Results 1 to 2 of 2
    Reputation: Oso M's Avatar
    May 2013
    Used Bike - Baseline Maintenance
    I just got my first mountain bike. A 2011 Trek Paragon.
    I know zilch about mountain bike maintenance...
    It was sold to me on ebay as a nearly new ride that only had a dozen or so outings. The frame is perfect, but the chain was a total mess, the brakes felt spongy and the pads rubbed. So the first thing I did was clean/lube the chain, bled the brakes and installed new pads for good measure. No more rubbing, the pads grab the discs symmetrically, and the brake levers are rock solid.
    i went on a short ride this afternoon and it shifted accurately, and felt great (in my completely limited opinion, it was smooth and it stopped well at least.)
    when I got home I rinsed the mud off the tires, wiped the gears off, and checked the torque on all the bolts...
    But I noticed some play in the headset... I didn't hear any rattles on the ride but if I hold the saddle in one hand and the stem in the other and jerk apart I can feel a little play. I doubt this is normal/correct. But I'm not sure how to resolve it.
    are there any other things I should be looking at. This is my first bike with a shock, and I have no clue how to assess the fork.
    Should I lubricate or grease anything?
    Thanks for your insight.
    Reputation: theMeat's Avatar
    The best way to check headset is to hold front brake and rock front/back. If you feel or hear movement it's too loose. If it doesn't spin freely or have a tight spot it's too tight. I could try and explain it but it'd be much better to watch a vid to see how to adjust. Park tools and youtube has a bunch.
    I wouldn't put a hose to the bike too often and usually wait till the next ride when it's nice and dry and use a soft paint brush or something to brush off the sanctions and maybe more.
    Zinn & the art of mtbing is a popular book with lotsa good info, and of coarse there's always someone here willing to tell you what they think.
    I usually lube my chain and maybe some other pivot point every few rides, and go over the bike for fine tuning and lube everything a few times a year, or when something breaks. It's a good idea to keep wear on the chain to a minimum if you want the rest of the drivetrain to last.
    Dialing in the fork to your weight/sag and riding style is a good idea, as well as getting a bike fit or doing one yourself with online info.
    I'm pretty sure that's an open oil bath fork so changing the oil once a year or so is in order. Have also changed the dampening by changing weight thinner/less, heavier/more, but wouldn't go to far from what's recommended.
    Don't buy any fancy bike lube, it's a waste. The advantages of synthetic oil/lube are just not realized on a bike, but it's much kinder to any rubber or plastic bits so that's not a bad idea.
    I could go on.......I'll leave you with nice bike, good luck
    Round and round we go
  1. Replies: 0
    Last Post: 03-05-2013, 08:58 PM
  2. Fox baseline shorts
    By stygz1 in forum Apparel and Protection
    Last Post: 02-24-2012, 03:33 PM
  3. Bike Maintenance
    By mayberry32 in forum Beginner's Corner
    Last Post: 10-02-2011, 08:08 PM
  4. What to do if a Bike shop damages bike while in for maintenance?
    By Thrasher in forum Colorado - Front Range
    Last Post: 05-16-2011, 03:04 PM
  5. Bike Maintenance Class
    By parsons144 in forum North & South Carolina
    Last Post: 01-12-2011, 01:01 PM
