    Apr 2013
    Rotor convertions
    Morning,
    I need a new set of rotors and I'd like to try up sizing 160 to 180mm. Can a Marzocchi FXR Pro 120mm travel shock, off a Kona dawg 2005 fit a 180mm rotor? And if so do I need a spacer ?
    Thank you
    B A N N E D
    Never heard of that fork model but you will need the correct adapter to up size to a bigger a rotor.
    Brake Time
    you should just need the rotor and the spacer for caliper.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    just make sure the adapters are F=front and R=rear for whatever size rotor you choose.
    "ORANGE IS THE NEW BLACK"
  1. Rotor convertions
    By speed mulisha in forum All Mountain
    Last Post: 06-04-2013, 07:45 AM
  2. Replies: 9
    Last Post: 04-01-2012, 12:18 PM
  3. Replies: 9
    Last Post: 12-29-2011, 05:47 PM
  4. Replies: 39
    Last Post: 05-25-2011, 06:14 PM
  5. Need rotor advice from Marta SL/storm rotor users
    By Shuteye in forum Brake Time
    Last Post: 02-14-2011, 02:58 PM
