Results 1 to 8 of 8
    Jun 2014
    RockShox Reverb Dropper seat post issue
    Just purchased a used dropper on ebay, guy said it worked fine. But it on my bike and it won't go up...
    any help would be appreciated....
    thanks,
    brian
    Jun 2014
    doesn't move if I have it out of the clamp either.
    Was it collapsed when you received it?
    Googling around, it is supposed to have 250 PSI of air in it. There is a valve in the bottom of the post. You could check the pressure with a shock pump. However, if it has leaked then I assume you will want to send it back.
    Jun 2014
    it was collapsed when I received it, I don't have a shock pump but I guess I could try a bike shop.
    Jun 2014
    I had a gauge that went to 160 and thought I would try that and it didn't have anything in it. It was leaking oil out the bottom as well. Does anybody know a good place to send it for a rebuild or is that going to cost more then just getting another one?
    Jun 2014
    just got a pump and pumped it up to 250psi and still will not go up. Looks like a rebuild will run about $100.
  1. Replies: 38
    Last Post: 03-04-2017, 12:00 AM
  2. need dropper help-- KS lev and rockshox reverb
    By Couloirman in forum General Discussion
    Last Post: 03-15-2014, 07:50 AM
  3. Dropper post--Fox DOSS or RockShox Reverb?
    By Alias530 in forum Clydesdales/Tall Riders
    Last Post: 12-05-2013, 07:57 PM
  4. Need help dropper seat post rock shox reverb
    By stephanmoll in forum General Discussion
    Last Post: 10-13-2013, 09:05 PM
  5. Replies: 2
    Last Post: 08-13-2012, 07:01 PM
