Results 1 to 32 of 32
    I like to ride my bike.
    Reputation: RideFaster's Avatar
    Dec 2004
    Try Platypus and Ditch Your Camelbak
    I was getting really sick drinking from my Camelbak bladder. I used their cleaning tablets, took the water out post ride and put the bladder in the freezer...still tasted gross and got me sick for a few days after rides. I would always have a bad headache (yes, I was drinking plenty despite the gross taste) after the ride.
    My Camelbak bite valve was easily caught on my seat when leaning back and would rip off, loosing 1/4 of my water before getting it back on.
    So, a fellow rider in my group has a Platypus reservoir, I was curious and I had to try something to replace the C-bak. I am so, so, SO GLAD I GOT A PLATY!!!! It is mind-blowing how much better it is than the C-Bak bladder / reservoir. I've been lazy and left old water in there, I no longer have to put it in the freezer and still, the water tastes CLEAN and like water! I am no longer sick, no longer have headaches and the bite valve doesn't rip off.
    I do definitely like the bite valve better (doesn't leak, easier to get more water w/less bite, etc.)
    A couple other things too.
    ...and no, I don't work for Platy.
    http://www.platy.com/
    I like the actual Camelbak packs, but their reservoirs aren't so good.
    I like bicycles. Bicycles make me happy. Riding them makes me even happier.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    MEDBLKANOSCBLT2RP23
    Reputation: pakdoc's Avatar
    Dec 2005
    Found old Hydropak's worked well too but got a new Deuter and been using NUUN tablets. The fit, ventilation and bladder seems noticably better than my MULE.
    RTR
    Reputation: slowrider's Avatar
    Nasty!
    I use to put sports addatives in my reseviors but I too got tired of the resulting science projects so I quit using anything other than water and solved the problem.
    I did however puncture my Camelback resevior and found replacements by Nalgene; I haven't tested it by adding anything to the water but they claim that the materials used are anti bacterial; and there actually cheeper than Camelback.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by RideFaster
    So, a fellow rider in my group had a Platypus reservoir, I was curious and I had to try something to replace the C-bak. I am so, so, SO GLAD I GOT A PLATY!!!! It is mind-blowing how much better it is than the C-Bak bladder / reservoir. I've been lazy and left old water in there, I no longer have to put it in the freezer and still, the water tastes CLEAN and like water! I am no longer sick, no longer have headaches and the bite valve doesn't rip off.
    I also like the bite valve better (doesn't leak, easier to get more water w/less bite, etc.)
    I agree about the Platypus bladders. Very nice, lots of size choices and reasonable prices.
    Do not agree about Camelbak packs. I much prefer Wingnut packs. Better fit, more stable and more comfortable.
    mtbtires.com
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    Been using the same Platy bladder for 13 years with no complaints. I did, however, put a Camelback bite valve on the hose because the first generation Platy valve was not so good.
    Reputation: Glynis27's Avatar
    My Camelbak came with an anti-microbial reservoir, it doesn't leak, is super tough and holds a ton of water. Maybe yours is just really old. The platypus might be great too, but the only problem I have with my Camelbak is that it makes my back sweaty.
    Hose is catching on the seat??? How do you have it routed?
    '15 Soma Wolverine '12 Soma Analog SS '10 Transition TransAM '07 Felt F1X '97 Schwinn Mesa SS '89 Fuji Saratoga '86 Fuji Club
    Oct 2007
    I want to chime in on the NUUN tablets. In the last six weeks I have done rides of 6.5 hours, two 10+ hour days in a row, and also two four hire training rides in the Florida heat--with zero cramps. And my Camelback bladders have not been getting funky like they would if you put a sugary sports drink in there.
    Five is right out
    I've found Camelbak bladders to be absolutely fine as long as I keep them clean.
    On the other hand, I've found their packs to be overhyped, under-designed, solidly mediocre offerings (with the obligatory nods towards Wingnut, Deuter and Ergon here).
    Quote Originally Posted by slowrider
    Nalgene bladders rock. The quick-release on the hose attachment means you don't have to re-run your hose every ride.
    They will grow funk though - don't believe they won't.
