Results 1 to 5 of 5
    shimano brakes SLX / XT
    Looking at replacing my elixer 5 brakes. What is the difference between SLX M666 and the SLX M675 (both ice tech)? Also I pretty much see only a 4 gram less weight on the XT M785....any other differences? Also do I need post adaptor or IS Adaptor on my 2011 Fuel EX8 with fox shock? It looks like blue sky is the cheapest price and availablility. Should I replace my Avid rotors too?
    2017 Santa Cruz Tallboy CC
    Rotors should be fine unless you feel grooves or they squeal like crazy. I hear slx is best bang for your buck and is not very different from xt aside from bling factor. I went with Hayes after a very troublesome pair of elixirs. I will never use avid brakes again (crotch bb7)
    My rotors seem fine. No squeeling and I have yet to even wear out one set of pads. As far as price I am looking at $40 more (front and back) for the XT vs the SLX M675. It turns out the M666 dont have the rear brakes available. I could use the $40 towards a SLX plus rear derailer upgrade over my regular SLX derailer.
    Quote Originally Posted by stygz1 View Post
    I upgraded my elixir 5s a week ago. I kept the rotors and they worked fine. Dont know the difference between slx and xt, but from posts I read while I was doing research, they are about the same.
    I used the same adaptor that came with my elixir 5s for my tallboy carbon ltc.
    I was probably going to use my original adaptors...so I guess that does not matter....just get the 180 front and 160 rear. Did you have to shorten the hoses? How does that work?
    What did you upgrade to?
