Results 1 to 29 of 29
    Dec 2012
    Single (1x10) Chainring Options (Wolf tooth, Race Face, etc)
    So, this single chainring aftermarket is heating up with Wolf Tooth, RF, Absolute, etc., now in the market. Are there any design/production/quality difference among these products? What makes WT's chainrings different from those of RaceFace?
    Just curious.
    Reputation: kubikeman's Avatar
    Jun 2010
    Wolf Tooth Components:
    Small US based.
    Only make chainrings (for now).
    Offer chainrings in a variety of styles to fit spiderless cranks and standard bolt on.
    You can order direct.
    Race Face:
    Large corporate company based in Canada.
    Manufacture a variety of awesome parts in many colors.
    Only offer these rings in a 104 BCD configuration.
    Costs slightly less due to mass production.
    FWIW I have a Wolf Tooth 32 and it's awesome.
    The cake is a lie.
    May 2013
    Just ordered a race-face. Trying to keep costs down and not running a chain guide too. Did anybody step down from a 3x10 setup? If you removed links from chain, how many?
    Noobish
    2013 Cannondale Trail 29er 1
    1990ish Specialized Hardrock
    May 2013
    Doing more research I think i might need a jump stop since i have an xt shadow long cage without a clutch derailleur. I'll try without and see how the new style teeth on the raceface do at chain retention. Then I'll go from there with other chain retention tools, or think about upgrading to zee show plus derailleur.
    Noobish
    would love a ride report on the non-clutched version as I'm thinking of doing the same.
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Dont forget Blackspire and RotoЯ which I really like but only available in 34 104 and not cheap
    used to be RipRoar
    Sep 1999
    wild times
    Wolf tooth CR are awesome. They are a few bucks more but made in the USA and excellent customer service. The website is very easy to navigate through making ordering a breeze. This company is great!
    May 2013
    Long term report.
    Raceface 34 tooth
    Hardtail 10 speed.
    Stepped down from 3x10 with no bash guards.
    FSA chain. Did not remove any links.
    Xt long cage non clutch.
    Zero drops after 3 months.
    Noobish
    Suprised no one has mentioned MRP, loving mine
    Jun 2013
    Has anybody used several different narrow/wide rings? I am curious how they compare.
    Oct 2010
    this is the one i use. its a 104 32 tooth and i was 1x9 but just switched to 1x10 today.
    SE Chain Ring, 32 - 48T, Bolt Center Diameter: 104mm
    wild times
    I initially bought a Wolf Ring 32T but needed a little smaller ring. I bought a Race Face 30T; I had great luck with both.
    Reputation: pablobell's Avatar
    Oct 2013
    Seem to be some non narrow/wide references creeping in here to confuse things. Anyone got a link for the RotoЯ ?
    Rotorbikeusa.com they don't make a standard nw, just a narrow wide q ring that needs the corresponding spider to work on either their cranks, sram x9, x0, x01 or xx1 cranks or s-works cranks.
    A few of my shops team members as well as a friend of mine all run it, 34 and 36t versions. Dero chain drop and awesome performance
    Reputation: TwoNin9r's Avatar
    Jan 2011
    Sub
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Unpredictable
    Reputation: Ridnparadise's Avatar
    I have been very happy with my limited time on a race face narrow/wide. I have a zee clutch derailleur, but it has not thrown a chain even running the clutch off.
    Jan 2011
    I have been running my rf narrow wide with an xt rear Derraileur and I just realized I've been running the clutch off the whole couple months and still haven't thrown a chain (and I ride hard)
    Posted via mobile
    Last night I witnessed a young fella carrying his bike back to the parking lot where I ride. He was running a Raceface N/W (didn't notice the tooth count). The ring had taco'ed. He was a large guy, (guessing 6'2", 230#) so he can put a lot of torque on the drive; but that was enough for me to try the wolftooth as my first attempt at this single ring endeavor. I did speak with him and he was not deterred from Raceface (said he had a ton of miles on the ring) and had already ordered another via his phone. I wanted to know more but it was already getting dusk and it was gonna be my first ride at night...
