posted by toscano View Post
    Vary will put!! Tried some replacing my old Scott grips with some Nashbar lock-ons, but hands would go numb on longer rides. Now using oury grips, a little thick and move around a little, but very comfortable and a good grip.
    Rod
    Rod is offline
    Oct 2007
    Oury
    Reputation: skellener's Avatar
    Feb 2013
    My favorites...
    Ergon GP2 Grip
    Ergon GP2 Grip Reviews
    Reputation: limba's Avatar
    I like Ritchey WCS foam. They cost nothing, weigh nothing and last forever. If you hate them who cares, they cost <$8. They're worth a try.
    ESI is another popular weight weenie grip.
    Reputation: applehead110's Avatar
    I'm all about ESI grips.
    Ergon Bike
    Reputation: ERGON's Avatar
    Nov 2006
    Thanks to those of you who recommended Ergon to KC_Rockhopper_29er! Beauty of the sport of mtbing, we have lots of decisions when it comes to equipment.
    KC_Rockhopper_29er, if you decided to make an Ergon grip model purchase, I suggest the small size for mtbing regardless of hand size. The small will allow for a better feel on the trail as well as allow for more in-depth hand movement / position changes.
    IMO, the GS1 in Small is the ticket for general xc style riding/racing.
    Jeff K
    Ergon USA
    In dog years, I'm dead.
    Reputation: burtronix's Avatar
    I just scored a great deal on a pair of Ergon GX2 Leichtbau grips. Took them on an initial ride & I need to tweak the position a bit. They felt great, especially for climbing.
    Replaced the stock Giant grips on my Anthem 29er.
    Whatever your hand finds to do, do it with all your might.... (Ecclesiastes 9:10)
    ESI Chunky...
    Reputation: jugdish's Avatar
    Oury
    Gone are the days we stopped to decide,
    Where we should go,
    We just ride...
    Aug 2010
    ESI are awesome. Putting on Ergons or Oury is nearly doubling your handlebar weight. ESI is very comfortable silicon foam that stays in place, absorbes shock, inexpensive and is a cheap way to save 100grams. Thats an easton EC90 handle bar in weight. Have had mine for nearly 2 years and they are still in great condition whereas gummy rubber wears quickly and leaves your hands feeling dirty. So glad I discovered these grips.
    Aug 2013
    Weight aside, Ergons let me stay on my bike longer. I'd rather lose the weight off my ass and save my hands and wrists the wear and tear. They've removed all hand pain and numbness, and offer a variety of different hand positions depending on what version you get. I prefer the version with the shorty 3-finger bar-ends. Takes a bit to get them into the right position, but once they are set up they work really well. I use them on both of my bikes, and they have allowed me to go flat bar on my cx bike and disregard the "more hand positions" argument people make for drop bars. My theory is that you don't need so many hand positions if you can stay in each position longer w/o becoming uncomfortable.
  67. #67
    Reputation: Settertude's Avatar
    Jun 2013
    I like the lock ons that came on my Yeti, but I replaced them with Ergon GP1 Bio Cork small. They work as advertised. My brother likes them so much, I just ordered a pair for him, too. They are amazingly comfortable, numbness gone and they will allow my wrists to ride for a long time to come. Kudos to the designers. They are brilliant!
    I like the idea of the wee bar ends, but I'd have trouble on most of the trails I ride.
  68. #68
    Jun 2012
    Odi rogue lock ons for me.
    I have large hands.
  69. #69
    Aug 2013
    Re: What are the Best Grips for XC MTB
    Quote Originally Posted by Settertude View Post
    I hear ya on the bar ends. The only reason I use them is because I've always had bar ends and feel naked without them regardless of little I realistically use them. I tried it without and it just felt wrong to me. The only time I really use them is longish flat rides just to change things up, the rest of the time they are just the tree hooks that I am used to.
    I also have some Odis and they are nice and fat. I think both are absolute top notch and it comes down to whether you want ergo grips or traditional grips.
    Sent from my Nexus 4 using Tapatalk 2
  70. #70
    Jun 2013
    I hear ya. I still remember back in the 90's when I stopped using bar ends. It felt real strange like something was missing and wrong. I thought my hands would slip off the bars. It turned out OK, though.
    Quote Originally Posted by funky_snowman View Post
  71. #71
    Reputation: phoenixnr's Avatar
    Oury
    On all my bikes
    Sent from my skz_tenderloin using Tapatalk HD
  72. #72
    Reputation: Skeeter97's Avatar
    Feb 2012
    Well this thread motivated me to try something different, so I just ordered a pair of the Ergo GS-1 grips. This will be my first adventure outside of the traditional "whatever came on my bike" round grips. Will report back when Mr. UPS delivers and I get a chance to ride
  73. #73
    Nov 2012
    Quote Originally Posted by phoenixnr View Post
    Oury
    On all my bikes
    I love my Oury grips, but I can't keep them from rotating. Trying ODI Rogue lock-ons for now and so far so good. Not as squishy as the standard Oury grip though.
  74. #74
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Foam here too, cheap and light and comfy. Only downside is they wear out fast. I like the ritchy ones a bit larger.
  75. #75
    Oct 2010
    Esi chunky silicone foam.
    CRAMBA Chairman
