Results 1 to 19 of 19
    Skewer question?
    Yes, I realize this is a very noob question. So please don't beat me up too bad.
    I have a 2001 Specialized Enduro. I recently bought a new front skewer. But it was Appx 5mm. And my original skewer is around 9mm. I searched for a bigger diameter skewer. But it seems that 5mm is the standard.
    Is this because I have an old bike and need to upgrade?
    Reputation: mitzikatzi's Avatar
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Oct 2007
    5mm skewers have been the standard for a long time. Specialized has been using 9mm skewers (like what mitzikatzi listed) for a while to stiffen up the front end. What you have is acutally better than 5mm, so you are better off keeping the 9mm that you have. Currently 15mm is growing into the new standard.
    2012 On One Whippet 650b
    2012 Santa Cruz TRc 650b
    2010 Soma Groove
    2005 Giant OCR C1
    2001 Trek 5200 USPS
    1987 Haro RS1
    Thanks for the info!!
    I'm now trying to locate a better looking skewer like the Crank Brothers one I bought last week. I don't see many 9mm skewers. And the ones I do see are dull looking.
    Do you guys know a site that I'd have better luck with?
    Also, what's the technical name? I've been searching "9mm skewer".
    somewhat related question - there is 9mm skewers and 10mm axles correct?
    Anyone know if its possible to convert hubs(Chris Kings) between the two standards, or if there is some spacer to convert from 9mm to 10mm in the drop out??
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by MikeyHustle View Post
    Try "through bolt".
    VERY limited options and none look like the Crank Bros (which is functionally a so-so QR).
    mtbtires.com
    Oct 2007
    Quote Originally Posted by pizon View Post
    Front axles are 9mm, rear axles are 10mm. Unless you are trying to run a front wheel on the rear there is no reason for such a conversion.
    2010 Soma Groove
    2005 Giant OCR C1
    2001 Trek 5200 USPS
    1987 Haro RS1
    Quote Originally Posted by ljsmith View Post
    Front axles can be 15 mm or 20mm they each need a specific hub and fork to be used.
    Front axles can also be "9mm" they both use standard QR type forks (open dropouts).
    9mm axles can be "through bolt" and require a special hub and skewer (through bolt/axle).
    In other hubs the 9mm axle is part of the hub. It has a 5mm hole in the center that allows a 5mm QR skewer to be used.
    9mm axles can also be threaded and use nuts to secure the wheel.
    Some hubs can be used as all 4 types with the use of adapters eg Hope.
    Generally most standard 9mm/QR hubs can not be converted.
    so the question is really about my rear wheel. it is attached to the bike with a QR skewer. This skewer seems pretty much identical to my front. So is it 9mm or 10mm?
    Dec 1998
    The QR skewer itself has a 5mm shaft (front and rear).
    As stated previously in this thread, and in a few hundred other threads, the axle ends for "standard" open/QR dropouts/hubs are 9mm front and 10mm rear. There is no 9mm rear and no 10mm front.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    That clarifies everything, thanks!
    Feb 2006
    If we're talking about one of the best rim brake hubs made, and that Specialized used, it's the Stout hub with Skraxle 9 mm skewer. Very smooth and stiffens up the front end quite a bit. I believe these were made by Hugi (see pic attached)
    Or, disc version:
    Specialized Stout Downhill Disc Brake Front Hub | eBay
    Reputation: onelovetony's Avatar
    Nov 2012
    Question on Skewers
    I just bought a 2012 Diamondback Response XE. The skewer on the front wheel looks VERY similar to this one here. Do you guys think it will work? I ****ed mine up... It's on wheelbuilder.com
    Dec 1998
    Quote Originally Posted by onelovetony View Post
    Looks like which one?
    Will bet you have standard QR skewers. Go see your LBS.
    mtbtires.com
    Nov 2012
    I'm new to this site, so I can't send a link unfortunately. But it is the DT Swiss RWS Steel MTB skewer. 5 mm. My bike is a 2012, and it looks like 5mm is the standard. I'm really new to biking, so I'm trying to learn quickly.
    Dec 1998
    The DT is overkill and can be finicky. Just get a Shimano skewer and have your LBS show you how it works so you are safe and do not damage it.
    mtbtires.com
    Sweat is just fat crying.
    Nov 2003
    Quote Originally Posted by aohammer View Post
    Stay away from the Stout rear hubs. Mine blew up way too soon. I talked with a friend of mine who works in the industry and he admitted they were/are weak.
    Information on the trails at New Hogan Lake, Calaveras County, CA.
    Nov 2012
    I appreciate the help. Thanks!
    Doom On!
Hot Deals
Contests
Latest Mountain Bike Articles
