Results 1 to 3 of 3
    Dec 2005
    Using a Fox 36 Van with Crossmax XL disc
    Hi everyone,
    (I've tried searching for answers to this question, however the search function seems to be having a bit of an issue).
    I've got a front wheel Crossmax XL Disc wheelset that I currently run on my Scott MC30 with Fox Talas RL forks (quick release 9mm axle).
    I'd like to run this wheel in the Fox 36 Vans, which have a 20mm axle.
    I've taken the 20mm-9mm reducers out of the front wheel, however there is still a large gap on either side of the hub.
    Are these wheels meant to come with additional parts to allow the 20mm to fit in a 110mm wide, 20mm fork?
    Thanks,
    Pete
    TC3
    TC3 is offline
    Reputation: TC3's Avatar
    You need a pair of spacers/cups, which should be included with your wheelset. If not, that shouldn't be expensive @ LBS
    Dec 2005
    Quote Originally Posted by TC3
    Thanks, I will chase them up.
    Pete
