Results 1 to 14 of 14
    likes bicycles
    Reputation: vitale232's Avatar
    Rocks Creepin' in the Brush
    I've been having an awesome season of riding. Cleaning all the technical stuff, the lungs and legs have come around and I'm climbing well, loving all the trails in my new area. I just feel really good on the bike.
    However, I've had two major falls this season. I've broken two sets of pedals this season. Both incidents were whipping fast down some singletrack, entering a subtle turn, whacking the pedal off a rock draped in manzanita, and flying spectacularly through the air.
    I've been trying to be more aware of what's hiding in the brush and generally keep the inside pedal up on corners. Obviously, slowing down will help - but that's not happening. Any other tips for avoiding the "lurkers"?
    Every thread needs a photo.
    Jun 2012
    Be heavy enough to crush the rocks.
    You could also try slowing down as it might save your from dying or becoming a quadriplegic.
    Reputation: Tystevens's Avatar
    Put your pedals at the 3-9 (horizontal), instead of 6-12. You won't hit any rocks in corners with them.
    '11 Specialized Enduro Expert for the trails
    '13 Felt Z4 for the road
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I know what you're talking about sort of. Here it's roots hiding just off the edge of the trail that stop your front wheel dead. Ooof. Try staying in the middle of the trail, it helped me.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    likes bicycles
    I'm not really trying to gain any weight or slow down. Although A would probably take care of B in that scenario...
    I had been dropping the outside pedal in an attempt to better weight the bike. I guess I'll have to learn to do it with horizontal pedals. Center trail certainly couldn't hurt as well. Thanks
    El Gato Malo
    Reputation: Wishful Tomcat's Avatar
    Quote Originally Posted by Tystevens View Post
    Unless it's winter time, then your pedals will be set at 2-8.
    likes bicycles
    Quote Originally Posted by Trail6 View Post
    i.e. riding on snow? Why?
    El Gato Malo
    You lose an hour in the winter when daylight savings time ends
    likes bicycles
    hahah touche
    I didn't do it
    Reputation: Mookie's Avatar
    I think you'll find that the horizontal pedal position will help you navigate corners better as well so you get double benefit.
    Sometimes I hit hidden little stumps off to the side of the trail. It's a real surprise when I'm just riding down the trail and out of nowhere there's this big jolt.
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    You can still put most of your weight on the outside pedal with outgoing all the way to 6:00. Pointing your inside knee towards the exit helps underweight the inside foot.
    YOUREGO ISNOT YOURAMIGO
    Reputation: GoGoGordo's Avatar
    "I'm just a big turd of misery"~ DV
    likes bicycles
    The NorCal thread is awesome. Thanks for sharing that.
    Self Appointed Judge&Jury
    Oct 2000
    A 3-9 position horizontally is an impossibility with a "normal" crankset. I think you mean keep them at a 11-5 position horizontally. This of course is in correlation to the frame being the 12 position in front and the 6 position to the rear. Just saying! Oh and also this technique only works if you coast through all of your corners.
    Quote Originally Posted by WHALENARD View Post
    No way man! The great Vans debate of 18 was epic!
