Results 1 to 57 of 57
    Reputation: rickcin's Avatar
    Seatpost marker?
    Is there a good way to mark a seatpost so you know where to reset after removing it from a work stand?
    Reputation: theMeat's Avatar
    Put a scratch on it
    Round and round we go
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    I use tape
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    I use a black marker. It's easily visible on the black post.
    Reputation: GhostRing's Avatar
    Feb 2012
    Dremel
    (marker)
    Time wounds all heels...
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    Some simple electrical tape will work just fine. A lot of pro teams do the same thing, so that's how you know it's legit.
    Sometimes, I question the value of my content.
    Quote Originally Posted by rickcin View Post
    I used to work on a lot of high end road bikes. General rule of thumb: don't mess with seatpost adjusment.
    If its your own bike go right ahead, but if you're working on another's they might get finnicky if they see you changing seat height. It sucks to be on a 200 mile road ride and feel distracted that your post might not be exactly where you want it.
    Of course most mtbers are less concerned since post height is often a compromise involving more than just putting the power down. I've wondered about an alternative to scratching your post when you want to drop it for a climb and bring it back to the right height afterwards. Tape won't make it in and out of the seattube.
    Jun 2012
    My seat post has numbers on the back. I can't be the only one.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Put a piece of tape on the post and remove it. Use a spare post to secure in the stand.
    Trailhead Poseur
    Reputation: jjaguar's Avatar
    Oct 2011
    Temporary? A bit of masking tape. On my own bike, I've made a line on the tube with a silver Sharpie since I usually drop the post an inch for technical trails. It lets me consistently reset seat height after the ride.
    I leave all seats at one height, just need to raise the post when putting them in the work stand to wash the bike, lube the chain etc.
    Reputation: JSumner13's Avatar
    I put a small scratch on mine with the edge of a file (Thomson). All the carbon posts I have have number markers.
    Markings or some sort of decal would be good!
    Carbon or Commie?
    Reputation: axisofoil's Avatar
    I use a scribe to etch a line.
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    If I put my pinky on the collar used to tighten the seat and stretch my fingers apart certain amount, the distance between my pinky tip and thumb tip is dang close to where I like it. That's how I used to do it. Now that I have a dropper, I'm a little out of practice.
    Reputation: random walk's Avatar
    Tighten a zip-tie around a saddle rail, cut off the end where it touches the top of the seat tube when the saddle's at the desired height. Tuck the zip-tie up under the saddle when not in use.
    I could cut a small piece of a wood dowel or tubing to use as a template when removing the bike from the work stand by nothing would be faster than a visual!
    You might as well use a tape measure, and fwiw a marker won't work with the grease that should be on the post involved.
    How about a hacksaw???
    Wow, very clever though, a pre-attached template!!!
    Viva la Vida!
    Reputation: Camaleon's Avatar
    Seatpost marker?
    Quote Originally Posted by jjaguar View Post
    ^ Mark with a silver sharpie
    We do not stop playing because we grow old;
    We grow old because we stop playing
    I think that is less destructive than marking with a hacksaw, or drilling a hole, not that I seriously considered either scenario!
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Seatpost marker?
    Quote Originally Posted by axisofoil View Post
    This. Simple and permanent.
    Sent from my rotary phone and compiled with a telegraph machine.
    JPark - 3.5- don't listen to dremer
    Quote Originally Posted by theMeat View Post
    Put a scratch on it
    No, NO, no,, stress risers, specially dangerous on the front of the post (under tension, back under compression)
    Seatpost marker?
    Quote Originally Posted by patineto View Post
    Hogwash.
    If a seat tube can't withstand a surface scratch, it has no business being a seat tube in the first place.
    Are you really going to tell us that a seat tube can't be scratched? That you should replace a seat tube if you crash and scrape it against a rock? Does this same logic apply to all components? Like for example, fork legs?
    Seatpost marker?
    Quote Originally Posted by Ken in KC View Post
    Hogwash.
    Replace "tube" with post, please.
    IM not saying use a chainsaw. The post gets scratched from simply installing it. Using an etch to scribe a line is also putting a scratch on it.
    Reputation: ElDuderino2412's Avatar
    Oct 2012
    i just use a sharpie. It will wear off eventually. Just re-sharpie it after it wears off.
