Results 1 to 9 of 9
    Apr 2013
    Seat falls during rides...
    On my new MTB, the seat drops a few inches after about 30 minutes of riding. I have the QR and as tight as I can and still be able to open it without tools. Anything else I can do to stem the slide?
    I'm SUCH a square....
    Reputation: bigpedaler's Avatar
    For a quick fix, take the post out and rub dirt on it, put it back in and crank 'er down.
    For a BETTER fix, replace the QR seat clamp with a bolt-style.
    Double-check to make sure you have the size you need. 1-2mm too small IS possible (for example, Surly usually calls for a 29.8 post, and my Kona takes a 30.0).
    A bike is the only drug with no bad side effects....
    Carbon prep-compound instead of grease is probably the easiest (cheapest) fix.
    Like pedaler said, a bolt-style clamp (or a better quality QR type) would also probably fix the problem.
    Reputation: theMeat's Avatar
    In this order try,
    A dab of grease on the qr or bolt so you make sure torque is being delivered.
    If not, yup, carbon paste on the post.
    If not, yup, stronger clamp.
    Round and round we go
    Reputation: thickfog's Avatar
    Oct 2010
    Re: Seat falls during rides...
    Carbon prep the post or use powdered chalk. Both work well.
    CRAMBA Chairman
    since 4/10/2009
    Reputation: Harold's Avatar
    I addition to what has been mentioned
    Clean the post AND the inside of your seat tube.
    Also make sure the gap in your clamp lines up with the slit of your frame's seat tube
    MTB B'dos
    Reputation: LyNx's Avatar
    Also if all that fails, drink a can of soda, cut a nice shim from it, insert shim, problem solved if you really have that much tolerance difference.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by bigpedaler View Post
    ^^ If you hate your bike.
    If your bike has a QR I'd give 80% odds that Meats first suggestion will cure the problem, and the other 20 that a better QR (or bolt) will.
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by theMeat View Post
    In this order try,
    Ditto.
  1. Closest Rides to Great Falls, SC
    By Sarguy in forum North & South Carolina
    Last Post: 03-31-2012, 07:07 PM
  2. Looking for Good Rides Between Idaho Falls and Jackson
    By rpalmer in forum Idaho, Montana, Wyoming
    Last Post: 09-23-2011, 07:49 AM
  3. Anyone rides Cascade falls on Olean street?
    By danwrzesinski in forum Massachusetts
    Last Post: 09-16-2011, 06:30 PM
  4. Replies: 11
    Last Post: 09-02-2011, 12:41 PM
  5. A downhiller rides Salmon Falls trail
    By flowmaster in forum California - Norcal
    Last Post: 04-13-2011, 11:22 AM
