    replace bottom bracket help. Shimano BC1.37 68 zb....what is that?
    I think I have most of this figured out. Its a shimano bottom bracket with 1.37 english treading and its shell width is 68mm. What does the zb stand for? What would be a modern replacement? My bottom bracket on my commuter blew out so I need a new one.
    dru
    dru is offline
    You'll need to give us a lot more info than that if you want help. So far we know you have a 68 mm wide shell using English threading.
    What type of crank interface do you presently have?
    There's at least three types I can think of that Shimano uses.
    Square taper?
    Octalink (2 types)?
    External bearing?
    Of course there's ISIS from the other manufacturers too......
    Drew
    occasional cyclist
    I figured it out some of it. The crank is a FC-751 which uses an octalink spline v2. That means I probably should go for a ES71 or ES70, right? I'm a little confused on chainlines. I am running a single speed cannondale with a flip-flop hub in the rear. What version of these BB's do I need and where can I find them?
    Your local shop can get whatever you need ,online stores ,ebay.take your choise don't forget you need the right tool to remove and replace it.
  1. FSA Crank with Shimano Bottom Bracket
    By Bech in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2012, 03:04 PM
  2. LBS says replace my bottom bracket...
    By jbourne84 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2012, 07:58 AM
  3. Replies: 3
    Last Post: 12-12-2011, 11:17 PM
  4. shimano bottom bracket heirarchy?
    By raleigh5 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2011, 06:27 PM
  5. Shimano es51 bottom bracket
    By Geist262 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-25-2011, 05:02 AM
