Results 1 to 17 of 17
    Oct 2010
    Quick disconnect adapter that fits Osprey Packs
    I own an Osprey Manta pack and it's great, but it's a real pain to maintain the bladder because it is always attached to the pack. I want to cut the tube so I can take it out easier. I found this Platypus piece below which is exactly what i'm looking for but it is too narrow for the wider tubes that Osprey uses on their proprietary packs. Is there another product like this, or a reliable modification to make it work without leaking?
    http://www.backcountry.com/platypus-...disconnect-kit
    wasn't sure where to post this.
    Quote Originally Posted by donkeykong0
    Not sure what you mean by the reservoir (bladder) always being attached to the pack. The reservoir should easily slide in and out of the pack.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    I just bought the camelback version of that yesterday and installed it. Works great!
    Reputation: ChainChain's Avatar
    Quote Originally Posted by ProjectDan35
    On an osprey pack?
    wannabee
    Reputation: giantbikeboy's Avatar
    Dec 2004
    http://www.outdoorpros.com/Prod/Nalg...searchcashback
    My Dakine pack had this bladder in it. Nalgene. Amazon has a few options.
    Mountain Man Dan
    No. On a camelback pack. Only way to go.
    I have an osprey pack and I gotta say over all I really like it. Way better than the old blowfish I had before. However, I'm not a huge fan of the bit valve and I could see this disconnect coupling being useful. the bite valve is clunky to thread through the elastic pieces on the shoulder strap.
    Mountain Man Dan
    Quote Originally Posted by ChainChain
    That was my issue with my camelback, i installed a 90 degree right angle end piece with the bitevalve and a shut off valve at the end, so I couldn't take the bladder out because it was connected to the hose which was put throw loops and whatnot. I installed that dis connect 3 inches from the bottom of the bladded, how much easier now.
    Oct 2010
    Quote Originally Posted by jeffbfox
    no. i want the tube to disconnect from the bladder, so i can fully detach it from the pack to make it easy to fill up, maintain, and dry, rather than dragging my whole pack to the sink.
    i did some more research and Osprey has their bladders custom made from Nalgene. There are Nalgene bladders that you can buy independently, that have the disconnect built into the base of the bladder, but the custom built ones for Osprey do not have this.
    I would just switch out the bladder to the regular Nalgene one, but then I would forego the rigid backing and custom fitting that makes it sit so well in the pack.
    Oct 2010
    Quote Originally Posted by giantbikeboy
    i saw this and its pretty much exactly what the Osprey comes with, minus the quick disconnect at the base, and (i'm presuming) the rigid and fitted back.
    wannabee
    Dec 2004
    oops, I thought that was the bladder with the disconnect.
    Reputation: skullcap's Avatar
    Maybe this?
    http://shop.katadyn.com/product/8014...&language_id=1
    I don't know if it's any wider than the platypus, but it might be worth looking into. Keep us posted, I'm looking at one of the Raptors and I'd be interested in knowing what solution ends up working for you.
    I'm enjoying my childhood way too much to ever give it up.
    Oct 2010
    Quote Originally Posted by skullcap
    Maybe this?
    nice find! that could do the trick. there aren't any specs though.
    I know, maybe call customer service and see if they have any info? Surely they know what it fits and what it doesn't. I haven't gotten a Raptor yet so I don't know what the ID (inner diameter) of the tubing is.
    I am also looking for a quick connect for Osprey packs.
    This web site has what we are all looking for, but it has a minimum order of 10.
    http://www.valueplastics.com/product...nnectMain.aspx
    I am willing to put in an order if I get enough interest from others. Complet set mailed to your door for say $10 each?
    wannabee
    Dec 2004
    since 4/10/2009
    Reputation: Harold's Avatar
    I use a Hydrapack bladder in my Osprey Talon pack. It has the sort of disconnect bit at the bladder you're asking about.
