Results 1 to 11 of 11
    Topeak Joe Blow Mountain pump and road tires...
    Hey guys,
    I have a Topeak Mountain pump but I just got a road bike today so I'm trying to decide if I need a second pump.
    The gauge only goes up to 75 or 85, so I'm wondering if the pump will still work for higher tire pressures. I am planning to get a dedicated gauge if so rather than having another pump sitting around.
    Has anybody tried this? Sorry if it's a silly question.
    Jun 2012
    Not a silly question, try the road bike forum, folks here mostly ride MTB's
    Quote Originally Posted by Learux View Post
    Thanks. I almost did that, but then I wondered if any of them would then have the mountain specific pump
    Jun 2012
    Fair enough, I would say start pumping and see what happens.
    Reputation: JoePAz's Avatar
    May 2012
    Quote Originally Posted by joshmv View Post
    Hey guys,
    yes. The pump may do the job, but you will not know where you are at. I run my road bike at 80 front and 100 rear. This is for 700x23 tires. I used Topeak Joe Blow pump, but my gauge goes past 100.
    Joe
    '12 Santa Cruz Highball 29", '13 Santa Cruz Solo 27.5",Vassago Verhauen SS 29" XC, AM, blah blah blah.. I just ride.
    Dec 2005
    Very often, the gauges on pumps are untrustworthy. A separate pressure gauge is a must-have. I like the digital SKS one.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I know this thread is a bit old but future readers might find this useful.
    I just got a JB Mountain pump. It's not made to pump up road bike tires. Not (only) b/c the gauge doesn't read past 75psi but b/c it's a high volume/low pressure pump. it's gets firm at 30psi. I can't imagine what it feels like trying to force 100+psi through that thing.
    Could it be done in a pinch? I'm sure it could. If I owned a road bike would I buy a low volume/high pressure pump to go along with my JBM? Absolutely.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by eatdrinkride View Post
    Getting to 50-60psi is no problem with the JBMt. More than that is full body weight on the handle and it barely moves.
    mtbtires.com
    MTBGremmie
    Reputation: jSatch's Avatar
    this pump is constructed to handle low pressures into large volumes, i.e., mountain bikes. apparently the internals may also be compromised since the pump wasn't designed to pump high pressure, as other owner reviews complain about a short life span of this pump. so yes, even though you may be able to hit higher pressures, you will wear the internals faster. that is, if the yellow valve lever doesn't break first. that's what happened to me and apparently many others. the thin plastic lever snaps rendering the pump useless. pump is engineered to save money in production costs, not to last long.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    A year and a half late on your response, but thanks.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by HitmenOnlyInc View Post
    Yes it was very helpful especially considering my Joe Blow has been working flawlessly since 2008'. At least I'll be ready when it does blow.
  1. Road tires on a mountain bike
    By DirtyHog in forum Wheels and Tires
    Last Post: 03-11-2017, 05:52 PM
  2. Joe Blow Mountain Pump-Tubless Inflation
    By ALS650L in forum Wheels and Tires
    Last Post: 08-06-2013, 09:07 PM
  3. Topeak RaceRocket frame pump?
    By BigBadConrad in forum General Discussion
    Last Post: 10-29-2012, 03:29 AM
  4. I just bought this Topeak Joe Blow Sport II. How do I use it?
    By AmericanDream in forum Beginner's Corner
    Last Post: 08-15-2012, 08:51 AM
  5. Topeak fork pump issue
    By wanderinginhel in forum Beginner's Corner
    Last Post: 02-26-2011, 09:54 AM
