Results 1 to 22 of 22
    Jan 2013
    Problem with wrist, will change of bike solve it
    I currently ride a hardtail chiner 29” with a rock shox Reba RL Solo Air 29". When riding on roots and rock gardens I get some pain in my wrists.
    I am considering changing bike to either a FS 29” bike with 100mm of travel, ie Trek Top Fuel, or a Fuel EX with 130mm of travel.
    Do you think going FS only will solve it, or is it better with more travel?
    Sneaker man
    Reputation: mik_git's Avatar
    probably not.
    All the gear and no idea.
    Reputation: Cuyuna's Avatar
    May 2017
    FS certainly helped my wrist pain due to arthritis in both wrists, as did a set of Ergon grips. I started with a Fatboy, then added a Bluto, then sold it for a Farley EX8. Made a HUGE difference in my riding comfort.
    Apr 2017
    Ergon for the win, I have terrible wrist pain from tens of thousands of hours playing guitar. Can't bike without the Ergons.
    Reputation: targnik's Avatar
    Jan 2014
    New grips + bar combo would be my first port of call ^^
    Different rubber would be my next go to...
    If that don't work, swap your new bits over to your new bike o_0
    Sent from my kltedv using Tapatalk
    "Mountain biking: the under-rated and drug-free antidepressant"
    Give'er!
    Reputation: MCHB's Avatar
    Jun 2014
    If the above suggestions don't work try a bar with more backsweep. That being said, you can also try rotating your existing bars forward/backward and seeing if that makes a difference. Likewise you can loosen and twist your brake levers into a more comfortable grab angle.
    ...I'm horrible at explaining things but hopefully that made sense!
    Jan 2013
    Thank you for all your replies, I will consider changing grips.
    Reputation: @Ride@'s Avatar
    Aug 2017
    Consider the angle of your brakes and shifters. If they are not inline with you arms, this sometimes causes you to awkwardly compensate for a bad angle with your wrists. Most people have them artificially high. Rotate them down.-your brakes, that is.
    Aug 2017
    They also say that Riser handlebars can help that problem.
    MTB B'dos
    Reputation: LyNx's Avatar
    I'd agree with what the others said, most likely some ergonoimic grips and or a bar with more or less sweep would do the trick or as suggested, simply try rotating your bar and see if that helps - amazing how many people who's bars are setup wonky.
    May 2017
    Quote Originally Posted by kave View Post
    Have you "THE CORRECT POSITION FOR THE WRIST" ?
    https://thedocandtheyogi.com/news/20...eruse-injuries
    RAKC Industries
    Jan 2017
    Definitely a set up issue. Grips may fix it. Seat height and distance in relation to the bars all can cause problems. Hell too much tire pressure can cause it.
    Basically if the bike isnt fitted correctly, things are going to hurt. Has nothing to do with being FS or hardtail (or even rigid) most of the time. Comes down to bad fit.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    US partner for Ravemen:
    www.rakclighting.com
    Dec 2016
    Yep, the Ergons with barends incorporated. A change of positions can help to releive stress between technical sections / whilst grinding up hills
    Reputation: Gasp4Air's Avatar
    Also: Do you tense up while absorbing the hits on roots and rocks? Are your elbows not bent? Both of these could be intensifying the impacts to your wrists. Staying loose and having your elbows bent, if you're not already doing so, could help a lot. Another thing I've noticed in my own riding is that too much weight forward will strain my wrists. Tweakng/changing bars, softer grips, Ergons, trying differenct stem kengths/angles, adjusting the saddle height/position might help. Small changes to the saddle angle will rotate your hips and can make a big difference in weight distribution. All the suggestions in previous posts are worth considering. I've been tweaking my cockpits for all the years I've been riding.
    Use it, use it, use it while you still have it.
    Nothing seems to kill me
    Reputation: CUP-TON's Avatar
    Dec 2016
    Check out Revolution Grips. I have talked to a few guys who had bad wrist pain while riding that was alleviated by using these grips. They have some sort of elastomer inserts that absorb trail chatter. Jenson USA has them. They are a little pricey but better with a 15% off coupon. And cheaper than about any other change.
    Like others, I use Ergons and they work for me, but if I had bad wrist pain I would try the Revolutions.
    Hello, my name is human and I came down from the stars.
    Sep 2014
    Poor brake lever angle wreaks havoc on the wrists, but its a certain kind of pain. Better suspension will help with fatigue.
    Best to play with brake lever angle before buying anything.
    May 2017
    You could play around with grips, levers, angles, bars, all that stuff, but it might be smart, at some point in the process, to actually try to find out why your wrists hurt. Arthritis, RSI, cysts, fractures...lots of things can go wrong with the hands and wrists as we age. At the least, a set of xrays might give your doctor and you an idea as to why your wrists hurt so much when biking, rather than just empirically buying new stuff and hoping you can stumble on a combination that makes them hurt less when your ride.
    In dog years, I'm dead.
    Reputation: burtronix's Avatar
    Quote Originally Posted by Gasp4Air View Post
    Yes, yes, yes! Do all the technique changes first. Then tweak your bar, lever, & saddle position to optimize around good technique. Then, last of all, change your hardware if you think there's still room for improvement.
    Lots of good advice here - just need to put it in proper priority.
    Sent from my SM-G955U using Tapatalk
    Whatever your hand finds to do, do it with all your might.... (Ecclesiastes 9:10)
    Quote Originally Posted by Ntinos P View Post
    Great article. I used to do some industrial ergonomics & this is right on for cycling wrist position in general. However, for MTB there are some additional technique for elbow & body position that can further reduce stress to the wrists. See the post by Gasp4Air.
    Mar 2012
    I generally don't have wrist pain but I think the straight angle on most mtb bars can be to blame for a lot of hand and wrist problems. I've been heavily considering getting handlebars with 16 degrees of sweep. Its a much more natural fit in your hand than a bar with minimal sweep.
    I think the Ergon grips simulate how a more swept back bar fits and it gives the palm of your hand a bigger platform to reduce pressure. A lot cheaper than new handlebars too.
    Tire pressure and fork set up correct? Rock hard won't help. At all.
    MTB B'dos
    ....wrong thread
  1. Wrist tendonitis & Wrist Support
    By waterkress in forum Apparel and Protection
    Last Post: 11-23-2016, 07:00 AM
  2. Replies: 41
    Last Post: 09-12-2013, 01:12 PM
  3. Wrist fracture prevention with wrist brace?
    By jared_j in forum Rider Down, injuries and recovery
    Last Post: 08-13-2013, 08:43 AM
  4. Solve my tube/tire problem and win the interwebz....
    By loki_racer in forum Wheels and Tires
    Last Post: 10-31-2011, 08:35 PM
  5. Do wrist guards actually prevent your wrist from breaking?
    By LoneReaction in forum Apparel and Protection
    Last Post: 09-02-2011, 09:50 AM
Members who have read this thread: 73
