Results 1 to 10 of 10
    Oct 2012
    Tire size limit for a Yukon fx, help !
    I want to throw some Maxxis Ardents on my Yukon but I'm not sure if they will fit. The bike is stock and the tires I want to put are 26 x 2.25... Will I have an issue?
    thanks!
    B A N N E D
    What size tires do you currently have ?
    How much clearance is currently there with the seat stays and chain stays ?
    How much clearance is currently there with the front derailleur on the small chainring ?
    If you put on a tire that doesn't have much clearance it might rub if you buckle a wheel or break a spoke.
    Oct 2012
    I'll post some pictures right now hold on
    Oct 2012
    My count needs to be 10, Grr
    Oct 2012
    Bump
    Oct 2012
    bump
    Oct 2012
    I live to bike
    Reputation: Jwiffle's Avatar
    2.25 will easily fit up front, pretty sure will fit in the rear as well.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
    B A N N E D
    What's the size of the current tires ????? ( it's stamped on the sidewall )
    If the size of the current tires was known you could compare the measurements of them to the tires you want.
    http://www.maxxis.com/Bicycle/Mountain/ardent.aspx
    26 X 2.25 ( 54/56-559 )
    The 54/56 refers to how wide the tires are: 54mm to 56mm.
    Oct 2012
    I already went to a shop and got them. They look sweet, I will post a pic tomorrow.
    Thanks for the help guys !
