Results 1 to 35 of 35
    MTBiker
    Plasti Dip to protect your bike frame
    I just bought some clear Plasti Dip in an aerosol can from the local Ace, the helpful place. Since my Enduro is still fairly new, I wanted to keep the paint looking fresh, so I put on 4 coats on high wear areas such as cable rub areas and the bottom side of the downtube. It's not quite tough enough for the chainstay unless I put maybe 20+ coats or something...
    Since the paint on this bike is matte already, it looks exactly the same, but now has a protective rubber coating that I can peel off in the future. It's abrasion, chemical, and heat resistant. In fact it even covered up some minor scuff marks already in the paint. I still need to see how it does over time, but I hope it works out.
    Has anyone tried this?
    We can bomb the world to pieces, but we can't bomb it into peace -Michael Franti
    Underskilled
    Reputation: CaveGiant's Avatar
    you have
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Reputation: 11 Bravo's Avatar
    I always use Helicopter Tape or Racers Tape.
    I'm not very smart, but I can lift heavy things
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    I've thought of dipping the brake levers in PlastiDip, wondering how many coats are needed.
    MTBiker
    Oh the brake levers sound like a good idea. The rubber finger pads on my gloves wore off long ago
    Reputation: nachomc's Avatar
    I wrap my entire frame in old tubes. It's cheaper and VERY green!
    :wq
    Nov 2008
    Listen!
    Sounds like a great idea to prevent cable rub. Is it available in white?
    MTBiker
    Old tubes would be pretty heavy lol
    Yes, it's available in white as well as black, red, and yellow (and maybe blue).
    I just checked on it to day after it has fully cured. I think it will work very well.
    Nov 2008
    Thanks for the reply, I guess you have to rough up the clearcoat so it will stick. I've been looking for alternatives to tape for cable rub, thanks allot!
    MTBiker
    Quote Originally Posted by hillwilly
    You don't need to rough up the clearcoat. It doesn't really adhere to the surface, but instead coats the surface with a rubber film. That's the beauty of it, because then you can peel it off if you don't like it or want to redo it.
    I used the black color on my car to paint the chrome trim and grilles. No prep at all aside from soap & water, so I can still revert to the original look in the future.
    Before anyone goes out and buys it for this application, I should get some rides in to see if it holds up to cable rubbing. It will be pointless if it comes right off.
    WWYD?
    Reputation: johnnyb's Avatar
    I've used plasti-dip on my commuter for years to protect the bolts and rack clamps from the salt spray of riding the ferry to work. I have the can and I transferred to an airtight bottle. It paints/drips on really well with plastic knife or old spoke.
    I use Clear Bra on my bike http://www.stickercity.com/clear-bra/.
    It comes in all sizes, easy to trim, easy to apply, easy to remove.
    It also comes in different color, even carbon fiber look.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Could you put this on your crank arm to prevent the black paint from rubbing off? Or would it be to grippy on the shoes?
    The bike is nothing more then circles turning circles, It's the human motor that makes it elegant.
    MTBiker
    Quote Originally Posted by ProjectDan35
    I think it will grip to your shoes and get rubbed off too easily. A tape-like protector would be better on the cranks I think, if you can put it on smoothly.
    Mountain Man Dan
    Mmm. I'm going to pick up a can and spray it various places.
    Mountain Man Dan
    EDIT nevermind
    Proud Snob
    This sounds like it would seal in moisture.
    Aug 2010
    Sounds like your defeating the purpose of "riding" the bike. " oh a scratch here; oh my gosh one there!" just ride the damn thing
    2011 transition 250
    2009 DB scapegoat
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Sounds like whoosh!
    Quote Originally Posted by Twisted1
    Sounds like the point has gone over your head. The OP is talking about high wear areas on the frame.
    JPark - 3.5- don't listen to dremer
    Proud Snob
    Let them wear.
    Eventually ruins your bike...
    Quote Originally Posted by metaljim
    Let them wear.
    Cable rub and wear will eventually eat a hole in your frame. It's a fairly big deal for people who keep their bikes for longer than 1-2 years.
