What do most people use to hold their bikes while washing them?
I constructed a wood floor stand, so because it is wood and somewhat heavy it does work but now I am into saving floor space in the garage and have individual floor stand.
One is the Willworx stand and I am thinking it will not be stable enough and might start the rusting process if getting soaked on a regular basis. The EZ stand appears to be all PVC but I have not purchased one yet ( in the thinking stages) and wondering how secure the bike will be in this stand during the cleaning process.
Someone must have some good advice for bathing the bike?
I lean it against the wall -- I wash my bikes outside. And then I pour water over it, go over the frame and other non-moving parts with a soapy rag, and then I pour more water over it. There's no need to make it any more complicated or involved than that.
Originally Posted by AZ.MTNS
Please someone explain to me (and others) how to insert a screen captured quote as my sig. line. TIA.
I made my stand myself.
2 horizontal iron galvanized tubes 22mm length 400mm
2 other tubes I bent 135 degrees and welded them across the 2 horizontal ones.
They are a bit less wide than my 2.25 tire and it works perfect.
They hold the tire at 6 o'çlock and 9 o'clock.
All was made in half an hour and works perfect. I'm also using it to store my bike.
It fits 26" and 29" perfect.
I wash my bike on my Park Tool workstand. This winter, I removed (Literally, mean this actually happened!) greater than 4 pounds of mud off of my Pugsley after a ill-advised post-thaw ride.
But I personally never submerge my bike in water such that rusting a stand would be an issue. I use a spray bottle (vinegar/water or windex) and paper towels, or a cotton towel soaked in a small bucket. Never a hose or a drenching. For soap, I found soft hand soap is very mild while still effective on dirt. A very light rinsing with a spray bottle or a towel soaked in clean water will finish everything up nicely.
I think I got the picture, guess I have been over doing it by using the garden hose at a fast and narrow spray, No wonder I would need to bolt the bike down.
Seems like I should be just using a hand held pump sprayer to remove the soapy water.
I normally use the back pack blower to dry the bike and I guess that part is safe.
I keep a single bike metal stand near the hose outside for quick rinses, and in the garage I just put it in the repair stand for more detailed cleaning.
You wash your bike? The only time mine gets "washed" is if i get caught out in the rain and then strap the bike on the roof rack and drive down the highway. But I do drive a Jeep, and a Jeep isnt a Jeep unless its dirty, so i guess im in the same mindset when it comes to my mtn bike..
It's very important to show up for races with a nice, shiny bike. Especially road races. Otherwise, you lose roadie points.
I have one of these. It's held up nicely for a long time, though it doesn't play well with anything that has a wide downtube or large BB shell*. I throw the bike on that and pretty much follow BigRingGrinder's routine.
I've either leaned it against my house, my truck, or a tree, or kept it on my bike rack on the back of my truck, or held it with one hand while spraying it with the hose with the other hand. That part seemed simple enough. What I never thought of, however, is how much of a better idea it is to use a spray bottle or wet towel instead of the hose. Wish I would have thought of that before the rust.
You can find me in the woods -- playing in the dirt and mud -- on my 2013 Trek Mamba -- or in my 1984 Chevrolet K10.
Easy...strap to rear rack and drive to automatic car wash! lol, just jokin'
I gotta admit, these days I don't wash it enough to have given it much thought...when I do wash it's just leaned up against the nearest convenient object that I don't mind getting wet and dirty.
In my younger days (before I had a wife and kids), I used to regularly wash my bike in the shower of my apartment.
If you have any welding experience, I picked up some scrap steel for $5 to make a nice heavy wash stand. For my 29er I used an 8' piece of 3/8" steel and 2 scrap pieces of square tubing (anything heavy will work). Gave it the ole "accidental" bump test and it is almost impossible to knock over. Took 30 minutes to bend the metal and weld it. Sprayed it down with cheap truck bed liner to make sure it was waterproof to avoid rust. Total cost: $12. I'm a newb to the forum, so if by some miracle I attach my photo correctly, it is below!
EDIT: Forgot I can't post pics until I have 10 posts, rendering this post fairly useless.
I send my bike to the local dry cleaners. That way the aluminum frame of my Superlight won't rust.
