Hi guys.
I was doing some maintenance to a powertap freehub body and a regular (no power) body from a sun ringle wheelset. Well, I see that using just some quality motor oil for the sun ringle wheelset could do the trick, but I want to know if I can use this same procedure for the powertap unit or could I use the mentioned grease above...It`s black and stays literally where you put it. I have used it for installing enduro fork seals, only for that but I don`t see why it could not go at the spring-pawls. It`s not sticky as the other alternative I have (finsih line white-teflon based grease) and seems from good quality.
Do any of you guys, have experience about it?
Thanks a lot
