Results 1 to 20 of 20
    Short steer tube. Is it safe???
    My steer tube was cut too short on a used yelli screamy that I bought by the previous owner . It worked with his small stem but I needed a stem with more rise and the new stem is about 40 mm high while the steer tube is about 30. So the second bolt on the stem is just over the end of steer tube. But the headset does fit fine on top and cover it. It's tight and not moving. I bashed it around outside and it's tight
    Just want to see what you guys think. Most impacts should push down on it so it should be fine right?
    Not an expert but from what I've heard its not recommended to have the top bolt of stem above the steer tube. Maybe find the similar stem you were using before with the rise you need.
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    ^^^^ he's right, the top bolt should be over/border the tip of the steer tube. This question comes up
    every month or every 3 weeks. Anyways try this stem, I bought 3 of them because they are low profile at 35mm tall. Good luck
    Race Face D2 Stem > Components > Handlebars and Stems > Stems | Jenson USA Online Bike Shop
    meanwhile other threads among dozens about this:
    Steerer tube little too short?
    http://archive.mtbr.com/12/0EF54D5B.php
    Looking at it again th bolt is barely above the tube. Maybe 2 mm. Looks worse because the stem continues for another 5 to 8 mm
    Still not perfect though I guess
    Life Is Short
    Mar 2006
    if its barely above the tube then it should ok, the clamp should be secure, the rest of the hollow part of the stem to the top cap is meaningless
    Feb 2005
    Get a single bolt stem like the Kore Race. The single bolt sits in the middle of the stem, so it'll definitely be below the top of your steerer tube.
    Live 2 Ride
    Reputation: Kona0197's Avatar
    You could get one of these if your worried about a loose headset while running that stem.
    Sette RS-D230 Headlock at Price Point
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Is it possible you could swap in your old stem that fit and get the height you need using a riser bar? Just a thought.
    I don't like to compromise on the stem/steerer interface. I like 100% contact and run one spacer above the stem in order to achieve that.
    May 2012
    probably not
    Reputation: Spinning Lizard's Avatar
    The cost of being wrong, IMO, definitely outweighs any thought of using it like that. Seriously, if that were to fail during a jump or at speed, we might not see you again.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by surftime View Post
    Not safe - as everyone has said.
    Best to get your bars up via riser bars and stick to a stem with the 30mm of length that clamps to the steerer tube (hunt and search for another similar stem with the degree of rise you need). You should be able to find a stem/bar combo that will get the bars where you need them compared to the previous owner. Other than that - you'll have to get a new fork (or at least new uppers with an uncut steerer tube).
    Here is a picture - top bolt is right there actually after tightening up
    Thanks for the tips guys
    Its a two bold stem, so one bolt at the bottom is fine ofcourse and then one at the top is just at the steer tube. In that case why would a one bolt stem be better?
    How about a longer headset bolt? Doesnt that bolt give that extra support to the top?
    Look at the pic below to gt an idea of how it looks - looks better to me now that the headset is tightened down.
    Its a somewhat different short high rise stem to get me the right positioning
    http://forums.mtbr.com/attachment.ph...1&d=1337954405
    Attached Thumbnails Attached Thumbnails Short steer tube. Is it safe???-stem.jpg
    It could hold. It might not hold.
    Best bet would to get a lower profile stem.
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    NOT ok in my opinion.
    "...like sex with the trail." - Boe
    nobody
    Reputation: wookalar's Avatar
    I'd look for a different stem.
    I don't have an engineering answer for you on why a one bolt stem that clamps below the top of the steerer tube is better than your set up with the lower bolt o.k. and the top bolt questionable but my opinion would be that a one bolt stem is designed to securely clamp with one bolt. A two bolt stem (presumably) is designed for both bolts to be functioning for it to clamp correctly. Again, just my opinion. Like someone else said, it might hold....it might not...
    I'm what Willis was talkin' about
    conjoinicorned
    Reputation: ferday's Avatar
    hard to tell from the picture, but the way it looks to me i'd run it no problem. the stem bolts don't just pinch in the immediate area of the bolt, there is some amount of area that is pinched and IMO 2mm would be in that safe zone.
    again - i'm just a guy on the net looking at a not great picture so don't take it for the gospel...but i've run plenty of setups where the top of the steer is really close to the top bolt...i'm running one now on my AM bike (it's about 2mm from bolt center to steer tube) and i personally have no worries at all.
    what would rainbow unicorn do?
    Again got to ask your self if a broken face, arm, leg is really worth it. If it is go ahead and use it. But it is definitely not OK. Might work, might not, but it will be a big problem if it does not work out. Assure it will costs more in medical bills then a different fork or stem would.
    Quote Originally Posted by Kona0197 View Post
    i believe that's an alternative to star nuts and expansion plugs. it is not an alternative to a properly installed stem.
    to the OP. obviously that's not good and the proper solution is to use a smaller stack stem, shorter headset, or replace the fork. of course, replacing the fork is cost prohibitive, and it looks like the frame uses an internal headset, so you pretty much have a single recourse.
    if you have to sacrifice stem angle for proper fork clampage, you can get back to your bar height with a hi rise bar. ideally, the steerer actually extends beyond the stem and proper compression is acheived with a 5mm spacer on top of the stem. of course, that's tough here, so your target should be to at least get the tops of the steerer and stem to be flush.
    here's a thread with a couple 30mm stack height stems.
    http://forums.mtbr.com/29er-bikes/st...ht-680742.html
    fwiw, ymmv and all that......
    thanks, im going to dig around for some different stems
    Quote Originally Posted by vqdriver View Post
    empty beer member
    Reputation: WrecklessREX's Avatar
    There are a few 1-1/2" to 2" riser bars out there if you need to get the bars up with a low rise or zero rise stem.
    I am currently running a Chromag Ranger 0 degree rise stem with a 30mm riser bar on my Nimble 9 to get the bars where I need them. FYI, the Ranger is only 28mm from the bottom to the top of the top bolt.
    It also looks pretty!
    Its not so much of an issue with the stem just flying off as it is letting the steer tube twist inside of it while your still holding the bars in the direction you want to go. This happened with the Thompson Elite stem and steel fork while going in to a rocky creek crossing, never knew what hit me till I looked at the bike and the wheel was turned 90* to the bars. I'm still using the same fork and haven't had a problem since I put the Chromag on.
Members who have read this thread: 9
