Results 1 to 5 of 5
    Reputation: xycarp's Avatar
    Riser bar vs. riser stem and flat bar
    I need to raise my bar a couple centimeters. What are the advantage over one approach over the other...
    -5 degree stem with riser bar
    vs.
    +20 degree stem with flat bar
    Which approach is better? Does it matter?
    Reputation: theMeat's Avatar
    As long as the grips end up where you want it don't matter, althou stem length as measured from center of steerer tube to center of handlebars, regardless of rise, will effect steering speed. So if you're going with more rise you need more length to get the same distance from steerer to bars.
    Bar width will also effect steering speed, and the more difference there is between bar width and shoulder width, the more it effects reach.
    Might wanna try some spacers under your current stem first, if there's room.
    Riser bars will allow you some adjustment by rotating them. The greater the rise, the greater the amount of adjustment. Sweep, and the more you have may limit that.
    With a stem all you can do is flip it.
    Round and round we go
    Sweep can be more important to your wrist comfort than you think and is hard to get with a flat bar. You also get tilt up maybe 4-5 degrees besides the 6-12 degrees of sweep back and the 15-25mm or more of rise.
    251 is offline
    Reputation: 251's Avatar
    This is all true. One advantage I've found with risers is that I can flip the bike upside-down and the ends of both grips touch the ground instead of the bike rocking on the stem. That said, I currently have flat bars (On-One Fleegle w/ 15° sweep) on both of my MTBs.
    Dave
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by theMeat View Post
    Riser bars will allow you some adjustment by rotating them. The greater the rise, the greater the amount of adjustment. Sweep, and the more you have may limit that....
    ^^^This
    Flat bar is for getting low. Not as good for getting higher.
    -F
    It's never easier - you just go faster.
  1. Flat bar or riser?
    By thekrow4jc in forum 29er Bikes
    Last Post: 05-30-2013, 12:25 PM
  2. Flat bar vs riser bar
    By dudesok in forum General Discussion
    Last Post: 11-20-2012, 10:14 AM
  3. Who's gone from flat bar to riser and why
    By pamt in forum General Discussion
    Last Post: 03-02-2012, 06:21 AM
  4. Replies: 5
    Last Post: 09-01-2011, 10:11 PM
  5. Flat bar or riser?
    By bridger in forum 29er Bikes
    Last Post: 01-07-2011, 08:49 AM
Members who have read this thread: 4
