Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
    Water bottles flying out of cages...
    Anyone have any advice for a water bottle / cage combo that stays put when I catch some air or bunny hop a log?
    Before anyone mentions it, I prefer water bottles over camelbaks.
    kp2
    kp2 is offline
    Why don't you just bend the cage in slightly so there's more compression on the waterbottle?
    Reputation: noslogan's Avatar
    ...idios...
    Reputation: SteveUK's Avatar
    Or, if that doesn't work, why don't you just bend the cage in slightly so there's more compression on the waterbottle?
    'scuse me. The sun did shone on my head today...
    What luck for rulers, that men do not think - Adolf Hitler
    The Notorious S.L.O
    Reputation: btadlock's Avatar
    I haven't used a water bottle in 5+ years, but it must be a common problem, as I see many water bottles along the trail.
    I know some poeple use a velco strap around the narrowest point, but that makes it hard to pull a drink out of the bottle w/o stopping.
    But if you are jumping, maybe you are only reaching for a drink when you are stopped.
    BT
    11 Trek Hifi Delux 23in
    05 Giant NRS 22.5in
    Evergreen Co.
    "All I need is.......two wheels and the truth."
    Quote Originally Posted by kp2
    Tried that, tried that and tried that. It's not enough, even if I bend it in so much that I can't get the bottle back in easily.
    I was really hoping someone knew of some sort of latch system, preferably easy to access while riding. Or maybe some sort of positive lock cage and bottle combo.
    Oh well, not too big a deal. Maybe I'll just give in and get a sweatbak, er camelbak.
    For a mountain bike I always lost bottles on metal cages, the cage would just give way eventually. Altho I use a hydration pack now, a couple of my bikes are outfitted with Lockjaw cages which I found the most secure but don't know if they're still made; they held the bottle in with a o-ring reinforced retainer yet was still easy to take the bottle in and out. Some friends swear by their King cages from Boure.
    suum quique
    what brand??
    Quote Originally Posted by Zaph
    I use the water bottle and C-bak as a combo for the long hot rides. I maybe have had six bottles bounce out in 10 years and was able to go back for half. They usually fell out on the rough/rocky downhills.
    You should make a million bucks by designing the device you need.
    Day job:
    Mechanical Engineer
    Reputation: Irrenarzt's Avatar
    The solution is simple. King Ti cage, you'll never lose a bottle again. A classic example of getting what you pay for.
    Nat
    Nat is online now
    Solo contendre
    Reputation: Nat's Avatar
    Loop a thick rubber band around the cage (i.e., double it back through itself) and then slip the other end over the water bottle.
    Reputation: shiggy's Avatar
    Dec 1998
    Cateye BC-100
    Unbreakable and the do not drop bottles. I have been using them for more than 15 years.
    mtbtires.com
    Quote Originally Posted by Irrenarzt
    I second that. I was so impressed I now have 3. Much better than the carbon rubbish I was using before.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    Simple .... Cheap .... Effective .... A rubber band.
    R.
    It is inevitable ...
    ...idios...
    "Simple .... Cheap .... Effective .... A rubber band"
    Do they come in titanium?
    Dec 1998
    Quote Originally Posted by Rainman
    R.
    Drop "A rubber band" and you described the Cateye cage and nothing extra is required.
    mtbtires.com
    Quote Originally Posted by shiggy
    Cateye BC-100Unbreakable and the do not drop bottles. I have been using them for more than 15 years.
    Yup. I bought one and put to the test down a way bumpy rock garden that'll rattle your teeth loose. Bottle stays put. Period. Cheap and light weight too.
    Reviewer/Tester
    My way is cheaper, and works with any existing bottle cage. No need to buy a new one.
    Use an old innertube, cut a few loops off it....presto! a lifetime supply of rubber bands.
    E Z ...
    R.
    Get your freak on!
    Cateye BC-100
    Second (third?) this one! I have one that is over 7 years old and is still doing a great job!.
    It may also be possible that your not using a great bottle... are you using cycling specific bottles? Plenty of good bottles around.. specialized makes some nice ones
    Dec 1998
    E Z ...
    R.
    But how do you get the bottles in and out on the fly?
    mtbtires.com
    Cateye BC-100
    That does look interesting. It seems to have more of a lip sticking out than others. Assuming the indentation on my bottle is in the right place, that should work great. 29 grams and the price is right.
    Until I actually get one in, (I'll just add it into my next online order somewhere) I'll try the rubber band idea.
    Thanks all, good suggestions.
    Dec 1998
    It fits all standard bicycle bottles
    mtbtires.com
    Reviewer/Tester
    Simple... Reach down, flip the rubber band over the top of the bottle, extract same ... drink.
    Reverse process to replace. So E Z.
    R.
    Reputation: ATLien's Avatar
    I suggest the Trek Bat Cages. I am riding with 2 of them, and they work well. They hold very tight, and they will work with most bottles. I just use gatorade sport bottles as my bottles at the moment, and it holds those thin bottles very well.
    -Chris
    [SIZE="1"]Bike and Ride Pictures[/SIZE]
    [SIZE="1"]Do not go where the path may lead, go instead where there is no path and leave a trail.[/SIZE]
    [SIZE="1"]- Ralph Waldo Emerson[/SIZE]
    [SIZE="1"]Home Trail:
    Blanket Creek (Woodstock, GA)
    [/SIZE]
    TejasMtB'er
    King Ti cage. Used since '99, no drops yet. But then I'm not a DH or FR'er.
    Oh yeah I also have a CB.
    Cya - Nathan
    '99 Litespeed Tsali-XT Group,Titec 118 Ti Handlebar,Frogs,Judy SID,KING Ti bottle cage,Salsa Brake Brace&Syncros Ti post. WT=23 pounds. My website has my '00 BMW Z3-2.8L Roadster and '01 Taco D-Cab 4WD truck.
    [SIZE="5"]z3power.net[/SIZE]
    Dec 1998
    R.
    With the Cateye:
    Reach down, extract bottle,
    Drink.
    Replace bottle.
    Even E Z R.
    mtbtires.com
Hot Deals
Contests
Latest Mountain Bike Articles