    Unfortunately, I took a leaky Nalgene to REI for warranty replacement only to find that they don't carry them any more, and they offered comperable replacement - Camelback. Oh well....
    One ride in and I already think the bite valve is too leaky. Great flow when bitten correctly, but set your pack down and the valve happens to get weighted and...wet pack.
    Life is Good
    Reputation: Judd97's Avatar
    Jun 2005
    The newer generation anti microbial camelbak bladders beat the pants off of the older generation bladders I first had when I got my camelbak in 2001. The new ones grew all sorts of little utopias if I wasn't careful. I don't have too much of a problem with my new bladder except for around the bite valve, but that's easy enough to clean.
    I am having a leaking problem in/around the bite valve area though, and that's kind of annoying.
    As far as other brand hydration packs, a few of my friends have them and I've seen them have nothing but trouble. Leaks, hard to use bite valves... I usually tell them to put a camelbak reservoir in their pack and call it quits.
    Get a bicycle. You will not regret it if you live. ~Mark Twain
    Reputation: Jason B's Avatar
    Well, there goes part of the problem right there. Freezing does absolutely nothing at all for you.
    A cross post from another forum on mtb's:
    Hey, guys...
    I was a microbiologist in a previous life, and I can tell you with all due certainty that freezing will not kill microbes. It will slow down their metabolism and reproduction, but it definitely will not kill them. They'll resume their normal function as soon as they warm up.
    The only way to actually kill bacteria and mold in your CamelBak effectively is to use one of the commercially available detergents and/or sterilizing agents.
    Let's look at it this way: if freezing was effective for disinfection, you'd hear about it being used in labs and operating rooms, as it would be safer and more cost effective than the current process. Labs and ORs sterilize their equipment using an autoclave - high-pressure steam heat.
    Reputation: InvictaS1's Avatar
    Mar 2005
    i really like my nalgene bladder. the quick detach hose is awesome, they even come with a magnetic clip that secures your bite valve to your packs chest strap (greatest invention ever), and the bladder doesnt have any taste at all.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Wingnut and Water Bladders
    Quote Originally Posted by shiggy
    Shiggy,
    What Platypus bladder fits with your Wingnut. I riding w an MPS Alpha and cramming a standard C-bak bladder in to the square (bottom) bladder pouch. It "works" but it not very well. Without some sort of sizing chart (or someone that knows the answer), the last time I looked I couldn't figure out which Platypus bladder would work with a square pouch.
    Try the military spec stuff from Camelback. Both the packs and the bladders are a step up. Quick release fittings, etc. LA Police gear has better prices than direct.
    Cheaper than dirt
    Try cheaper than dirt (military surplus) if you'r not particular about your resevior brand; the website has new overstock military reseviors for $10 last time I checked.
    Reputation: Wombat's Avatar
    I have had to replace at least 3 platypus bladders in the last 4 years because they eventually leak at the seam where it "folds" as it fills and empties.
    Tim
    Hoosier
    Reputation: Keatan's Avatar
    Have had no problems with my camelbak bladder however the pack is uncomfortable most of the time. My next pack will most likely be an Osprey
    SS is like beer...its an acquired taste.
    Reputation: enFuego's Avatar
    another vote for Platypus
    Been using Platypus bladders in my Mule. Even the latest Camelback bladders have that vinyl taste that I can't stand. Platypus doesn't have that garden hose taste.
    Gotta clean 'em and dry 'em ASAP after the ride.
    Dec 2004
    Quote Originally Posted by Wombat
    Tim
    Yes, the guy I referred to in my original post has had several of his Platy's leak. He claims they are good with their warranty and they pay shipping to send him a new one when it leaks.
    About the freezer thing, it doesn't hurt if it at least temporarily slows their growth, and I would think that combined with the cleaning tablets and draining the water...it would've helped. It was a newer bladder to whoever asked.
    And, I lied ( ) In my first post, I said I like the actual packs...in truth I don't, I just put that there to not sound completely negative on C-Bak's part. They are OK, but my main gripe is they never feel just right on my back.
    I just wanted to say thanks to Platy and let the whole wide world know.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    slow
    Feb 2005
    Quote Originally Posted by Keatan
    Been using my Osprey hydropack with my Platy bladder for 13 years. Comfortable and durable.
