Results 1 to 7 of 7
    New question here. Suggestions for hubs on a worn/wobbly stock wheel set. (nothing fancy)
    I have a 2003 GT timberline with "aluminum QR" hubs.
    http://www.bikepedia.com/QuickBike/B...e#.UYFbuMopk1J
    I'm wondering what's a budget replacement for this type of hub? I've had them worked on by a LBS but they continue to wobble. I think the ball bearing cup is worn and allows for side-to-side wobble, despite tightening. Any tighter and the hub won't spin freely.
    Any suggestions for replacing this hub without breaking the bank? Or should I just buy new wheels? This is just my daily commuter in los angeles. But I like to beat it up occasionally, jumping off curbs and doing wheelies.
    '98 GT Backwoods
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Why not get new inexpensive wheels like Alex rims laced to Formula hubs, plenty of that on eBay.
    Your shop should be able to get you a wheel in whatever price you want to pay.
    Nevermind, I fixed it. The nut that holds the bearings was loose. Luckily my pops has some thin wrenches that helped out. Thanks for the help.
    '98 GT Backwoods
    Actually, I was wrong. I will be needing a hub overhaul. The cone's and the bearing cup's are worn, despite tightening the nuts properly.
    What hubs do you recommend for a mountain bike (v-brake) that gets beat up on rough roads. I looked at some shimano's such as the "acera's" but they have bad reviews as they need maintaining. Deores don't have much better reviews either.
    '98 GT Backwoods
    How safe are mtb products from ebay? I found this set from hong kong.
    Avid Single Digit 7 SD7 SD 7 SD 7 Rim V Brake F R FR7 Fr 7 Fr 7 Brake Lever | eBay
    Where do you guys get your parts from?
    '98 GT Backwoods
    Reputation: mitzikatzi's Avatar
    Quote Originally Posted by adrianm1188 View Post
    ...snip... Deores don't have much better reviews either.
    I have a set of wheels with Deore hubs they work well.
    All hubs (cup and cone) need maintenance. I give mine fresh grease once a year or after a very wet ride. It is a very simple maintenance task.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
  1. Diagnosing worn rear hubs?
    By Bigwheel29 in forum Beginner's Corner
    Last Post: 05-02-2012, 11:13 AM
  2. Velocity hubs vs Stan's stock hubs
    By 7Wayne7 in forum Wheels and Tires
    Last Post: 02-22-2012, 04:11 PM
  3. Are stock Giant anthem wheel hubs "convertible"?
    By kamper11 in forum 29er Bikes
    Last Post: 07-17-2011, 11:11 PM
  4. Wobbly Wheel Hub or Skewer?
    By tahoegold in forum Wheels and Tires
    Last Post: 05-23-2011, 12:13 PM
