Results 1 to 6 of 6
    Custom User Title
    Reputation: dr13zehn's Avatar
    Salsa Pro Moto Flat Bar with 17deg bend
    Has anyone tried this bar? Aluminum or Carbon. How are you riding impressions with that kind of bend?
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by dr13zehn
    I've got the Moto Ace 17 degree bend bar. It's a comfy bar. If you are considering the bar, just make sure to factor in the amount of bend may require you to use a longer stem to dial in your fit. Riding impressions? It's a fun bar which you immediately adapt to once the reach is dialed in correctly. I raced XC on it for the 2009 season and enjoyed it.
    <a href="http://www.flickr.com/photos/7166535@N05/3243933869/" title="Shot4 by singingsingletracker, on Flickr"><img src="http://farm4.static.flickr.com/3334/3243933869_1e1b191f2e_b.jpg" width="760" height="1024" alt="Shot4" /></a>
    BB
    Former Bike Wrench
    I enjoy mine quite a bit. I required a 15mm longer stem over what I used with a 9* bend bar to keep my reach the same. It took me all of a mile of riding to adapt to it. I have virtually eliminated wrist pain and greatly reduced hand pain (combined with Ergon EX1 grip).
    Custom User Title
    Thanks for the replies guys.
    I was actually thinking about getting a 90mm stem a while ago to replace my 100mm one. I will just try the bar with the 100mm and see how I need to adjust from there.
    More sweep is even more comfortable. Lots of 25-45 degree baclsweep bars available now due to demand. Bruce nailed an important ingredient. Be sure your range of stem length increase required can accomodate the associated backsweep to keep your reach the same which is as important to comfort and performance as handle end angle.
    Dec 2009
    Quote Originally Posted by dirtrider7
    More sweep is even more comfortable. Lots of 25-45 degree baclsweep bars available now due to demand. Bruce nailed an important ingredient. Be sure your range of stem length can accomodate the associate backsweep.