    I am a pathetic rider...
    I think I am the only one in this post who has no complaints about their camelback lol. I have been using mine for about a year now and besides one time where I was stupid enough to put some gatorade in there it has been bacteria free and tasting great. I like the way it is designed and feel it is build very solidly and fits comfy when you have it adjusted right.
    Save the Earth, Ride a Cyclist
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    I am happy with the older Camelbak bladders, the ones with the small screw top openings. I always have mine in the freezer. The larger openings are too hard to open when cold or frozen. I have never had anything grow in mine. I also only use water. Bladders that aren't being used are allowed to completely air dry (on a bladder expander) before being put away.
    I route my hydration hose over my shoulder so it never gets caught on anything. Occasionally it will pinch open while being transported or set down if I forget to close the valve.
    I have tried other bladders and hate their bite valves.
    I also highly recommend Wingnuts.
    Riding Fat and still just as fast as I never was.
    Reputation: 4mula1's Avatar
    I had a circa 1994 C'back. The bite valve fit over the T shaped end of the hose. Really, really, easy to knock off. I don't know what ever became of it during my extended hiatus from riding. Knowing how well I kept it clean back then plus what I put in it it probably walked away on it's own...
    The Classic I got this summer is so much better than the old one I had. The only thing I've noticed is that if the bite valve hits my knee hard enough it sprays me a bit. Oh well. Beats drinking from a dirt covered bottle...
    My camel back one works fine. I use only water and clean it out with cheap gin or vodka on a fairly regular basis. No growth, taste or leaks in the year or two I've had it.
    After 3 more uses, I find that the Camelback bite valve SUCKS and leaks whenever something touches it.
    LAME.
    a.k.a. MTBMaven
    Reputation: mtnfiend's Avatar
    Lots of other comments here but I have found Camelback bladders sufficient after several years of use and little cleaning. I too have found that sport drinks and bladders do not mix well. I use only water and elete water pure electrolyte drops only in my bladder. And I hardly ever clean it. Just a quickly cycling of water through the systems and then fill it. My only main complaint is how hard it is to take the "top" off to fill the thing. Sometimes mine is a real pain. But once open I like the large size of the opening.
    I am also a huge fan of the Wingnut pack with only minor grips. The fit of the thing is superb.
    I thought of that while riding my bicycle. ~ Albert Einstein on the theory of relativity
    Dec 2004
    It's weird because I only used water. Never put anything else in there.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    Founder: Dirty3hirties
    Reputation: ddraewwg's Avatar
    Quote Originally Posted by CharacterZero
    LAME.
    You can get one with the shut off valve....doesn't leak. I have two of them.
    In general, I've only used Camelbacks (2 blowfishes and 1 HAWG). The HAWG looks completely brand new and I've been using it for the past 6 years at least....same bladder. Never have had any problems with it.....never freeze it....rarely wash it (i let it dry though after every ride).
    Recently, I've thought about getting a new bladder just for the hell of it, but then I figure it's just a waste of $30 since there's absolutely nothing wrong with it.
    Mold will grow on anything if given a chance. Run bleach and rinse thoroughly.
    txn
    txn is offline
    Reputation: txn's Avatar
    LAME.
    I've had the same issue with Platypus bite valves. Luckily, both companies added the shutoff.
    Reputation: antonio's Avatar
    Jan 2005
    I always drink watered down Gatorade from my CB bladder. Every 4 to 5 rides or so I'll rinse the bladders with water and a small amount of bleach. I rinse it out very, VERY thoroughly, and store in the fridge. Same bladder for years and zero issues - no mold, no funky taste, and no headaches. Needless to say, I'm pretty satisfied with their bladder.
    I'll agree, though, that both my Wingnut and my Osprey packs fit much better than the Hawg I used to run.
    Ant
    no issues with camel bak either. i always leave water in it for a day or too, and just emtpyit out, rinse and allow to air dry buy hanging it out.
    no taste, no growth, no problems at all.
    the bite valve is awesome. easy to drink from, and no leaks. i even have the camelbak waterbottle with the bite valve and love it.
