Results 1 to 10 of 10
Thread: thru axle?
    Mar 2013
    thru axle?
    hey guys might be a stupid question but i have no idea about thru axles. im looking at getting a new fork but has a 20mm thru axle ive never had one but looked on youtube on how to install my question is i have a normal wheel on the front as it stands now and wanna know do thru axles go on any wheel or will i have to buy a new wheel rim?
    No. Just No.
    Reputation: Circlip's Avatar
    Some types of hubs are convertible (by installing some different bits such as hub end caps) between different axle types and others are not. If you post up your hub make and model, or else a photo which clearly identifies the make and model, someone here may be able to give you a specific answer about whether your front hub is convertible to 20mm.
    Reputation: dansMTB's Avatar
    What kind of fork is it?
    In short, odds are you will need a new front wheel.
    Heres a vid for the rockshox maxle: Maxle_360 - YouTube
    Heres a pic of a 20mm front hub
    Big Mac
    Reputation: mbmb65's Avatar
    thru axle?
    Not normal. Need new wheel rim.
    Mar 2013
    could tell ya what make the rim is as got them 2nd hand and they been sprayed black. could u guys suggest a cheap rim that would take a 20mm axle
    Mar 2013
    couldnt*
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Rims have nothing to do with the axle/hub other than the fact they eventually get attached to each other. If you don't know what the hub is, and it was spray painted, it's probably not compatible. I'd start looking for a new hub if you really want that fork.
    I'm a mountain bike guide in southwest Utah
    No. Just No.
    Quote Originally Posted by Silentfoe View Post
    Or more likely a new complete built wheel with 20mm hub.
    Reputation: jkad's Avatar
    Dec 2005
    Velocity Blunt SL Comp 26" Is 6 Bolt Disc QR 15 20 MTB Mountain Wheelset Wheels | eBay
    Just an option.. i picked up a complete wheelset front and back (front has a 20mm thru axle) with tubeless tires shipped for $150.00 off PB.
    Do a search there..cant go wrong.
    "foot to pedal, wheel to dirt, there is no substitute for the act of riding "
    Aug 2010
    I'm in the same boat. It will be quite some time before I can afford a new "decent" thru- axle type fork AND wheels that will work with the fork!
  1. Replies: 2
    Last Post: 01-23-2013, 10:20 AM
  2. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum XC Racing and Training
    Last Post: 01-22-2013, 10:04 PM
  3. Replies: 34
    Last Post: 03-17-2012, 10:05 AM
  4. Hope Pro 2 rear axle upgrade? install Evo bearings and axle?
    By KrisRayner in forum Wheels and Tires
    Last Post: 02-24-2012, 03:05 PM
  5. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 09:09 AM
