Results 1 to 12 of 12
    Aug 2010
    Tire dilemna - Knobby or semi-slick/hybrid. Please help!
    Hi
    I have a hard tail mountain bike, which I only use on roads for my daily commute (18 miles) - I bought it for the extra comfort as I have a bad back and really feel the bumps on londons crappy roads, so a road bike is a definite no
    My tires at the moment are specialized fast trak control 26"x2, and I run them at 35psi for the extra comfort. I want to get tyres that are made for road use, but I'm worried about sacrificing comfort, so am definitely sticking with 2" wide, chunky tyres
    I'm torn between Specialized Crossroads Armadillo's, which are pretty knobbly, and Specialized Hemishere Armadillos, which are semi-slick/hybrid.
    My question is do the knobbly bits provide extra comfort/shock absobrtion? If so the crossroads would be better for me (my back!), but if not then the Hemispheres are better and are more suitable for road use. But comfort is my main concern
    I've searched for days on the internet but cant find any answers
    Can anyone help please?
    Reputation: nuffink's Avatar
    Feb 2010
    I travel to London on a mountain bike occasionally so I feel your pain. Because I'm lazy I just stick to my Conti Race Kings since they roll reasonably well. If I were doing it more regularly I'd switch to Schwalbe Kojak's. I have a pair of the 26" x 2.00" and they're a treat on the tarmac. I don't think you'll find anything much lighter (460 gm) or faster in a large volume tyre. If you do, let us know.
    The knobs would really only help you for climbing and gripping onto dirt surfaces. On the road, knobby tires don't really help with that, otherwise you'd see dragsters running knobby tires instead of slicks.
    Likewise, a slick tire will also be smoother on the road. The lower PSI is where you're soaking up some bumps, and while I don't think knobby tires are bad for road use at all, I had a bike with slicks and you COULD tell a little bit of a difference...
    My 2 cents.
    Aug 2010
    great thanks for these
    so the knobs dont provide any extra comfort/shock absorbtion on tarmac (london roads have potholes/bumps everywhere)?
    Feb 2010
    No. All they do is add a bit more trail buzz into your bike and, potentially, limit your grip. Knobblies are designed for surfaces that deform in some way. On tarmac slicks (or very close) are the order of the day.
    Old Yeller
    Reputation: DMKiefer's Avatar
    On the other hand, since you are commuting, the knobbies provide more protection from bits of glass and sharp metal than a slick or semi-slick. I just switched from knobbies to semi slicks this summer and got two flats from a tack laying in the road, and a tiny thorn that would have been avoided if there were knobs on the tire. I never got flats with the knobbies.
    I'm on the road quite a bit on skinny slicks (on my road bike) and have not got a flat in 2 years. Flat protection is about the same between knobbies and slicks. However, on road performance is far better on slicks. My wife rides her mtb on the road with 1.5" slicks. No flats yet. I wouldn't even bother with those semi/hybrid tires. Just go for the slicks.
    Aug 2010
    this is all great info, thanks so much
    both the tyres I'm looking at both have Armadillo flat prevention so flats are less of a worry
    I've attached pictures of both tyres here (Crossroads are on the left). I guess the Crossroads isnt really that Knobbly, especially in the middle
    But it does look more comfortable and looks like it can absorb more shock...
    If you want a bigger volumn tire, check this out:
    http://www.jensonusa.com/store/produ...pple+Tire.aspx
    Available in 2.0 or 2.35.
    But if it were me, I'd go 1.5":
    http://www.jensonusa.com/store/produ...nith+Tire.aspx
    Sep 2012
    sorry for the thread resurrection... been trying to search for info on hybrid tires but mostly outdated and this is the most recent ones. would like to know what are new choices and if they have improved the past years. new to mtb-ing and currently have 1.5' serfas drifters and it's working so far since i'm mostly doing roads and light trails for now. previous owner was doing mostly road and he set it up for commuting. brought to a pretty rugged trail and it held up fine in slow speed and just lost grip on loose dirt/sand. was thinking of going with the 2-inch version of the serfas. any suggestions or even just experiences with other hybrids? i'm aware that these will always be a compromise of road and off-road and won't be excellent in either department. i don't really mind as it's not competitive and just recreational for now.
    sorry again for the thread revival
    Aug 2014
    any reviews about maxxis detonators? 26x1.5?
    Family owned
    Nov 2003
    Quote Originally Posted by stevewand View Post
    I believe they do. It stands to reason that each one of those little knobs acts like a tiny shock absorber.
    Can you try it? Ride one set for a few days, then switch. Get back to us.