    Ride Instigator
    Reputation: Ricko's Avatar
    Quote Originally Posted by 11 Bravo
    I've heard of people using this "Helicopter Tape". Does it go by any other name and where do you purchase it?
    Proud Snob
    Quote Originally Posted by Ken in KC
    I've heard this, but I've never seen it. I've had lots of older bikes, some near 25 years old (current mountain bike is a 15 year old frame), all with cable rub spots, but nothing close to wearing down the frame material. I get that it's a possibility, but I just don't think it's a valid concern for anyone.
    Not to say you shouldn't protect your frame. If you want to, then by all means do it. But I really doubt that it's saving you from wearing a hole in your frame.
    shower strip stick ons. heavy duty, clings like a 500 pound gorilla, and comes in many colors. easy to cut and looks like a decal.
    /bing
    Aug 2010
    It would take over 50 years for the plastic around the cable to rub a hole in a steel or aluminum frame. Don't be a dingle berry and worry about minor things like this. Just ride!
    2011 transition 250
    2009 DB scapegoat
    Ignorance...
    You must lead a blissful life. You're wrong. It can take as little as 5 years, depending on the amount you ride.
    Quote Originally Posted by Ricko
    I'm sure it is available from lots of places, but I bought it from here.
    Aug 2010
    If I'm wrong show the facts! Why would top dog manufactures engineer bikes like this then? You have pics of the cable rubbing hole in the frame?
    2011 transition 250
    2009 DB scapegoat
    Proud Snob
    Your number may be wrong, but it sure isn't 5 years. I'm looking at my 1995 Stumpjumper right now that has plenty of wear, and there's the tiniest couple of spots where I can see bare metal.
    I've had bikes nearly 30 years old with shift cables routed on top of the BB shell along painted metal guides and there was not any amount of damage done to the material. And if a derailer cable with constant tension isn't eating it's way through the frame, then a little spot where the housing slaps isn't going to do anything.
    Reputation: bandit350's Avatar
    Apr 2005
    3m automotive tape -> recommended
    http://solutions.3m.com/wps/portal/3...otection/Film/
    the 3M automotive film looks similar to clear bra. i picked up a large roll on ebay for about 5 dollars and it has worked great. similar to the clear patches at bike shops but in roll form and much wider. i've had it on a couple bikes for years. great buy.
    DynoDon
    Reputation: manabiker's Avatar
    Tree Fort bikes found these for me, made by Jagwire, just place them where they don't interfere with turning or shifting. They come in silver or black
    Treefortbikes.com
    Jagwireusa.com / accessories / stick on guides
    <img src="http://i892.photobucket.com/albums/ac122/manabiker/P8150002.jpg">
    <img src="http://i892.photobucket.com/albums/ac122/manabiker/P8150003.jpg">
    Reputation: Glynis27's Avatar
    I've seen a few times where a cable has rubbed half-way through the frame tubing. It isn't just the housing that does the rubbing but rather the dirt and grit trapped between the housing and the frame. The soil in your area and the cleanliness of the bike play a huge role.
    I'd rather not even have my paint rubbed off at all, thanks, especially on my steel bikes. I just use the stick-on 3M film
    '15 Soma Wolverine '12 Soma Analog SS '10 Transition TransAM '07 Felt F1X '97 Schwinn Mesa SS '89 Fuji Saratoga '86 Fuji Club
    Sorry...
    It happened back in the mid-90's before I could afford a digital camera. No pics.
    "Why would top dog manufacturers engineer bikes like this then?" It really doesn't have anything to do with engineering. But to answer your question with a question: Ever heard of Biopace or elastomer forks?
    Reputation: boomn's Avatar
    I've seen it before too, where an exposed cable had cut through a frame tube.
    The growing popularity of full-length housing will eliminate some of that possibility, but even housing can do some serious damage to paint pretty quickly
    Reputation: GTscoob's Avatar
    Bump!
    How'd this hold up? I'm thinking of using some plastidip on my Access 29er frame and my dirt jumper since it'll be a lot less than powdercoating.
