Results 1 to 12 of 12
    Apr 2013
    Shimano deore m581 front derailleur
    Hi all, I've been fine tuning my 2007 stumpjumper comp, and at best the front derailleur (shimano deore m581) scrapes on the derailleur cage when on the large chain ring and smallest rear cog, and the smallest chainring and two largest rear cogs. I've followed a bunch of good forums and instructional videos, but it seems physically impossible for me to tune the front derailleur to not scrape... ie. the low limit screw is screwed in as far as can go (as close to bike as possible) and it still scrapes on the small chain ring and largest two rear cogs. Some people suggest this is normal for some derailleur / shifter brands. Does anyone have any recommendations for replacement derailleur / shifters? My shifter is sram x7. Cheers.
    B A N N E D
    Apr 2013
    On the derailleur cage.
    B A N N E D
    Quote Originally Posted by Johnmatrix View Post
    Inside ? Outside ? Bottom ?
    Apr 2013
    Inside of the cage on the small chain ring and largest two rear cogs, outside of the cage on the large chain ring and smallest cog. I fiddled with it for about 6 hours this weekend, and pretty sure it can't be adjusted any better. I read on another thread on a site that some of the cages are a bit tight, and that it is impossible to eliminate all chain rub.
    B A N N E D
    When the chain is on the small chainring/large rear cog can you push the deurailleur cage inwards any further by pushing on it with your fingers ?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Yes, traditionally it is difficult to impossible to set it up with no rub, even if you do it all correctly. The front derailleur is mechanically inferior to the rear, in terms of function. Shifting across 3 gears with with a front derailleur is just too much for the other constraints. This was figured out a long time ago, and a relatively good solution was the SRAM micro-adjust front gripshift shifter. This would allow you to twist it enough so it changed gear, and then back off one or two so it wouldn't rub. Really, that's what it takes to do it perfectly every time. The way we set up traditional shifters and derailleurs is usually so they only rub or slightly rub in the gear combos that you are least likely to be using.
    Jun 2012
    you should have no rub on middle ring and all gears in the back. When using large ring in front, rub is expected using first second or third largest in back(cross-chaining don't do it)
    Same for when using smallest in front, the three smallest gears in back might give a slight rub.
    What you experience is not normal, try to bend the cage and see if you can improve on it.
    Did you try to rotate the derailleur around the seat tube?
    Apr 2013
    No. It's rock solid
    Apr 2013
    Quote Originally Posted by Learux View Post
    My situation is as you describe in your first paragraph. No rubbing in the middle chainring. Thanks for your reply.
    B A N N E D
    Has the derailleur taken any hard hits that could of knocked it out of shape ?
    Maybe post some photos of it.
    Apr 2013
    Quote Originally Posted by cobba View Post
    I bought the bike second hand, but it is in excellent condition. The derailleur looks fine. Photos are a bit hard to see, but the cage / guide looks fine.
  1. Shimano Deore XT - GS or SGS derailleur
    By miguelbasora in forum Beginner's Corner
    Last Post: 05-06-2013, 11:26 AM
  2. Derailleur which one? SLX RD-M662/Shimano LX M581
    By Chillout in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-22-2012, 07:08 PM
  3. Replace Shimano Deore LX rear derailleur
    By bbqdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-24-2012, 05:53 AM
  4. Shimano Deore rear derailleur
    By MiGSPiNe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 11:06 PM
  5. Shimano Deore Shifters with XT Rear Derailleur?
    By marpilli in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2011, 08:03 PM
