Results 1 to 3 of 3
    May 2005
    Stem Length and Angle Question
    I want to go from a 100mm 8 degree stem to an 80mm stem. Using the online calculator I would need a 15d stem to keep about the same height. If my goal is to make my bike more "trail" and less xc, do I want to keep the same height? btw if I went with a 80mm 10d stem I would be 7mm lower than I am currently.
    A lot of the posts I see about changing stems only refer to the length. Is the angle not very important? Thanks.
    Plays with tools
    Reputation: customfab's Avatar
    It's not so much that the angle isn't important more that your options are limited. They also are less effective as the stem length decreases.
    How does your bike fit with a 100mm vs an 80? That's where you start.
    ffc3, I found I had to raise the angle of the stem when I started riding more all mountain vs xc it is easier to lift the front wheel when crossing logs or riding through rock gardens and I had more control on the descents riding through rocks and jumping off water bars. With my old stem it had a 6 degree rise x100 mm climbed great but was uncomfortable riding rougher trails always felt like I was ready to be pitched over the bars in technical sections now I have a 17 degree stem x 120mm works way better for me.
  1. Stem length/angle question for singlespeed...
    By AK47 in forum Singlespeed
    Last Post: 04-06-2010, 09:44 PM
  2. Replies: 7
    Last Post: 04-20-2009, 01:19 PM
  3. Stem length, angle, and its effects
    By tiggles in forum All Mountain
    Last Post: 07-22-2007, 07:24 AM
  4. stem angle vs length
    By quattrokid73 in forum General Discussion
    Last Post: 04-17-2007, 01:58 PM
  5. Stem length and angle question..
    By Zip in forum Turner
    Last Post: 11-25-2006, 03:06 PM
