    Tubeless & Rim Tape
    What is the purpose of the Stan's notubes tape in a tubeless setup? Is it necessary to use the tape on tubeless ready rims? If so, then why are are the rims called "tubeless ready" and how are they different from rims that are not?
    Jesus
    Re: Tubeless & Rim Tape
    Tubeless ready generally means there are sme small cheap steps t make to go tubeless. I.e. rim tape, rim strip, etc, to cover the spoke holes and make them air tight.
    Tubeless rims don't need any tape. There are no spoke holes. So no need for tape. I.e. mavic UST rims and most shimano Tubeless stuff.
    http://Theclydeblog.org Big guy cycling product tester
    But there must be some difference between "tubeless ready" and "standard/other" rims? Because if "tubeless ready" needs tape than I don't see any advantage with respect to rims that are not airtight because of spoke holes. After all, Stan's tape is supposed to work even on rims with holes.
    Reputation: shiggy's Avatar
    Dec 1998
    Tubeless & Rim Tape
    Quote Originally Posted by jarango View Post
    Mostly semantics. The best tubeless/tubeless ready rims are UST compatible. The inner bead shape matches the bead shape of UST compatible tires for an airtight seal and retention. Many UST spec rims do need tape to seal the spoke holes.
    Notubes rims are not UST spec and Notubes tape and rim strips do not make standard rims UST spec either.
    mtbtires.com
  1. Gorilla Tape Tubeless
    By in the trees in forum Wheels and Tires
    Last Post: 11-14-2012, 08:47 AM
  2. Tubeless rim tape confusion
    By dhelm72 in forum Wheels and Tires
    Last Post: 11-11-2012, 06:19 PM
  3. 100 mm Tubeless tape GroupBuy
    By MasterOMayhem in forum Fat bikes
    Last Post: 03-06-2012, 06:04 AM
  4. Stans Tape. Tubeless tape. Info needed.
    By MasterOMayhem in forum Wheels and Tires
    Last Post: 03-01-2012, 12:55 PM
  5. Tubeless tape not sealing
    By Drea in forum Wheels and Tires
    Last Post: 09-10-2011, 12:11 AM
