Results 1 to 22 of 22
    Reputation: KevinGT's Avatar
    Dec 2012
    Recommendation for a good mini-pump for Camelback?
    I did a bunch of searching but haven't seen a good thread for recommended mini pumps. I hadn't checked my mini pump in over 5 years. When I needed it today, a mile from the car, it wouldn't work. So I'm in the market for a new one.
    I'm looking for one that's not too long (the 13" Topeak Mountain Morph is just too long for my taste). Being able to use CO2s in addition to manual pumping is a plus but not mandatory.
    I'm looking at the Crank Bros. Power Pump, the Blackburn Mammoth, and the Park Half-Pint.
    Suggestions?
    I live with fear and danger every day. And on the weekends she lets me go mountain biking.
    T.W.O.
    Reputation: mimi1885's Avatar
    Stick with Mountain morph or road morph, or pricy co2. Many mini pumps are useless. The Morph series are the next best thing to floor pumps. Mini-pumps may provide you some comfort of having a back up plan until you have to use it. Do yourself a favor, get the pump that would get you back on your bike without breaking sweats or giving you arm pump.
    I also heard many good things about Lezyne.
    powered by peanut butter.
    Reputation: heartland's Avatar
    I love my Blackburn Mammoth. I think it's a lot better than the Crank Bros pump.
    "Never trust a man in a blue trench coat. Never drive a car when you're dead." -- Tom Waits
    Reputation: ttusomeone's Avatar
    I have the Topeak RaceRocket MT (their MTB specific one). I used it for the first time in a race yesterday and was impressed at how quickly it pumped up my tire (29er). This is the only mini-pump I've used, but I would definitely recommend it.
    Quote Originally Posted by heartland View Post
    I use a Mammoth Stage 2. Has two settings, low/high pressure. About 50/30 pumps of each is enough to get a 26x2.0 to about 40 PSI.
    You're gonna get arm burn....unless you are carrying a frame pump. Not really practical on a mountain bike.
    Cow Clicker
    Reputation: wmac's Avatar
    Stans + Air Chuck Elite + a tube - just in case.
    No, YOU don't understand. You're making an ass of yourself for all of eternity.
    Jun 2012
    lezyne
    Reputation: B-Mac's Avatar
    Topeak Mountain Morph - it has a fold-out foot peg that allows you to use it like a mini-floor pump plus a built in gauge. Also has a short hose so you're not always about to bust off your valve stem. Strongly recommend this pump.
    Check out my You Tube Channel
    Feb 2012
    RE: Recommendation for a good mini-pump for Camelback?
    Blackburn evo. You can even use it as a small foot pump.
    Sent from my HTC6990LVW using Board Express
    Another vote for lezyne. Doesn't really get any easier then the lezyne. It's extremely small and lightweight. Very easy to use
    This is the one I use. Mountain Pipe
    Jun 2012
    Lezyne is also higher quality than topeak.
    Reputation: bykerider's Avatar
    I had bought a few of the usual pumps, topeak, BlackBurn. Every once in a while they did work well but usually they worked poorly.
    I ponied up the $45 for the lezyne. This thing makes large volume tires its prison *****.
    Just make sure to buy the high volume(HV) version for the best results.
    Lezyne High Volume Bicycle Hand Pumps
    Reputation: NYrr496's Avatar
    Topeak Mountain Morph here.
    I like turtles
    I carry a topeak pocket rocket and it has served me well for years.
    My next pump will be a lezyne though, they get nothing but great reviews and the idea of having a hose to connect to the valve just seems smart.
    Quote Originally Posted by bykerider View Post
    +1...Best $ can buy.
    12' Sir9 Rigid
    11' Jabber Rigid
    10 SJ SS rigid
    10' Swork SS 29er
    10' Tallboy
    08' RM Vertex SS
    Reputation: cbell3186's Avatar
    Re: Recommendation for a good mini-pump for Camelback?
    Agreed also, I have the the mini 'floor' pump, solid fast pumping, bulletproof, the long hose is perfect. after 3 or more of the cheapies you learn to just bite the bullet
    Reputation: Vlad_OfTranssylvania's Avatar
    Feb 2013
    Airstik Sl by blackburn... tiny but can inflat a 29er tire in no time. highly recommend it
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    A desiccated chimpanzee foreskin is better than a Crank Bros. pump.
    Sweat is just fat crying.
    Nov 2003
    I have two older Mammoths that have to be at least 15 years old, can that be right? Haven't had to do a thing to either, they just keep on keepin' on.
    Don't forget to wrap duct tape around the shaft, it's great to have in an emergency.
    Information on the trails at New Hogan Lake, Calaveras County, CA.
    May 2012
    I have crank brothers 2 stage pump(high volume/ and high pressure) from about 2003. I used it this past weekend and it worked fine. I have no idea if this model is still available.
    Joe
    2003 KHS Alite 4000 26" Hardtail - XC, All mountain, blah blah blah.. I just ride.
    i use axiom air enforce. its about 13" long but its really easy to use and pumps up tires quick.
Hot Deals
Contests
Latest Mountain Bike Articles
