Results 1 to 40 of 40
    Dec 2013
    Technique I can't seem to learn: two rocks with gap: can't get the front wheel up!
    Picture this:
    • Two pumpkin-sized rocks, spaced about 18 inches apart. You go up and half-way over the first rock and it's looking good so far.
    • But then your front wheel approaches the second rock. You try to pull up on the bars to lift the front wheel, but the rear wheel is still high on the first rock and the bike is tipped downward too much. Your attempts to lift the front wheel fail.
    • Rather than going up and over the second rock, the front wheel digs in hard and you come to a sudden halt, almost (or actually) going OTB.
    I'd love to hear some tips on how to approach this. Any time this obstacle pattern occurs in a trail (two bumps back-to-back) I'm pretty much screwed. I've tried keeping my weight back, and keeping my elbows bent in an attempt to lift at just the right point. But so far no dice. It gets me every time.
    Self Appointed Judge&Jury
    Oct 2000
    Front wheel up on first rock as you're approaching the front wheel onto the second rock you compress down the rear and pull up in a bunny hopping technique and then immediately pull the up on the bars to get the front tire onto the second rock. Go up and over hit the skids and drink a beer.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Just huck it.
    Reputation: smithcreek's Avatar
    Nov 2012
    Right before the front wheel hits the second rock I compress the front wheel hard and let the fork rebound take enough weight off the front wheel that it rolls over it. Make sure to pedal through it or at least the instant you release the fork compression. Trying to loft the front wheel in a manual in that situation is near impossible unless you are going so slow you can pedal and wheelie, trials style.
    Professional Crastinator
    Reputation: Fleas's Avatar
    This assumes that this is a low speed move with space for a wheel in between the rocks.
    Just as the front wheel touches down past the 1st rock, move your body slightly forward, then stop your body while making it light - almost like a bunny hop. Thrust (lunge?) the bike forward and up, rotating around your bottom bracket while your body is stopped. As the rear tire rolls down the backside of rock 1, the front tire goes up rock 2 and your body moves forward to continue over rock 2. It takes some muscle. The lighter you can make yourself, and the stronger you are, the easier it is. It is the same move on double logs and certain stairs that are spaced really weird. I'd have to say it is a lot like a bunny hop with bike rotation. And don't forget to pedal up rock 2 - prob'ly a ratchet pedal + another lunge.
    If the rocks are close enough to bridge the gap with your wheelbase, wheelie off rock 1 and put your front wheel on or over rock 2.
    -F
    PS - it is easier on a rigid bike
    It's never easier - you just go faster.
    Classic wheel trap. See above for great ideas that I cant' do.
    Quote Originally Posted by matto6 View Post
    Picture this:
    • But then your front wheel approaches the second rock. You try to pull up on the bars to lift the front wheel, but the rear wheel is still high on the first rock and the bike is tipped downward too much. Your attempts to lift the front wheel fail.((Pulling up will never work))
    Momentum is your friend...
    So is a manual...
    Even better is a manual with a bunny hop up onto the first rock...
    The only way to keep the front in the air is to get the weight way back...(the manual)..
    If your gonna let the front go down in between the rocks you will after really push it down so that it springs back hard.....that can work too.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    There's a spot like that in one of the local parks. The rear wheel is dropping off one rock at the same time the front hits the next one. Timing and momentum is everything. Be in a fairly hard gear. You cant granny ring that. Stand up in an attack position. Just as your front tire approaches the 2nd rock pedal hard & lift the bars like you're going to manual. Commit to it. Dont go at it tentatively or you'll wuss out. As the front clears the second rock keep pedaling & ride it out.
    No moss...
    Picture this:
    It's not possible to ride over something like this on a bicycle. You should contact the local bike clubs in the area, to find out where the "flow trails" are. Riding those is alot more fun.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by turbodog View Post
    Because everyone wants to ride a trail that is as smooth a a sidewalk....with jumps. Wait..... That sounds a lot like our local BMX track.
    Anybody can ride flowy trails.....cleaning sections like the OP describes is a much better challenge.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Feb 2013
    I'd like to see some pictures of this rock section before I try to give any advice. It could just be that you need to try a different line.
    "...when I stand to climb I'm like the Hulk rowing the USS Badass up the Kickass River."
    -michaelscott
    Reputation: kubikeman's Avatar
    Jun 2010
    Okay... I'm picturing two pumpkin sized rocks... I don't see the problem
    The cake is a lie.
    Or, like they do around here, rip out both rocks. After all, if they can't ride it, obviously nobody else can...or wants to try.
    Quote Originally Posted by mtbdl View Post
    or, like they do around here, rip out both rocks. After all, if they can't ride it, obviously nobody else can...or wants to try.
    I know you're joking but...
    GRRRRRRRRRRR!
    Someone around here just cut out a tree that has acted like a gate, called "The Squeeze", for the last 22 years. You could exactly fit a 30" handlebar straight through. Anything wider had to be wiggled through. The trail stewards are looking for that person.