    I also mark my handlebars and stem(on bottom where no one can see) w/a sharpie line. Makes reassembling bikes from travel bags easier/faster.
    2012 Pivot Mach 429
    2010 Cervelo R3 SL
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by Dirty $anchez View Post
    Back in the day, when most seat posts were stout enough to hammer nails with, a scratch with an awl was the ticket but now a lot of posts (straight/non-dropper) cost more than my first mountain bike. The Dirty $anchez method mentioned above is the best.
    Seatpost marker?
    Quote Originally Posted by J.B. Weld View Post
    Must be turning in to a retro grouch. I've been riding the same seat posts for around a decade. They don't seem to be negatively impacted by the awl mark.
    Really, if a seat post can't withstand a scratch, should they be on a bike at all?
    Oct 2012
    not everybody has alloy posts
    2012 Pivot Mach 429
    2010 Cervelo R3 SL
    IMO, of all the various suggestions and there are many good ones, I like marking the seat post with a white or silver sharpie!
    Seatpost marker?
    Quote Originally Posted by ElDuderino2412 View Post
    Great point.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I run about 9" of seatpost extension. It coincidentally works out well - I typically pull out my trouser snake, place it next to the post and set my saddle height accordingly.
    Not everyone is so lucky.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    I wish I had a dropper post because a lot of my rides are on varied terrain. I'm not scared to adjust manually so I have three marks scribed on my post. The tallest line for smooth sailing, then one about a half inch lower and another an inch below that one. I'm usually wanting something pretty close to one of those lines, and I know exactly what each of them feel like, so changing the height is fast.
    I use the tip of a razor blade to scribe lines in my post. The teeniest tiniest thinnest line shows up forever, I hardly apply any pressure at all to the blade. Can't imagine that it would do any damage or lead to cracks, it's just an alloy post.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Permanent scratches affect resale of the post and future reference if you change saddles or shoes or pedals.
    I use a sharpee or tape but that Zip Tie idea is pretty cool too.
    Raised in a Chicken-Coop by Chickens
    Ever try a tape measure? They're amazing.
    Mar 2011
    you could always put the tape on before you remove the seat post, that way the bottom line of the tape is where it should be set, drop the seat back in, when it reaches the bottom of the tape, your golden
    Quote Originally Posted by mbell View Post
    That's only a good idea if I bring it up. lol, Plus tape measures can scratch. Best to use tailor's tape. Don't use a cheap one they can stretch and degrade over time. Yup, it's true
    You could secure the bike with the top or down tube ahda, and leave the serious business of moving the seatpost to qualified pit crew mechanics.
    Quote Originally Posted by senorjax View Post
    another, slightly heavier(and not without its own problems) approach is to use some cable crimper-do-hickies and set a derailleur cable going from your seat rails to your seattube clamp bolt. If you set it so the post is at the right height when you pull the cable taught, you can quickly return the post to its max height at the end of a descent for which you lowered the seat. a bit of security if you lock and leave your bike too. It also works well if you're 6 hrs in and its night and you can't reliably figure out where your mark is.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    call me old fashioned, but i just use the marks that occur naturally when a seatpost is actually installed. or i use the grease marks...
    regardless, it's not brain surgery. there is always an obvious mark of some sort that differentiates from the inserted and extended part of the seatpost...
    Quote Originally Posted by .WestCoastHucker. View Post
    there is sometimes an obvious mark of some sort that differentiates from the inserted and extended part of the seatpost...
    this is more like my reality. especially when you've had a post for more than one frame or you've changed pedals, shoes, saddles, etc and now your old mark is no longer the correct one.
    Pro Crastinator
    Quote Originally Posted by PretendGentleman View Post
    ...now your old mark is no longer the correct one.
    which is why you use the new one. pull your post out right now, there is an obvious insertion mark. be it from the clamp, grease or whatever, but snap a picture of it and i bet everyone on this forum can tell you where that point is...
    Mar 2013
    I use a silver marker, you can get it at any office supply store. Works great!
    So I guess you have a quick release seat post clamp?
    I don't understand..... why can't you just sit on it, and see whats comfy?
    Old Yeller
    Reputation: DMKiefer's Avatar
    I've always used a spring loaded center punch ( like the one to break tempered glass windows in an emergency) and put a single punch mark on an aluminum post right at the top of the seat tube and centered in the slot of the clamp/seat tube. This gives quick reference to seat height and centering. My carbon post all have scaled decals on them.
