Washing your bike?
Printable View
  • 01-28-2013
    rickcin
    Washing your bike?
    What do most people use to hold their bikes while washing them?
    I constructed a wood floor stand, so because it is wood and somewhat heavy it does work but now I am into saving floor space in the garage and have individual floor stand.
    One is the Willworx stand and I am thinking it will not be stable enough and might start the rusting process if getting soaked on a regular basis. The EZ stand appears to be all PVC but I have not purchased one yet ( in the thinking stages) and wondering how secure the bike will be in this stand during the cleaning process.
    Someone must have some good advice for bathing the bike?
  • 01-28-2013
    Bro
    I lean it against the wall -- I wash my bikes outside. And then I pour water over it, go over the frame and other non-moving parts with a soapy rag, and then I pour more water over it. There's no need to make it any more complicated or involved than that.
  • 01-28-2013
    aandegrens
    I made my stand myself.
    2 horizontal iron galvanized tubes 22mm length 400mm
    2 other tubes I bent 135 degrees and welded them across the 2 horizontal ones.
    They are a bit less wide than my 2.25 tire and it works perfect.
    They hold the tire at 6 o'Álock and 9 o'clock.
    All was made in half an hour and works perfect. I'm also using it to store my bike.
    It fits 26" and 29" perfect.
  • 01-28-2013
    Flat Again???
    I wash my bike on my Park Tool workstand. This winter, I removed (Literally, mean this actually happened!) greater than 4 pounds of mud off of my Pugsley after a ill-advised post-thaw ride.
    But I personally never submerge my bike in water such that rusting a stand would be an issue. I use a spray bottle (vinegar/water or windex) and paper towels, or a cotton towel soaked in a small bucket. Never a hose or a drenching. For soap, I found soft hand soap is very mild while still effective on dirt. A very light rinsing with a spray bottle or a towel soaked in clean water will finish everything up nicely.
  • 01-28-2013
    dmtnt
    The garage door. ;)
  • 01-28-2013
    deke505
    I don't wash it, the mud is the only thing holding it together:thumbsup:
  • 01-28-2013
    rickcin
    Washing my ride
    I think I got the picture, guess I have been over doing it by using the garden hose at a fast and narrow spray, No wonder I would need to bolt the bike down.
    Seems like I should be just using a hand held pump sprayer to remove the soapy water.
    I normally use the back pack blower to dry the bike and I guess that part is safe.
    Thanks for all of your input!
  • 01-28-2013
    Mr. Lynch
    I keep a single bike metal stand near the hose outside for quick rinses, and in the garage I just put it in the repair stand for more detailed cleaning.
  • 01-28-2013
    ghettocop
    I wash mine on my roof rack. Then drive down the Freeway for 20 minutes or so to dry it.....Perfect!
  • 01-28-2013
    rickcin
    Very clever, you wash the bike and the car get cleaned & dryer as a result, if I only had a roof rack...!
  • 01-28-2013
    BigRingGrinder
    Bike leaned against garage door.
    Drizzle water from hose (not spray) onto dirty bike.
    Pump sprayer with simple green / water to soap up bike.
    Brush for chain/cogs, rag for frame.
    Dribble rinse.
    Pretty bike again.
  • 01-28-2013
    drj85
    You wash your bike? The only time mine gets "washed" is if i get caught out in the rain and then strap the bike on the roof rack and drive down the highway. But I do drive a Jeep, and a Jeep isnt a Jeep unless its dirty, so i guess im in the same mindset when it comes to my mtn bike..
  • 01-28-2013
    Bro
    It's very important to show up for races with a nice, shiny bike. Especially road races. Otherwise, you lose roadie points. :p
  • 01-29-2013
    deke505
    what does a roadie look like? I am usually in the trails so I don't see them.
  • 01-29-2013
    rickcin
    I hear ya! My bike needs to stay relativly clean since it sits next to me in my Honda Element most of the time, at least in the summer.
    The front tire becomes my armrest as it assumes the position between the front seats.