    -F
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    I studied your plight, made a few sketches; I couldn't do this either.
    I don't rattle.
    Oct 2000
    This ^^^ seems to be the best and most accurate way of doing it. Saved me some typing DJ thanks!
    go faster
    Quote Originally Posted by ncfisherman View Post
    Just huck it.
    Is this what you mean?
    Technique I can't seem to learn: two rocks with gap: can't get the front wheel up!-2hrzk9f.jpg
    Reputation: 70sSanO's Avatar
    Nov 2013
    I'm doomed...
    John
    1995 Trek 970 - 80mm Atom Race
    1992 Serotta T-Max - 70mm Z3 Light
    1993 GT All Terra - 46mm Mag 21
    (STOLEN)
    The White Jeff W
    Quote Originally Posted by Fleas View Post
    GRRRRRRRRRRR!
    -F
    Vultures Knob?
    No moss...
    Jan 2014
    Buy a 29er.
    Just kidding!!! That was a joke. Lower the flame throwers.
    Seriously, sometimes you just might not have the ability to clear something. Either practice practice practice or just need to avoid the rocks.
    I get over stuff now that I never thought I would be able to do and there is plenty of other stuff out there that I still think I'll never do. Maybe I'm right. Maybe not.
    Jan 2014
    There was this massive log across a trail that foiled me for the last year and half. Then a few weeks ago I got over it clean for the first time. Last week someone removed it. Idiots.
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    Quote Originally Posted by Iamrockandroll13 View Post
    this ^^
    Back tire hop!
    lol, yeah a specific size would be more handy in figuring this problem out.
    Reputation: J.B. Weld's Avatar
    I'm sure there must be an App for this.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Unweight the front wheel(lean back), so the rear wheel builds momentum as it quickly rolls down the first rock. As the front wheel impacts the second rock - it should be light enough to start climbing up it. Make sure the gearing is NOT on the granny, though.
    This is one of those tricky moves that really require more timing and execution...than all-out effort.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: AllMountin''s Avatar
    Re: !
    As you approach the obstacle, just say, "**** it" and huck it.
    Works every time.
    live long and huck
    Reputation: Optimus's Avatar
    Get a dropper post. When you roll up to the obstacle, lower your post and come to a complete stop. Dismount safely. Push and/or lift your bike through/over/around the obstacle. Remount safely. Raise post back up while continuing to ride down the trail.
    Oct 2000
    Quote Originally Posted by Optimus View Post
    Opti,
    Do you have a training video you could show for the learning impaired.
    live long and huck
    As a matter of fact DJ, I do, LOL.
    <iframe width='500' height='281' src='http://www.pinkbike.com/v/embed/366226/?colors=c80000' allowfullscreen frameborder='0'></iframe>
    Oct 2000
    Ha,ha I see very informative. I have a few of them myself but I can't edit down to just a minute like that.
    live long and huck
    This one is a little more serious.
    <iframe width='500' height='375' src='http://www.pinkbike.com/v/embed/366231/?colors=c80000' allowfullscreen frameborder='0'></iframe>
    live long and huck
    OP, it's not so much speed, as it is rhythm. And practice. And a dropper post does help, although you will become almost dependent on it. But who cares as long as you are riding what and where you want.
    Oct 2000
    It's funny I have a dropper post and hardly ever use it. Things are moving too quick by the time you lower it your past the obstacle in question. Unless it's a long steep technical downhill.
    It's even more challenging when the rocks are slippery.
    <iframe width='500' height='375' src='http://www.pinkbike.com/v/embed/362230/?colors=C80000' allowfullscreen frameborder='0'></iframe>
    Afric Pepperbird
    Mar 2005
    Aw, hell, that's easy! I wanna see how to ride over large pumpkins spaced close apart!
    Reputation: noosa2's Avatar
    Quote Originally Posted by dirt farmer View Post
    LOL that is the easy line that Optimus took but it is not as easy as it looks in this video.
    live long and huck
    I know I have a pumpkin riding video somewhere, but I just can't find it. I can't remember though if they were large, or medium-large. But they were pretty close together. The neighbors were pissed that I was riding on their front porch on Halloween.
    live long and huck
    Quote Originally Posted by noosa2 View Post
    Haven't yet mastered getting up on the rock on the right.
  1. New front wheel...Stans NO TIRE front wheel???
    By ecub in forum General Discussion
    Last Post: 04-24-2014, 05:49 AM
  2. Converting rear wheel (10mm) to a front wheel (9mm)
    By WeAreTheCosmos in forum Wheels and Tires
    Last Post: 06-21-2013, 03:46 PM
  3. Paid spam: clyde 29er wheel set or front wheel
    By Slow Danger in forum Clydesdales/Tall Riders
    Last Post: 05-22-2012, 01:33 PM
  4. Play of rear wheel (rocks side to side)
    By darnelli in forum Wheels and Tires
    Last Post: 04-19-2012, 09:49 AM
  5. I need a new front wheel
    By pecsokak in forum 29er Bikes
    Last Post: 01-21-2011, 01:53 PM
