Results 1 to 17 of 17
    Dec 2013
    Pressure gauge that isn't a piece of ****?
    I've been using accugauge pressure gauges. Last weekend I pinch flatted during a race (yes, tubeless) , and today my tires felt soft despite what the gauge said, so I double checked with my other accugauge. 22 psi on one, 14 psi on the other. #&@$+#$@ No wonder I pinch flatted, the thing is off by almost 8 psi. At this point I'd be better off throwing them away and going by feel.
    Does there exist a reliable and accurate gauge that works in the 20 psi range? I don't mind spending money if it's paying for quality. But it has to frigging work.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Yes, I call it "my hands".
    Reputation: Ronnie's Avatar
    I've found one of these to be fairly accurate and consistant:
    TopeakŪ Cycling Accessories ? Products - SmartGauge D2
    The trouble with having an open mind is that people will insist on trying to put things in it.
    RAKC
    Reputation: tigris99's Avatar
    Ya I gave up gauges for my tires at this point, been wondering the same thing, not even so concerned about exact accuracy, more about consistency and one that will last. For the moment my hand works for tire pressures. But even that's not very consistent. Like the bike feeling heavier one day when carrying it than the day before.
    Be watching this to see what ppl recommend.
    Sent from my Nokia Stupid Phone using Tapatalk
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Pressure gauge that isn't a piece of ****?
    I have one of those toppeak as well and find it to be pretty accurate.
    Dec 2013
    Quote Originally Posted by Ronnie View Post
    Thanks. Any problems with it releasing a lot of air when you take a reading? From the amazon reviews:
    Quote Originally Posted by amazon
    Great for letting air out of your tires and giving you really, really inaccurate tire pressure readings. I didn't believe all the other bad reviews, but now that I've wasted my money, I would never purchase again.
    Reputation: shiggy's Avatar
    Dec 1998
    I use the Schwalbe digital gauge. Consistent, easy to use. Better than any other I have used including all previously mentioned in this thread.
    mtbtires.com
    > /dev/null 2&>1
    Feb 2012
    Quote Originally Posted by matto6 View Post
    You do have to be quick and strong when you engage it. But you get the hang of it quickly.
    Shiggy has usually tried everything so I'd trust his recommendation.
    Reputation: DethWshBkr's Avatar
    I hate digital gauges.
    I use one of these, MX and mountain bike!
    KTM Tire Gauge | ATV | Rocky Mountain ATV/MC
    Yes, you need a presta adapter, but I think everyone should have one at all times anyway.
    Dec 2013
    Quote Originally Posted by DethWshBkr View Post
    Interesting.
    Re: the presta adapter. Having one at all times is one thing, but screwing it on and off each wheel every time you go for a ride...... Is that what you do?
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    I've been rocking that Topeak for a solid 6 months. I ride 3-4 times a week and check my pressure before each ride. Hasn't failed me yet with tubes and now tubeless.
    I have sampled a tire 2 consecutive times and have received the same reading each time so air loss is a non-issue. As stated above, watching for a good engagement of the presta and a deliberate, quick action prevents any air loss.
    Colorado
    Reputation: ltspd1's Avatar
    Nov 2007
    Agree. The gauge on my beloved Silca pump quit years ago. However, I've been riding long enough to know what pressure I need for the conditions I'm riding just by feel.
    Interesting.
    I actually leave at least one on the valve stem at all times. Yes, I have to take it off, tighten the presta "nut" and screw the adapter back on.
    Often times, I have both valve stems with adapters, on at all times.
    You never know when you will need them!
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    I've been happy with the SKS Airchecker.
    GRAVELBIKE.COM - ride everything
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    I've been using the same Zefal analog gauge for years. No plans to change any time soon.
    Let's make like a Bike and get the Huck outta here...
    Jul 2013
    I use my Zefal floor pump to check the pressure on my bike tires. The good thing about using the pump gauge is I could readily add more air if the indicated pressure is not enough.
    I'm not the type of person who would have the patience to check a tire pressure with a gauge, then remove the gauge and connect the air pump to add more air in. That's unnecessarily adding extra steps for set of tasks which can be simplified.
    What works for me may not work for you. What's best for you depends on many factors. We are different from each other.
    Sep 2012
    I keep a floor pump with an oversized gauge for easy reading in my truck and check to make sure I'm good before each ride. If I need air then it's already attached to the valve.
  1. Recommend pressure gauge please?
    By mforness3000 in forum Wheels and Tires
    Last Post: 02-08-2017, 01:49 PM
  2. low pressure gauge?
    By Ant-Eater in forum Fat bikes
    Last Post: 03-06-2013, 11:56 PM
  3. Digital pressure gauge
    By trap121 in forum Wheels and Tires
    Last Post: 02-02-2013, 07:21 AM
  4. Finally... a pressure gauge that does it all!
    By meltingfeather in forum Wheels and Tires
    Last Post: 04-30-2012, 06:45 PM
  5. Presta Pressure Gauge
    By tooclosetosee in forum Tooltime
    Last Post: 11-08-2011, 03:33 PM
