Results 1 to 51 of 51
    Apr 2005
    Sun Joe presssure washer?
    Does anyone use sun Joe portable washer? This thing runs on40 volt battery pack
    Sent from my SM-G965W using Tapatalk
    Jan 2009
    no one who is smart uses a pressure washer to clean their bike. perhaps in a muddy race situation, but a pressure-washed bike will need to be overhauled after the jet of water has washed the grease out of all the places it is needed. a gentle hose and a brush will do the trick just fine.
    Thorn in your Sidewall
    Vassago Jabberwocky
    Apr 2005
    This washer is used where you don't have access to water
    Jan 2009
    where would you not have access to water? do you have water at your house? rinse your bike off when you get home. why would you need to pressure wash your bike in the wild? are you afraid someone is going to ambush your bike with glamour shots?
    if you're going to carry a pressure washer, you can just pack a jug of water and a soft brush with you to do the same task without risking blasting your bearings and stuff.
    I am not concerned with how you access water, just the fact that there's no reason to use a pressure washer on your bike at all. seems like overkill for absolutely no reason at all.
    Vassago Jabberwocky
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    ACE plant sprayer. ideal.
    https://www.acehardware.com/departme...rayers/7437668
    will clean off goo, won't blast too hard
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    One ring to mash them all
    Mar 2015
    OTOH, sounds like an excellent option for Post Ride Body Cleanup.
    "Reasoning will never make a Man correct an ill Opinion, which by Reasoning he never acquired"
    ó Jonathan Swift
    Jan 2009
    I use a plant spray for post-ride booty cleanup.
    Vassago Jabberwocky
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by the one ring View Post
    And it would triple as a bug zapper in the wilds.
    Bicycles aren't motorized
    Reputation: life behind bars's Avatar
    May 2014
    It's hand held too!
    It ain't supposed to be easy.
    Make
    America
    Gravel
    Again
    Contains no juice.
    Nov 2003
    And as a clogged drain cleaner! Sha-ZAYAAMM!!!
    "...rhetorical hyperbole..."
    Contains no juice.
    Nov 2003
    Quote Originally Posted by mack_turtle View Post
    Spray? Or sprayer? Lol
    Mar 2015
    Quote Originally Posted by Finch Platte View Post
    Yeah, hopefully not Roundup.
    ó Jonathan Swift
    Jun 2016
    I live in a condo where there's literally no where to draw water from. My porch has good drainage so I bought one of these that has worked really well for me, cheap as well. You just pump it for pressure and It's not really a "pressure" washer as the water pressure is not super strong, but good enough to wash a bike. I imagine this would work well as a trail side shower or to wash stuff off if no water access.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Apr 2005
    Quote Originally Posted by 127.0.0.1 View Post
    This thing is too weak
    Jan 2009
    Quote Originally Posted by Picard View Post
    for what?! are you riding through wet concrete and allowing it to dry on your bike? no one else ever says they "need" a pressure washer, except you. if you need a actual pressure washer to clean your bike, you're doing something weird.
    I have used a sprayer like that, it puts out more pressure than I need. if the dirt is caked on, you spray the dirt down, let it soak up some water for a few seconds until it turns to mud, then spray it right off. I pressure washer would do the same thing, but it's way more complex and will damage your bike in the long run.
    Vassago Jabberwocky
    Apr 2005
    Quote Originally Posted by Naolin View Post
    This washer has negative reviews. It leaks at the base of the hose connector
    Mar 2015
    https://www.amazon.com/Theo-Klein-Fi.../dp/B0014QOMRQ ?
    ó Jonathan Swift
    Jan 2009
    newsflash- everything on Amazon has some negative reviews. 3.5 out of 5 stars for 46 reviews is not bad. if you don't like that one, there are a ton of similar products that do the same thing without resorting to the absurdity of using a pressure washer on your bike. that's like brushing your teeth with a belt sander.
    Vassago Jabberwocky
    Jan 2009
    a little of both. stuff grows in places it's not wanted.
    Vassago Jabberwocky
    Apr 2005
    The sun Joe isn't powerful as my gas washer. Joe produces only about 1000psi
    Jan 2009
    what exactly are you trying to wash off your bike with water at 1000 psi? how is that remotely necessary?
    Vassago Jabberwocky
    EAT MORE GRIME
    Nov 2013
    no it doesn't
    source: I own one, it doesn't leak.
    Apr 2005
    I want to wash of heavy mud, dog poop
    Jan 2009
    you don't need 1000 psi + to do that. a gentle hose, maybe a little dish detergent, and a soft brush will do that job. anything else is a stupid idea. no one on the forum is going to validate that for you unless they also like doing foolish things to their bikes with unnecessary tools.
    Vassago Jabberwocky
    EAT MORE GRIME
    Nov 2013
    ok then yes get the portable pressure washer, they are fine
    but this is better as it is 12v. run off a car battery, no fancy 40volt monstrosity
    https://www.amazon.com/Dyconn-Faucet.../dp/B00PT46CC2
    Apr 2005
    This washer doesn't ship to Canada.
    Cycologist
    Reputation: chazpat's Avatar
    Building one of these?
    Quote Originally Posted by Oh My Sack! View Post
    Remember, there's always quilting and knitting if pedalling becomes too tough.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Its like people havenít discovered soap yet.
