Results 1 to 2 of 2
    Sep 2012
    Problem with syntace x12 142mm rear axle
    The problem is that today I removed the rear wheel and when I looked at the syntace x12 it had the rubber o-ring, that goes on the edge of the end where you put the allen, ruined. I mean its cut so is more of an U ring now. Should I look for an o-ring to fit there or should I try to get a new axle? Im worried because I use this bike to commute so I use a lot.
    Should I not ride it? I put the ruined o ring in there and put the thing back together but I can see the o-ring all squished in the edge of the axle, feels like a tight fit but I know is not where it is supposed to be. thanks
    Syntace O-ring
    Hey Cridom,
    If you are in the US or Canada, send an email with your contact to info@syntace-us.com and we can get that taken care of. You can also call at 510-261-8836. Shouldn't be a problem if you ride it but just make sure you check it for tightness before riding.
    Thanks - Kenny
    Syntace USA
    Quote Originally Posted by cridom View Post
  1. 142mm rear axle convert to 135 QR?
    By WVJon75 in forum 29er Components
    Last Post: 12-03-2012, 02:27 PM
  2. Syntace X-12 rear axle on Epic?
    By bootsie_cat in forum Specialized
    Last Post: 10-07-2012, 06:23 AM
  3. Possible I9 Rear Hub Problem with 12mm Thru Axle?
    By BullSCit in forum Wheels and Tires
    Last Post: 03-21-2012, 08:13 PM
  4. Hardtail that takes 142mm rear axle.
    By weedkilla1 in forum 29er Bikes
    Last Post: 03-01-2012, 08:53 AM
  5. Syntace axle with 12 x 142mm chip kit
    By soderblom in forum Yeti
    Last Post: 01-02-2012, 08:43 AM
