I just got some new Tune Quick Releases and there is something really disturbing about them. Funny enough I googled for a while but I dont seem to find any issue or concern about that anywhere!?
Due to the concept, the Quick Release lever can be freely moved beyond its "locking point" where it becomes loose again.
Since the lever is amazingly easy to move (even if you pre-set the pressure with the counter screw to the limit where the lever can still close) it does not take much for the lever to bend over into the disc or even if you turn the releases around, into the spokes.
I just wonder what will happen when a branch on the trail hits the lever into the wheel...
Firstly, you have got the lever in the wrong position, direct it pointing back to save it getting caught on something and flipping open while your riding.
Secondly, it shouldnt be loose when you tighten it, if it is throw them in the bin
third, its a very poorly designed lever, its long, thin and straight.
Most levers have a slight bend in them to hug your shock, ive never seen a lever designed like that, its an accident waiting to happen
Ive had about 10 sets of skewers and none could get into my disks no matter what i did.
not only that it doesnt have a flat surface to get nice easy leverage from, its a ridiculous and dangerous design.
Just so you can see about 100 real skewer designs, go to chain reaction cycles website, and find skewers, have a look how propper ones are made, i can guarentee you will not see one that looks like that.
out of interest, what brand are they and where did you get them?
Take them off and throw them in the bin, or return them for a refund and tell the place you got them from to get serious and sell some real skewers.
cheers
PARRAMATTA EELS R.L.C Life member- BLUE AND GOLD NEVER FOLDS..
'Lifes not about winning or losing, lifes about choosing'
I probably should not have posted this in a non Europe centric forum it seems because I just realized that those products are not available outside Europe.
Those are TUNE products. (Cant post a URL since my post count is below 10) Tune is pretty much the Chris King of Germany, quite legendary and those did get remarkable results in tests in several publications which is why I am so surprised about that. Those are pretty light 37g Titanium QRs which appear to be hand made and durable with lifetime warranty. They are 110 USD retail.
I probably should not have posted this in non Europe centric forum it seems because I just realized that those products are not available outside Europe.
$110 US That will do me...
Well it did me... and they are **** or maybe I am to stupid to use QRs...
No mate its not you, its the very poor design of that lever.
In all reality you can buy a nice set of skewers for 20 -30 bucks, the hope sets, even halo, these both come in heaps of nice ano colours, send them back and save your money..
if you really want to keep them put them in their proper position facing backwards, but just order a 30 buck pair, they will be as good a quality as those, your paying for the name with those for sure.
Crank bros make a nice set, as do hope, so check those out, i just bought some halos last week for 13 bucks, they look slick and have never failed me in years of dirt jumpin, i just bought a new pair for the colour, nothing more, and for 13 bucks its nothin.
cheeers
you can find a better design on ebay from china. Spend 10-20bucks and get new skewers.
The few sets I've weighed were 27-34g for the Ti set. So, lighter than tune...and alot cheaper.
id just point them so the lever just hits the fork leg.
They don't lock then.
I've had the "pleasure" of playing around with the Tune QR's, and they sure are a poor design.
The way they're made, you can't point them backwards either.
It's a roadie product at best, and an overpriced one.
As somebody else wrote, Shimano makes outstanding QR's.
They don't offer much bling effect, but they're strong and they work.
I did some digging over at mtb-news.de and while it seems they are a little tricky to set up,
they work once you got them dialed in.
Keep in mind Tune products are for weight weenies so they might flex more but the jury seems to be still out for that.
If I understand that right they also have a left and right
and I hope that not every qr's has a left and right since that would be quite embarrassing.
Just a thought... have you tried flipping the QR so the lever is on the opposite side of the disk? Example below... btw the QR in the pic is a Tune DC17.
Agree with everyone else though, looks to be a poor design. If you want light and don't care about price look at the DT Swiss RWS Ti if your a weight weenie or just save money and get a Shimano QR.
Can I be honest with you? I am bad news. I'm not your friend, I'm not gonna help you, I'm gonna break you. Any questions?
If you take a closer look at the pic the OP posted, you'll see that the version you posted a pic of, is a lot different.
Just played around with them a little. Turning them seems to work as the lever is now almost to short to get into the spokes. However there is still a possibility in case it bends substantially.
this issue you're posting about is probably the exact reason they aren't available in the US.
+1 on buying better skewers
Originally Posted by shawnt2012
...the other two morons are bellowing like wookies in a bush waiting for a response back
OP obviously you are unhappy with the performance of those skewers but you like the look. I would reccomend checking out Hope. They have made a skewer with similar looks for years. So they are top notch quality time tested skewers.
Check them out... hope skewers - Google Search
29'ers should come with a warning label affixed to the toptube. WARNING: Objects may be further than they appear.
As you describe it, it sounds like they don't have a stop, so than can loosen in either direction, that's bad.
Send them back to wherever they came from and use Shimano skewers if you like the way internal cam designs look. They're the best anyway, XTR is light and the Deore ones are cheap, pick one and never worry about a loose skewer again.
