• 02-03-2013
    KevinGT
    Recommendation for a good mini-pump for Camelback?
    I did a bunch of searching but haven't seen a good thread for recommended mini pumps. I hadn't checked my mini pump in over 5 years. When I needed it today, a mile from the car, it wouldn't work. So I'm in the market for a new one.
    I'm looking for one that's not too long (the 13" Topeak Mountain Morph is just too long for my taste). Being able to use CO2s in addition to manual pumping is a plus but not mandatory.
    I'm looking at the Crank Bros. Power Pump, the Blackburn Mammoth, and the Park Half-Pint.
    Suggestions?
  • 02-03-2013
    mimi1885
    Stick with Mountain morph or road morph, or pricy co2. Many mini pumps are useless. The Morph series are the next best thing to floor pumps. Mini-pumps may provide you some comfort of having a back up plan until you have to use it. Do yourself a favor, get the pump that would get you back on your bike without breaking sweats or giving you arm pump.
    I also heard many good things about Lezyne.:thumbsup:
  • 02-03-2013
    heartland
    I love my Blackburn Mammoth. I think it's a lot better than the Crank Bros pump.
  • 02-03-2013
    ttusomeone
    I have the Topeak RaceRocket MT (their MTB specific one). I used it for the first time in a race yesterday and was impressed at how quickly it pumped up my tire (29er). This is the only mini-pump I've used, but I would definitely recommend it.
  • 02-03-2013
    wschruba
    I use a Mammoth Stage 2. Has two settings, low/high pressure. About 50/30 pumps of each is enough to get a 26x2.0 to about 40 PSI.
    You're gonna get arm burn....unless you are carrying a frame pump. Not really practical on a mountain bike.
  • 02-03-2013
    wmac
    Stans + Air Chuck Elite + a tube - just in case.
  • 02-04-2013
    aBicycle
    lezyne
  • 02-04-2013
    B-Mac
    Topeak Mountain Morph - it has a fold-out foot peg that allows you to use it like a mini-floor pump plus a built in gauge. Also has a short hose so you're not always about to bust off your valve stem. Strongly recommend this pump.
  • 02-04-2013
    mbco1975
    RE: Recommendation for a good mini-pump for Camelback?
    Blackburn evo. You can even use it as a small foot pump.
    Sent from my HTC6990LVW using Board Express
  • 02-04-2013
    menusk
    Another vote for lezyne. Doesn't really get any easier then the lezyne. It's extremely small and lightweight. Very easy to use
  • 02-04-2013
    TBarnaby
    This is the one I use. Mountain Pipe
  • 02-04-2013
    aBicycle
    Lezyne is also higher quality than topeak.
  • 02-04-2013
    bykerider
    I had bought a few of the usual pumps, topeak, BlackBurn. Every once in a while they did work well but usually they worked poorly.
    I ponied up the $45 for the lezyne. This thing makes large volume tires its prison *****.
    Just make sure to buy the high volume(HV) version for the best results.
    Lezyne High Volume Bicycle Hand Pumps
  • 02-04-2013
    NYrr496
    Topeak Mountain Morph here.
  • 02-04-2013
    groupbmonster
    I carry a topeak pocket rocket and it has served me well for years.
    My next pump will be a lezyne though, they get nothing but great reviews and the idea of having a hose to connect to the valve just seems smart.
  • 02-04-2013
    snellvilleGAbiker
    +1...Best $ can buy.
  • 02-04-2013
    cbell3186
    Re: Recommendation for a good mini-pump for Camelback?
    Agreed also, I have the the mini 'floor' pump, solid fast pumping, bulletproof, the long hose is perfect. after 3 or more of the cheapies you learn to just bite the bullet
  • 02-20-2013
    Vlad_OfTranssylvania
    Airstik Sl by blackburn... tiny but can inflat a 29er tire in no time. highly recommend it
  • 02-20-2013
    dirt farmer
    A desiccated chimpanzee foreskin is better than a Crank Bros. pump.
  • 02-20-2013
    Finch Platte
    I have two older Mammoths that have to be at least 15 years old, can that be right? Haven't had to do a thing to either, they just keep on keepin' on.
    Don't forget to wrap duct tape around the shaft, it's great to have in an emergency.
  • 02-21-2013
    JoePAz
    I have crank brothers 2 stage pump(high volume/ and high pressure) from about 2003. I used it this past weekend and it worked fine. I have no idea if this model is still available.
  • 02-21-2013
    pizon
    i use axiom air enforce. its about 13" long but its really easy to use and pumps up tires quick.