    ( Console is removable)
  • 01-29-2013
    Love Commander
    I have one of these. It's held up nicely for a long time, though it doesn't play well with anything that has a wide downtube or large BB shell*. I throw the bike on that and pretty much follow BigRingGrinder's routine.
  • 01-29-2013
    Tyler21
    I've either leaned it against my house, my truck, or a tree, or kept it on my bike rack on the back of my truck, or held it with one hand while spraying it with the hose with the other hand. That part seemed simple enough. What I never thought of, however, is how much of a better idea it is to use a spray bottle or wet towel instead of the hose. Wish I would have thought of that before the rust.
  • 01-30-2013
    milenk0
    I use a Topeak LineUp Bike Stand, which works pretty well.
  • 01-30-2013
    rickcin
    Thanks, I will check one out!
  • 01-30-2013
    epic-gamer
    on the ground
  • 01-30-2013
    RollingWanderer
    Easy...strap to rear rack and drive to automatic car wash! lol, just jokin'
    I gotta admit, these days I don't wash it enough to have given it much thought...when I do wash it's just leaned up against the nearest convenient object that I don't mind getting wet and dirty.
    In my younger days (before I had a wife and kids), I used to regularly wash my bike in the shower of my apartment.
    -RW
  • 01-30-2013
    RollTide29er
    If you have any welding experience, I picked up some scrap steel for $5 to make a nice heavy wash stand. For my 29er I used an 8' piece of 3/8" steel and 2 scrap pieces of square tubing (anything heavy will work). Gave it the ole "accidental" bump test and it is almost impossible to knock over. Took 30 minutes to bend the metal and weld it. Sprayed it down with cheap truck bed liner to make sure it was waterproof to avoid rust. Total cost: $12. I'm a newb to the forum, so if by some miracle I attach my photo correctly, it is below!
    EDIT: Forgot I can't post pics until I have 10 posts, rendering this post fairly useless.
  • 01-30-2013
    dirtdan
    Attachment 766792
    The same thing I use to build and work on them. A work stand was one of the best purchases ever. (not better than the Tallboy LTc though)
  • 01-30-2013
    Mr5150
    I send my bike to the local dry cleaners. That way the aluminum frame of my Superlight won't rust.
  • 02-02-2013
    Gered Dunne
    daily riding seems to shake the old dirt right off. ride more!
  • 02-02-2013
    rickcin
    Wish I could, a little too cold here this time of year!
  • 02-02-2013
    DR3
    I hang it from ropes tied to the seat post and handlebars from a hook on the ceiling of my garage. That way I stay warm in the winter. having it suspended like that really makes it easy to get the bike up high enough to get to the 'smart dirt'. Besides, it keeps my garage floor clean too!
  • 02-02-2013
    dirtyjack
    Washing your bike?
    Garage door
  • 02-02-2013
    Mr. Lynch
    Most the time i rinse it off before removing it my hitch rack. then i dry it off inside the garage.
  • 02-02-2013
    Tyler21
    Wouldn't the dirt be falling down onto your garage floor? I'm assuming you put a tarp or something down underneath it?
  • 02-02-2013
    rickcin
    Very nice, I love it! Exactly my taste, Overkill! I do have access to Stella but do not weld, however I work with people who do.
    What do you use for the rods?
  • 02-02-2013
    rickcin
    Sweet!
  • 02-02-2013
    9iron
    Park Tool work stand. Clean, dry bike and stand, lube chain, done.
  • 02-03-2013
    speedracer1993
    doesnt fit in the washing machine
  • 02-10-2013
    3vil
    i normally just lean the bike against the pickup and blast it with the garden hose, it takes some practice though. i have this trick i where i place my thumb over the end of the hose and get an increase in pressure by restricting the exit. it's a pretty revolutionary technique, took me years to master, but works wonders for getting mud of my bike.
  • 02-11-2013
    goodmojo
    i dont wash mine, but my neighbor hooks the seat over a tree branch when he washes his
  • 06-29-2013
    smithjss
    Nice!
