Results 1 to 3 of 3
    Nov 2016
    Stuck Raceface Cinch
    I need to change out a creaking bottom bracket and am having issues pulling a set of Next R cranks. I've had them off before with no issues but they will not budge this time. I've removed both the 16mm and 8mm caps from the drive side and the single 16mm cap from the non-drive side completely and the cranks will still not slide out. Any ideas?
    Sent from my SM-N950U using Tapatalk
    Nov 2016
    Brain fart user error. Forgot the drive side 16mm is the puller. Put all that back together, left it on and loosened the 8mm and voila. Leaving this all here in case someone else makes the same mistake.
    Reputation: phlegm's Avatar
    Love when people follow up for future use - cheers.
    BTW, don't post again for a while. You're at a cool 2K posts.
  1. Easton 38T+ 1X Cinch Ring on Race Face Turbine Cinch Crank?
    By Sablotny in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2018, 07:22 PM
  2. RF Cinch - Steel Cinch ring mounting...correct?
    By badgermtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-19-2017, 02:28 PM
  3. RF Cinch w/ Bashguard vs non-Cinch
    By head in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2016, 09:53 PM
  4. Next SL Cinch vs Turbine Cinch
    By Travis Bickle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2015, 11:55 AM
  5. Replies: 2
    Last Post: 12-15-2014, 12:46 PM
Members who have read this thread: 33