    I've been using a raceface for almost one year, never dropped a chain or had issues. They do have less to them than the wolftooth but from what I've seen the wolf tooths wear out faster. I would think It would be pretty hard to bend one, maybe with a horrible chainline but even then under typical riding situations even being a bigger guy I can't see them bending easily. I'd think there was an external factor that the guy either didn't mention or wasn't aware of. I have seen a few bent chainrings but most were bashed against rocks, one was from a combination of improper front and rear simultaneous shifts and it was some bootleg oval ring replica out of stamped aluminum so was pretty easy to bend even by hand
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Good results so far with North Shore Billet direct mount chainrings on 2 bikes. One single speed one geared.
    No moss...
    Reputation: Chippertheripper's Avatar
    Sep 2014
    Nice bump.
    Did it pretzel from pedalling or smashing off obstacles??
    Quote Originally Posted by Amazed View Post
    Reputation: borabora's Avatar
    When I built my last bike I configured a 1x10 setup with a spiderless Home Brew Component chainring (took about 8 weeks to get it but I was in no hurry). With no chain guide but a clutch rear derailleur (x9) the configuration worked pretty well but I dropped my chain on bumpy descents. It seemed to get worse over time as I started dropping the chain maybe once every 20 miles or so.
    Ordered a Wolf's Tooth spiderless 32t along with a 40t cog for my SRAM cassette. Pretty darn expensive! I haven't dropped my chain in 1200 miles. Runs quiet, no sign of worrisome wear and 100% reliable. While costly I'd replace with Wolf's Tooth again when the time comes.
    Quote Originally Posted by Chippertheripper View Post
    Nice bump.
    Forgot to say that he did report breaking a chain ring bolt so I' thinking that was where the failure started. It may have been over torqued, loose, or something. But since he was getting another just like it, that says a lot.
    The perfessor
    Reputation: mr_chrome's Avatar
    Jan 2005
    ok, running AbsoluteBlack's W/N 64 BCD 26T Chainring (yeah, I'm an old guy who rides in the mountains)........in 8 months of riding, only thrown the chain once......otherwise, been FLAWLESS going to 1X10 XT drivetrain (using an XT double-crank with a bashguard on the biggest ring).......running OneUP's 42T on the rear, definitely a sweet set up.....
    Rigid 29er Ti SS / 29er SC Tallboy AL
    Quote Originally Posted by runningwild View Post
    I did exactly this a while back. Both run fine, no issues at all. I'm pretty sure I haven't dropped a chain with either, running both with a zee short cage clutch type rd on my FS trail bike.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    OneUp entered the single NW chainring market today.
    OneUp Components US - Narrow Wide Chainrings (104 BCD)
    Mar 2013
    Quote Originally Posted by mr_chrome View Post
    Same but 28T and 11-36 cassette
    Reputation: Rynee's Avatar
    Aug 2014
    Quote Originally Posted by HitmenOnlyInc View Post
    Already ordered taking advantage of the 20% discount offer i orderd a 32 and a 34 tooth ring. And a 42t sprocket. And a kmc chain
    On topic: i'm running a 30t race face nw ring with x7 non-clutch derailleur and 11-32 cassette on my honzo. No dropped chain in 6 months.
    as the rf ring is quite pricey, i added a bash guard to the lineup, compromising the weight savings and optics a bit
  1. 28 tooth single chainring
    By peterk123 in forum 29er Bikes
    Last Post: 04-17-2016, 12:03 PM
  2. What 10 spd chain with new Wolf tooth chainring?
    By nndo in forum General Discussion
    Last Post: 05-04-2013, 11:15 AM
  3. Replies: 18
    Last Post: 12-11-2012, 01:29 PM
  4. Single chainring options?
    By Nockpoint 01 in forum Fat bikes
    Last Post: 09-26-2012, 08:25 PM
  5. single chainring for 1x10?
    By r1Gel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2011, 04:23 AM
Members who have read this thread: 7