    Reputation: Cuyuna's Avatar
    May 2017
    If I wash at home as routine maintanence I usually put it on a stand and scrub it down with some soapy water (Simple Green) along with the chain, cassette, and bogey wheels, then hose it off. If I have a truly dirty bike as in riding the trails in the rain or otherwise sloppy ride (our local Red Dirt) then Iíll usually stop by the coin op car wash on the way home and put a few quarters in. I avoid the bearing areas and donít blast close up. No big deal. My bearings do just fine on that particular regimen. IMHO, the whole pressure-washer on bikes thing is largely an urban legend boogeyman if used with common sense.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Cleaning bikes is overrated. Dirt in pivots and bearings is bad, as is water and washing out lube. Do your cleaning efforts ameliorate or exacerbate these problems?
    Do the math.
    May 2017
    Quote Originally Posted by Lone Rager View Post
    My biggest issue on mountain bikes is always chain, cassette, and especially jockey wheels. I donít care about the rest of the bike, but when those items in particular reach a particular grunge threshold, shifting suffers, so I do tend to clean those items fairly often. Iíve never had an issue with any bike Iíve owned in 30 years that I would attribute to over-cleaning.
    ETA: seat post. Iíve read enough ďstuck seat postĒ threads to stimulate me to pull the seat post fairly often, wipe it down and re-lube.
    Contains no juice.
    Nov 2003
    Well, Canada.
    Reputation: MOJO K's Avatar
    Free-hub bodies, wheel bearings, suspension components....none of it likes the pressure sprayer. One mechanic suggested that I should never even use a nozzle on the garden hose, just a brush and "falling" water. I myself kind of like using a brush attachment on the shop vac to clean the bike after it's all dried up. Then I hit the drivetrain with a towel shot with a little WD-40 if it's junked up. A little piece of corrugated cardboard cleans out between the cogs beautifully.
    Quote Originally Posted by Cuyuna View Post
    Agree. Not that I wash my bikes regularly, but I've been hitting them with hose sprayers and an occasional blast from the pressure washer for ages and have never noticed any issues.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    "...if used with common sense..."
    That's the rub though...the guy is looking to clean off heavy mud and dog crap, the common sense may not run strong here.
    I definately had problems with over washing my bikes early on, especially free-hubs and the old Shimano cone and cup wheel bearings. I also have hot water outside my house which causes way more problems than it solves on a bike.
    Jan 2009
    I see Picard is a new phenomenon for you.
    Vassago Jabberwocky
    It seems he had been washing the bike in his sink. Now the drain is clogged, and getting a pressure washer is cheaper than hiring a plumber to fix it. It's rare for Piccard to give the whole story, but I'm pretty good at filling in the blanks.
    Bikesexual
    Reputation: jcd46's Avatar
    Quote Originally Posted by MOJO K View Post
    I think you covered it! Nice job.
    The Orange Fleet:
    '16 SC Heckler
    '14 All City MMD
    '12 Kona Unit Rigid
    Apr 2005
    You got it all wrong. The sink is much too small to wash my bike
    Reputation: phlegm's Avatar
    Yes it does.
    https://www.amazon.ca/Dyconn-Faucet-.../dp/B018WLV1II
    Reputation: Scott O's Avatar
    Are you purposely riding through the dog poop? If so, you might want to consider not doing this.
    Apr 2005
    Quote Originally Posted by Scott O View Post
    Nope. The trails are full of poop.
    Oct 2000
    Never hit the old dirt trails without toilet paper.
    Jan 2009
    pressure washer + dog poop = liquefied and splattered dog poop.
    Vassago Jabberwocky
    Apr 2005
    You are so negative dude
    Oct 2000
    Itís like putting poop in a blender. You donít want to do it and you know itís not recommended but. . . ďsomeĒ are driven to do so.
    Jan 2009
    on a positive note, you can save it and add it to your morning smoothie for a fiber boost!
    Vassago Jabberwocky
    Apr 2005
    I loaned my old xc bike to my buddy. He rode through dog poop and it got stuck on pedal 2 weeks ago. I couldn't scrub it off the pedal with soap and water. It is stuck like crazy glue
    Mar 2012
    I've owned the Mountain Washer for over 3.5 years now and absolutely love it.
    https://shop.mountainwasher.com/
    My bike is all tricked out. It has pedals, a handle bar, a seat and two wheels! H8tRs gunna H8t!
    Jan 2009
    what have those dogs been eating?
    Vassago Jabberwocky
    Upcyclist
    Gluten.
    Cool heads prevail
  1. New Schwalbe Little Joe tire (replaces the Mow Joe)
    By Spectre in forum Families and Riding with Kids
    Last Post: 09-17-2015, 07:44 AM
  2. altitude xfusion o2 air presssure
    By dwyooaj in forum Rocky Mountain
    Last Post: 12-30-2013, 09:22 AM
  3. Replies: 14
    Last Post: 07-17-2012, 10:36 AM
  4. Joe Joe from Kokomo, buckskin belly, rubber butthole
    By Cooter. in forum Downhill - Freeride
    Last Post: 07-24-2006, 04:22 PM
  5. Replies: 7
    Last Post: 06-23-2006, 09:51 AM
Members who have read this thread: 106