    May 2012
    Normally there have a mark come with the seatpost at the backside...
    Seatpost marker?
    Quote Originally Posted by DMKiefer View Post
    This is a great idea. Thanks.
    Reputation: bidaci's Avatar
    Quote Originally Posted by random walk View Post
    Great idea!
    Very clever!....You see, you ask, you get many answers that are similar and then one that no one else had thought of!
    I'm just messing with you
    Reputation: wv_bob's Avatar
    It's amazing how hard people will work to avoid just using a Sharpie to mark the thing
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    I ordered a white sharpie, I think that is the simplest and it gives several options as well.
    I just hope it lasts!
    this might be true if you raise the seatpost and don't have it clamped very long. Working at a shop, it's courteous to wipe grease off a post before you clamp it so the next person to use the stand doesn't get gooped, which often erases the mark. Even wrapping the post in a rag and trying not to wipe the mark off is likely to blur the mark or erase it, especially if you're doing something high torque like pulling bb cups, which is likely to lead you to twist the frame in the stand, obscuring the grease mark. Using a spare post is one option, but that doesn't work for everyone and you'd need a spare post for every size seatpost that you clamp in your stand.
    However, I was referring more to the issue of lowering the post for descents and knowing how high to raise it to. sliding the post down into the frame blurs the grease mark, doing this many times over the course of a few years leads to many blurred marks. To some extent this can be combated by cleaning the post, but some of the marks that will remain are from dirt grinding off enough finish to create a mark that is indelible.
    and responding to the idea of denting the post, the idea of denting my thomson post is unappealing because I might change my seatpost insertion with a different saddle, pedals, shoes, or as fitness, flexibility, preferences, etc. change over time. Not to mention the fact that I expect to use the thomson post for longer than I'll want to keep the frame.
    And to the poster who asked why we don't just ride what feels right: This is ultimately what happens, but stopping and experimenting with different positions is not what I want to do on every ride. Even if it feels right, it might feel better in a different position. If I'm on a 40 mile ride in the mountains with several 5+ mile climbs, I really really don't want to have any doubts about the optimality of my post height: it's like a placebo, I don't really know if my post height is optimal, but it's vital that I think it is so I don't go crazy when every muscle in my legs are cramping as I approach the top of a 7 mile climb at the end of the day.
    Tape measures leave room for error as does putting a piece of electric tape around the post. Did I measure to saddle rails, to top of saddle, etc? tape measures are inconvenient for raising your seatpost to it's full height after a descent. Tape measures are great for adapting a seat height to a new frame, but you expect to make minor changes to post height in the first few rides. If you're working on a cranky pro racer's $10k crabon bike and you raise their seatpost and assure them you've measured where it was so you can return it to precisely where they had it....good luck convincing that cranky pro that you've left no room for error. It's worse for roadies, but I never move the post if I can figure a way not to. Even with tape, one might leave the frame in the stand for a day or two and when you come back you can't remember if the tape was flush with the top of the frame or the top of the seatpost collar. It's only a ~1-2mm difference, but some customers find that meaningful. I am not that picky, but I found understanding when I had my own devilish mental experiences with cat 1,2,3 etc. climbs.
    For something somewhat permanent without scratching, silver sharpie on black. But use masking tape for nice professional looking markings. Nice narrow ring, looks factory made if done properly. I could never force myself to scratch a Thomson
    Quote Originally Posted by rjedoaks View Post
    So I guess you advise masking and then just sharpie in between the tape to get a nice straight line?
    Yes, if you just mark the back half of the post and do it neatly, you'll be surprised how clean it looks
  1. Bike + trail marker pics
    By abeckstead in forum Passion
    Last Post: 6 Days Ago, 05:48 PM
  2. Permanent marker for fork stanchion?
    By derby in forum Shocks and Suspension
    Last Post: 08-03-2012, 08:29 AM
  3. Hatman park Trail Marker Switch out
    By thomllama in forum Connecticut, Rhode Island
    Last Post: 06-10-2012, 03:26 PM
  4. Replies: 23
    Last Post: 02-13-2011, 08:52 PM
  5. Replies: 72
    Last Post: 01-10-2011, 06:20 PM
