Results 1 to 13 of 13
Thread: Seat Slipping
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Seat Slipping
    Anything I can do to keep my seat from slipping while riding? It drops 2-3" while riding and i usually have to dismount to raise it back to a comfortable level. I've tried tightening the clamp but don't want to over tighten it and possibly risk cracking the frame. I have a '12 Giant Talon 2 if that makes a difference.
    Reputation: theMeat's Avatar
    Before you go and buy a bigger, stronger clamp you can try carbon paste on the post, and put some grease on the bolt threads to make sure all the torque is being delivered.
    Round and round we go
    Oct 2012
    Re: Seat Slipping
    I'll give it a shot... Thanks Meat!
    Diggity Dog
    Reputation: ShinDiggity's Avatar
    Make absolutely sure the seatpost is the right diameter for the frame. It more than likely is (30.9) and then the carbon paste is what I would try first. If you need to try a new clamp I have found the Salsa brand to be a good replacement. If all else fails you can knurl the seatpost as long as the post is aluminum.
    Oct 2012
    Re: Seat Slipping
    I sure as shit hope it's the right diameter... It's stock! Lol
    Carbon prep should just about do it.
    Reputation: J.B. Weld's Avatar
    If the bike has a quick release binder then I would look at that. A lot of times the stock ones are pretty crappy and even though it seems like you're putting a lot of torque on the lever they still won't cinch down tight. I don't know what type or QR they use on that particular bike so that may not be the issue, but I have found it to be fairly common problem.
    Sometimes a drop of lube on the skewer pivot cam can make a world of difference, or as OhGee said a better one such as the Salsa can solve everything.
    Oct 2012
    Re: Seat Slipping
    I'll check out ebay and see if I can get one.
    Reputation: sgtjim57's Avatar
    My Camber came with a quick release clamp, it would "NOT" keep my seat where I wanted it. No matter how tight I clamped it down. Purchased an Origin seat clamp (bolt action) from LBS and have had "ZERO" problems sense. I am aluminum on aluminum so I can't speak for carbon.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    Dec 2012
    Luckily I don't have this problem, but it got me thinking about how I grease my seat post, who here greases their seat post? and why?
    I do it to get rid of creaking noises.
    Quote Originally Posted by tim_from_PA View Post
    Sure do. But I wipe it off before inserting it leaving only a very small amount on the post. I also clean the tube where the seat post is inserted (inside the tube) at the same time.
    It is a must do unless you don't mind your post will get stuck.
    Metal to metal = grease
    Carbon to carbon = carbon paste
    Metal to carbon you can go either way.
    Quote Originally Posted by theMeat View Post
    ... and put some grease on the bolt threads to make sure all the torque is being delivered.
    Thanks -- I did that and it solved my problem too.
    I use a torque key to make sure I am getting it tight enough -- that worked for a while but started slipping recently. Applied a little grease to the bolt, have ridden the hell out of it all weekend, and it hasn't budged!
  1. Thomson seat post slipping [YS]
    By cruiserman in forum Canfield
    Last Post: 10-19-2013, 05:05 AM
  2. My seat post keeps slipping......
    By honkylipz in forum Specialized
    Last Post: 09-07-2013, 03:58 PM
  3. 429 Seat Post Slipping
    By edbraunbeck in forum Pivot Cycles
    Last Post: 10-28-2012, 09:45 AM
  4. Seat Post Slipping
    By aroundoz in forum Motobecane
    Last Post: 09-20-2011, 01:33 PM
  5. EMD9 seat post slipping
    By pstaff15 in forum Niner Bikes
    Last Post: 08-02-2011, 01:17 PM
